I am using a wmos d1 mini with esp home to control water valves in our garden. That works perfectly fine. Since last week I added a rain sensor with a potential free contact. It just is closed if the sensor is dry and it opens when it rains.
Here the ESP Home Code
binary_sensor:
- platform: gpio
pin:
number: GPIO2
mode:
input: true
pullup: true
device_class: moisture
Now the Problem I got. When the rain-sensor is connected to ground and D4 (with pullup) the wmos mini will not startup properly - its will never show up in Home Assistant. After disconnecting the rain sensor, the wmos mini comes up as normal. I also can connect the rain sensor afterwards an everything including the rain sensor works fine. The question: What happens during the startup, the prevents the normal boot if ground and D4 is connected?
Thanks for your help.
