Hey there, I have just gotten the M5 Stack and used the configuration.yaml from github for the M5 and there is a switch configured which is quiet important because it toggles the Wake Word Listening but its not in HA
okay now I updated to the new ESPHome version 2023.12.0 and now its not even connecting to WIFI anymore here are the logs
I (29) boot: compile time 10:00:24
I (29) boot: chip revision: v1.1
I (31) boot.esp32: SPI Speed : 40MHz
I (36) boot.esp32: SPI Mode : DIO
I (41) boot.esp32: SPI Flash Size : 4MB
I (45) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (54) boot: ## Label Usage Type ST Offset Length
I (61) boot: 0 otadata OTA data 01 00 00009000 00002000
I (69) boot: 1 phy_init RF data 01 01 0000b000 00001000
I (76) boot: 2 app0 OTA app 00 10 00010000 001c0000
I (84) boot: 3 app1 OTA app 00 11 001d0000 001c0000
I (91) boot: 4 nvs WiFi data 01 02 00390000 0006d000
I (99) boot: End of partition table
I (103) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=479e4h (293348) map
I (218) esp_image: segment 1: paddr=00057a0c vaddr=3ffbdb60 size=04d04h ( 19716) load
I (226) esp_image: segment 2: paddr=0005c718 vaddr=40080000 size=03900h ( 14592) load
I (232) esp_image: segment 3: paddr=00060020 vaddr=400d0020 size=113f5ch (1130332) map
I (641) esp_image: segment 4: paddr=00173f84 vaddr=40083900 size=1a35ch (107356) load
I (700) boot: Loaded app from partition at offset 0x10000
I (700) boot: Disabling RNG early entropy source...
I (712) cpu_start: Pro cpu up.
I (712) cpu_start: Starting app cpu, entry point is 0x40082a30
I (0) cpu_start: App cpu up.
I (728) cpu_start: Pro cpu start user code
I (728) cpu_start: cpu freq: 160000000
I (728) cpu_start: Application information:
I (733) cpu_start: Project name: atomecho
I (738) cpu_start: App version: 2023.11.6
I (743) cpu_start: Compile time: Dec 21 2023 09:59:21
I (749) cpu_start: ELF file SHA256: 1b917a97ac0e9ae5...
I (755) cpu_start: ESP-IDF: 4.4.5
I (760) cpu_start: Min chip rev: v0.0
I (764) cpu_start: Max chip rev: v3.99
I (769) cpu_start: Chip rev: v1.1
I (774) heap_init: Initializing. RAM available for dynamic allocation:
I (781) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
I (787) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
I (793) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
I (799) heap_init: At 3FFCB6B8 len 00014948 (82 KiB): DRAM
I (806) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (812) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (818) heap_init: At 4009DC5C len 000023A4 (8 KiB): IRAM
I (826) spi_flash: detected chip: gd
I (829) spi_flash: flash io: dio
I (834) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
Y��y���0�0S�
I (29) boot: ESP-IDF 4.4.5 2nd stage bootloader
I (32) boot.esp32: SPI Speed : 40MHz
I (62) boot: 0 otadata OTA data 01 00 00009000 00002000
I (800) heap_init: At 3FFCB6B8 len 00014948 (82 KiB): DRAM
I (835) cpu_start: Starting scheduler on PRO CPU.
[I][logger:326]: Log initialized
[C][ota:473]: There have been 3 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[V][esp32.preferences:126]: sync: key: 233825507, len: 4
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[V][app:030]: Sorting components by setup priority...
[C][esp32_rmt_led_strip:019]: Setting up ESP32 LED Strip...
[V][esp-idf:000]: I (256) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
[D][binary_sensor:034]: 'Button': Sending initial state OFF
[C][light:035]: Setting up light 'M5Stack Atom Echo 1012d8'...
[D][light:036]: 'M5Stack Atom Echo 1012d8' Setting:
[D][light:041]: Color mode: RGB
[D][template.switch:046]: Restored state ON
[D][switch:012]: 'Use wake word' Turning ON.
[D][switch:055]: 'Use wake word': Sending state ON
[E][voice_assistant:468]: No API client connected
[D][voice_assistant:422]: State changed from IDLE to IDLE
[D][voice_assistant:428]: Desired state set to IDLE
[D][switch:012]: 'Use Listen Light' Turning ON.
