Seems like 90% of what is listed on the Blakadder Tasmota devices site has either migrated to a non-ESP SoC or isn’t available at all anymore. I managed to buy two of the Gosund WP9’s back in the halcyon days of being able to use Tuya-Convert. I wish I had bought more. Are there any power strips out there at all which support ESPhome?
Sonoff L1
Thank you, but I’m looking for a POWER strip.
Oops…
Sorry about that.
Meross has a few power strips that is ESP based I believe
I would love to know the same. Probably six months ago I went through a similar search and came up empty. Ended up getting a Kasa power strip, which does work locally in HA. Unfortunately it phones home and blocking it causes it to restart every 15 minutes or so. Not the end of the world with it not being a total random company, but one that I could easily flash with ESPHome would be ideal and is what’s stopped me from buying additional ones.
I got the Meross MSS425F which uses a MWA6S, and my (first) attempt to transplant with a ESP8685 didn’t work, but I have it on my to-do list to try soldering it again.
I’ve read, but haven’t yet verified, that the Tapo P306 power strip has ESP32-C2 inside, so that might be worth checking (please report back if you get one). I can’t find a template online so you might have to reverse engineer the relay GPIOs yourself.
I’ve personally flashed several Wyze Outdoor Plugs (ESP32) which are only two outlets each but often on sale for under $15, and fairly straightforward to flash over USB serial.
