Hopefully this is really simple for someone, but my searching isnt bringing up the answer and after a few days of testing different ‘solutions’ none seems to have worked for me.
I am followins Dr Zzzs guide for a Tasmota/Sonoff. I am using a NodeMCU and can setup the Temp sensor which works fine, but when I setup the PIR sensor that works, but it then stops the Temp sensor working.
I have narrowed this down to the Value_Template.
Without the PIR sensor the output direct from the Tasmota get:
I have was not aware of this feature and have been using HA for nearly a year now, so thanks for point it out to me. I will run some tests using this tool and see if I can find out what the cause is.
Just to clarify what I meant, I can have the Temp sensor working, or I can have the PIR working separately, but when I have both configured on the Tasmota software, the PIR works but the Temp doesn’t read or display in HA at all. I can see the temp is being sent out in the console of the Tasmota. I will reply back with any advancement I get.
For anyone googling this as an issue they have - turns out it was my Max packet size in the PubSubClient!! I know this is meant to be changed, but due to using another PC to flash the NodeMCU it was missed. Its been driving me crazy!
Cheers for the replies VDRainer.
I think this emphasises the importance of having a client display the data being sent by the broker, rather than relying solely on the tasmota log files.