[D][switch:055]: 'Use Listen Light': Sending state ON
[D][light:047]: State: ON
[D][light:051]: Brightness: 60%
[D][light:059]: Red: 100%, Green: 89%, Blue: 71%
[C][i2s_audio:024]: Setting up I2S Audio...
[C][i2s_audio.microphone:018]: Setting up I2S Audio Microphone...
[C][esp32_ble:027]: Setting up BLE...
[C][wifi:038]: Setting up WiFi...
[V][esp-idf:000]: I (382) wifi:
[V][esp-idf:000]: wifi driver task: 3ffd64d4, prio:23, stack:6656, core=0
[V][esp-idf:000]:
[V][esp-idf:000]: I (1615) system_api: Base MAC address is not set
[V][esp-idf:000]: I (1625) system_api: read default base MAC address from EFUSE
[V][esp-idf:000]: I (1638) wifi:
[V][esp-idf:000]: wifi firmware version: 0f80fa0
[V][esp-idf:000]:
[V][esp-idf:000]: I (1645) wifi:
[V][esp-idf:000]: wifi certification version: v7.0
[V][esp-idf:000]:
[V][esp-idf:000]: I (1666) wifi:
[V][esp-idf:000]: config NVS flash: enabled
[V][esp-idf:000]:
[V][esp-idf:000]: config nano formating: disabled
[V][esp-idf:000]:
[V][esp-idf:000]: I (1677) wifi:
[V][esp-idf:000]: Init data frame dynamic rx buffer num: 32
[V][esp-idf:000]:
[V][esp-idf:000]: I (1696) wifi:
[V][esp-idf:000]: Init management frame dynamic rx buffer num: 32
[V][esp-idf:000]:
[V][esp-idf:000]: I (1707) wifi:
[V][esp-idf:000]: Init management short buffer num: 32
[V][esp-idf:000]:
[V][esp-idf:000]: I (1717) wifi:
[V][esp-idf:000]: Init dynamic tx buffer num: 32
[V][esp-idf:000]:
[V][esp-idf:000]: I (1738) wifi:
[V][esp-idf:000]: Init static rx buffer size: 1600
[V][esp-idf:000]:
[V][esp-idf:000]: I (1748) wifi:
[V][esp-idf:000]: Init static rx buffer num: 10
[V][esp-idf:000]:
[V][esp-idf:000]: I (1758) wifi:
[V][esp-idf:000]: Init dynamic rx buffer num: 32
[V][esp-idf:000]:
[V][esp-idf:000]: I (1769) wifi_init: rx ba win: 6
[V][esp-idf:000]: I (1770) wifi_init: tcpip mbox: 32
[V][esp-idf:000]: I (1779) wifi_init: udp mbox: 6
[V][esp-idf:000]: I (1779) wifi_init: tcp mbox: 6
[V][esp-idf:000]: I (1789) wifi_init: tcp tx win: 5744
[V][esp-idf:000]: I (1799) wifi_init: tcp rx win: 5744
[V][esp-idf:000]: I (1799) wifi_init: tcp mss: 1440
[V][esp-idf:000]: I (1809) wifi_init: WiFi IRAM OP enabled
[V][esp-idf:000]: I (1819) wifi_init: WiFi RX IRAM OP enabled
[C][wifi:051]: Starting WiFi...
[C][wifi:052]: Local MAC: E8:6B:EA:10:12:D8
[V][esp32.preferences:059]: nvs_get_blob('88491487'): ESP_ERR_NVS_NOT_FOUND - the key might not be set yet
[V][wifi_esp32:213]: Enabling AP.
[V][esp-idf:000]: I (1841) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
[V][esp-idf:000]: I (1948) wifi:
[V][esp-idf:000]: mode : softAP (e8:6b:ea:10:12:d9)
[V][esp-idf:000]:
[V][esp-idf:000]: I (1950) wifi:
[V][esp-idf:000]: Total power save buffer number: 16
[V][esp-idf:000]:
[V][esp-idf:000]: I (1952) wifi:
[V][esp-idf:000]: Init max length of beacon: 752/752
[V][esp-idf:000]:
[V][esp-idf:000]: I (1963) wifi:
[V][esp-idf:000]:
[C][wifi:239]: Setting up AP...
