I would like to share my last project.
I made 4 physical buttons with ESPHome, one for everyone in the house. I have built this into various things
These have different functions, 1x click, 2x click, …
They also have the ability to hold and dim.
The LED in the button comes on when it gets dark outside and also gives feedback about how many times the button was pressed.
This is the code for ESPHome:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "xxxxxxxxxxxx"
password: "xxxxxxxxxxxxx"
ap:
ssid: "Knop Giel Fallback Hotspot"
password: "xxxxxxxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "xxxxxxxxxxxxxx"
output:
- platform: esp8266_pwm
pin: D0
light:
- platform: monochromatic
name: "Led knop Giel"
output: redgpio
effects:
- strobe:
- flicker:
binary_sensor:
- platform: gpio
pin:
number: D5
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- OFF for at least 0.5s
then:
- binary_sensor.template.publish:
state: ON
- if:
condition:
light.is_on: licht
then:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 5s
- light.turn_off:
- light.turn_on:
else:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 5s
- light.turn_off:
- delay: 2s
state: OFF
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
state: ON
- if:
condition:
light.is_on: licht
then:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 4s
- light.turn_off:
- light.turn_on:
else:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 4s
- light.turn_off:
- delay: 2s
state: OFF
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
then:
state: ON
- if:
condition:
light.is_on: licht
then:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 3s
- light.turn_off:
- light.turn_on:
else:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 3s
- light.turn_off:
- delay: 2s
state: OFF
- timing:
- ON for at most 1s
- ON for at most 1s
then:
state: ON
- if:
condition:
light.is_on: licht
then:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 2s
- light.turn_off:
- light.turn_on:
else:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 2s
- light.turn_off:
- delay: 2s
state: OFF
- timing:
- ON for at most 1s
then:
state: ON
- if:
condition:
light.is_on: licht
then:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 1s
- light.turn_off:
- light.turn_on:
else:
- delay: 1s
- light.turn_on:
effect: strobe
- delay: 1s
- light.turn_off:
- delay: 2s
state: OFF
- timing:
- ON for at least 1.2s
then:
state: ON
- if:
condition:
light.is_on: licht
then:
- light.turn_on:
effect: flicker
- delay: 1s
- light.turn_off:
- light.turn_on:
else:
- light.turn_on:
effect: flicker
- delay: 1s
- light.turn_off:
on_release:
state: OFF
name: "Knop Giel klik"
name: "Knop Giel lange klik"
name: "Knop Giel 2 klik"
name: "Knop Giel 3 klik"
name: "Knop Giel 4 klik"
name: "Knop Giel 5 klik"
The automations for the multi_click can be found here: https://github.com/gieljnssns/My-Hassio-config/tree/master/config/automation/esp_buttons
All the code for dimming is based on this topic and can be found here as 3 packages.
