Hi All
I recently purchased a ESP32D0WDQ5 (revision 1) device and loaded the custom firmware from Hassio 3.8 in a VM with ESPHome module loaded in home assistant.
Once flashed via USB and the device has restarted, I am not able to see the device join my WI-FI network (left for 5-10 mins) I have tried loaded custom firmware from ESPHome, both ‘ESP8266’ & ‘esp_wroom_02’ boards and still no luck. (checked WI-FI name and credentials)
I have check ESPHome and forums here, and can’t find any information about how you determine the physical board you have with the list of devices available in the flashing process.
I am using ESPflasher on Windows to do the flashing process (hold boot button)
Hopefully someone out there has come across something similar and or has experience with these sorts of things.