[C][wifi:241]: AP SSID: 'i45a'
[C][wifi:242]: AP Password: '100170416810'
[V][esp-idf:000]: I (2742) wifi:
[V][esp-idf:000]:
[V][wifi_esp32:804]: DHCP server IP lease start: 192.168.4.100
[V][wifi_esp32:807]: DHCP server IP lease end: 192.168.4.200
[C][wifi:251]: IP Address: 192.168.4.1
[V][wifi_esp32:208]: Enabling STA.
[V][esp-idf:000]: I (2748) wifi:
[V][esp-idf:000]: mode : sta (e8:6b:ea:10:12:d8) + softAP (e8:6b:ea:10:12:d9)
[V][esp-idf:000]:
[V][esp-idf:000]: I (2767) wifi:
[V][esp-idf:000]: enable tsf
[V][esp-idf:000]:
[D][esp32_improv.component:240]: Setting Improv to start
[C][ota:097]: Over-The-Air Updates:
[C][ota:098]: Address: atomecho.local:3232
[C][ota:101]: Using Password.
[W][ota:107]: Last Boot was an unhandled reset, will proceed to safe mode in 7 restarts
[C][api:025]: Setting up Home Assistant API server...
[D][wifi:441]: Starting scan...
[C][voice_assistant:028]: Setting up Voice Assistant...
[C][i2s_audio.speaker:019]: Setting up I2S Audio Speaker...
[I][app:062]: setup() finished successfully!
[D][esp32.preferences:114]: Saving 2 preferences to flash...
[V][esp32.preferences:137]: NVS data not changed skipping 4088855305 len=1
[V][esp32.preferences:137]: NVS data not changed skipping 347086140 len=1
[D][esp32.preferences:143]: Saving 2 preferences to flash: 2 cached, 0 written, 0 failed
[D][esp32_ble:270]: Enabling BLE...
[V][esp-idf:000]: I (2858) BTDM_INIT: BT controller compile version [97e0759]
[W][component:214]: Component esp32_ble took a long time for an operation (0.52 s).
[W][component:215]: Components should block for at most 20-30ms.
[V][wifi_esp32:702]: Event: WiFi AP start
[V][wifi_esp32:706]: Event: WiFi AP stop
[V][wifi_esp32:596]: Event: WiFi STA start
[V][esp-idf:000]: I (3384) wifi:
[V][esp-idf:000]: Set ps type: 1
[V][esp-idf:000]:
[I][app:102]: ESPHome version 2023.11.6 compiled on Dec 21 2023, 09:59:21
[I][app:104]: Project m5stack.atom-echo-voice-assistant version 1.0
[C][logger:416]: Logger:
[C][logger:417]: Level: VERBOSE
[C][logger:418]: Log Baud Rate: 115200
[C][logger:420]: Hardware UART: UART0
[V][esp32_ble:328]: (BLE) gatts_event [esp_gatt_if: 3] - 0
[V][esp32_ble_server:119]: Creating BLE service - 0x180A
[V][esp32_ble:328]: (BLE) gatts_event [esp_gatt_if: 3] - 7
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 0x2A24
[V][esp32_ble:328]: (BLE) gatts_event [esp_gatt_if: 3] - 9
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 0x2A26
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 0x2A29
[C][esp32_rmt_led_strip:171]: ESP32 RMT LED Strip:
[C][esp32_rmt_led_strip:172]: Pin: 27
[C][esp32_rmt_led_strip:173]: Channel: 0
[C][esp32_rmt_led_strip:198]: RGB Order: GRB
[C][esp32_rmt_led_strip:199]: Max refresh rate: 0
[C][esp32_rmt_led_strip:200]: Number of LEDs: 1
[V][esp32_ble:328]: (BLE) gatts_event [esp_gatt_if: 3] - 12
[D][esp32_ble_server:077]: BLE server setup successfully
[D][esp32_improv.component:077]: Creating Improv service
[V][esp32_ble_server:119]: Creating BLE service - 00467768-6228-2272-4663-277478268000
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 00467768-6228-2272-4663-277478268001
[V][esp32_ble_server.descriptor:029]: Creating descriptor - 0x2902
[V][esp32_ble:328]: (BLE) gatts_event [esp_gatt_if: 3] - 10
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 00467768-6228-2272-4663-277478268002
[C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Button'
[C][gpio.binary_sensor:016]: Pin: GPIO39
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 00467768-6228-2272-4663-277478268003
[C][light:103]: Light 'M5Stack Atom Echo 1012d8'
[C][light:105]: Default Transition Length: 0.0s
[C][light:106]: Gamma Correct: 2.80
[C][template.switch:068]: Template Switch 'Use wake word'
[C][template.switch:091]: Restore Mode: restore defaults to ON
[C][template.switch:057]: Optimistic: YES
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 00467768-6228-2272-4663-277478268004
[C][template.switch:068]: Template Switch 'Use Listen Light'
[C][factory_reset.button:011]: Factory Reset Button 'Factory reset'
[C][factory_reset.button:011]: Icon: 'mdi:restart-alert'
[V][esp32_ble_server.characteristic:118]: Creating characteristic - 00467768-6228-2272-4663-277478268005
[V][esp-idf:000]: W (3784) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[V][esp32_improv.component:190]: Setting state: 1
[D][esp32_improv.component:097]: Service started!
[V][esp-idf:000]: W (3800) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[V][esp32_improv.component:190]: Setting state: 2
[V][esp-idf:000]: W (3822) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[C][esp32_ble:374]: ESP32 BLE:
[C][esp32_ble:376]: MAC address: E8:6B:EA:10:12:DA
[C][esp32_ble:377]: IO Capability: none
[V][esp-idf:000]: W (3835) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
[C][esp32_ble_server:200]: ESP32 BLE Server:
[C][esp32_improv.component:257]: ESP32 Improv:
[C][wifi:559]: WiFi:
[V][esp-idf:000]: W (3880) wifi:
[V][esp-idf:000]: Haven't to connect to a suitable AP now!
[V][esp-idf:000]:
[W][wifi_esp32:873]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:391]: Local MAC: E8:6B:EA:10:12:D8
[V][esp-idf:000]: W (3883) wifi:
[V][esp-idf:000]:
[W][wifi_esp32:883]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:396]: SSID: ''[redacted]
[C][wifi:397]: IP Address: 0.0.0.0
[C][wifi:399]: BSSID: 00:00:00:00:00:00[redacted]
[C][wifi:400]: Hostname: 'atomecho-1012d8'
[V][esp-idf:000]: W (3923) wifi:
[V][esp-idf:000]:
[W][wifi_esp32:894]: esp_wifi_sta_get_ap_info failed: ESP_ERR_WIFI_NOT_CONNECT
[C][wifi:402]: Signal strength: 0 dB ▂▄▆█
[C][wifi:406]: Channel: 7
[C][wifi:407]: Subnet: 255.255.255.0
[C][wifi:408]: Gateway: 192.168.4.1
[C][wifi:409]: DNS1: 0.0.0.0
[C][wifi:410]: DNS2: 0.0.0.0
[C][mdns:115]: mDNS:
[C][mdns:116]: Hostname: atomecho-1012d8
[V][mdns:117]: Services:
[V][mdns:119]: - _esphomelib, _tcp, 6053
[V][mdns:121]: TXT: friendly_name = M5Stack Atom Echo 1012d8
[V][mdns:121]: TXT: version = 2023.11.6
[V][mdns:121]: TXT: mac = e86bea1012d8
[V][mdns:121]: TXT: platform = ESP32
[V][mdns:121]: TXT: board = m5stack-atom
[V][mdns:121]: TXT: network = wifi
[V][mdns:121]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[V][mdns:121]: TXT: project_name = m5stack.atom-echo-voice-assistant
[V][mdns:121]: TXT: project_version = 1.0
[V][mdns:121]: TXT: package_import_url = github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
[C][api:139]: API Server:
[C][api:140]: Address: atomecho.local:6053
[C][api:142]: Using noise encryption: YES
[C][improv_serial:032]: Improv Serial:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:6608
load:0x40078000,len:15060
ho 0 tail 12 room 4
load:0x40080400,len:3816
entry 0x40080698
I (77) boot: 2 app0 OTA app 00 10 00010000 001c0000
I (92) boot: 4 nvs WiFi data 01 02 00390000 0006d000
I (765) cpu_start: Max chip rev: v3.99
I (819) heap_init: At 4009DC5C len 000023A4 (8 KiB): IRAM
now realizing there might be a need for unique_id on those sensor entities? never did that before, still rather newish to ESPHme myself.
lets find some other examples out there
With your configuration it finally works thanks allot, even though I dont have the buttons for controlling the volume anymore which doesnt really matter to me
