selfmade
(Achim)
June 15, 2023, 9:40am
1
my esp restarte automaticly and i loose some Values
Logger: aioesphomeapi.connection
Source: runner.py:179
First occurred: 13. Juni 2023 um 19:13:53 (34 occurrences)
Last logged: 04:03:54
192.168.2.102: Connection error occurred: Connection requires encryption
bigbox-lightcontroller @ 192.168.2.102: Connection error occurred: [Errno 104] Connection reset by peer
watercontrol-esp32-s2-saola-1 @ 192.168.2.106: Connection error occurred: Ping response not received after 90.0 seconds
watercontrol-esp32-s2-saola-1 @ 192.168.2.106: Connection error occurred: [Errno 104] Connection reset by peer
any ideas
greetings
Achim
Without your code from this ESP node, it’s like a guessing game. Please post the code from that node, and please use a code format (see here ), it is otherwise not possible to check for errors.
But, I have a very strong feeling, that you aren’t using the mandatory encryption:
selfmade
(Achim)
June 15, 2023, 3:14pm
3
ok thank you for the tip
there is the code
ubstitutions:
devicename: bigbox-lightcontroller
board: esp32-s2-saola-1
upper_devicename: ESP32_S2_BigBox_LightController
device_location: Kueche
device_description: BigBox Lichtsteuerung platform using ESPhome firmware
ipaddress: 192.168.2.102
last_update: "2023-06-04 22:54:12"
esphome:
comment: lightcontroller
includes: []
libraries: []
build_path: bigbox-lightcontroller
platformio_options: {}
esp32:
framework:
type: arduino
logger:
#level: VERY_VERBOSE
#tx_buffer_size: 1024
api:
encryption:
key: !secret ESPHOME_API_KEY
ota:
safe_mode: true
password: !secret HA_OTA_PASSWORD
# none... wurde auf light.... geändert 04.06.2023
wifi:
power_save_mode: light # none (default for esp8266), light (default for esp32), high
ssid: !secret WLAN_ASUS_SSID
password: !secret WLAN_ASUS_PASSWORD
manual_ip:
static_ip: !secret ESP32_S2_BIGBOX_LIGHT_IP
gateway: !secret WLAN_ASUS_GATEWAY_IP
subnet: !secret WLAN_ASUS_SUBNET
dns1: !secret WLAN_ASUS_DNS1
ap:
ssid: "Bigbox-Lightcontrol"
password: !secret WIFI_AP_PASSWORD
web_server:
port: 80
auth:
username: admin
password: admin
# Sensoren am I2C Bus
i2c:
sda: GPIO8
scl: GPIO9
scan: true
# Analog cd74hc4067 16 Channel Mux
cd74hc4067:
- id: cd74hc4067_1
pin_s0: GPIO12
pin_s1: GPIO13
pin_s2: GPIO14
pin_s3: GPIO15
dallas:
- pin: GPIO16
update_interval: 120s
- pin: GPIO17
# pin-out
# GPIO1 PWM1 led_panel1_GPIO1 3000K
# GPIO2 PWM2 led_panel2_GPIO2 3000K
# GPIO3 PWM3 LED_4000K1_GPIO3
# GPIO4 PWM4 LED_4000K2_GPIO4
# GPIO5 PWM5 LED_660nm_1_GPIO5
# GPIO6 PWM6 LED_660nm_2_GPIO6
# GPIO7 PWM7 LED_730nm_GPIO7
# GPIO8 SDA I2C
# GPIO9 SCL I2C
# GPIO10 adc Aanalog_mux-sig-pin
# GPIO11 PWM8 PANEL_12V_FAN_GPIO11
# GPIO12 Aanalog Mux Address S0
# GPIO13 Analog Mux Address S1
# GPIO14 Aanalog Mux Address S2
# GPIO15 Aanalog Mux Address S3
# GPIO16 1-wire hub_1
# GPIO17 1-wire hub_2
# GPIO33 LED-Panel_1 3000K Switch N-Fet
# GPIO34 LED-Panel_2 3000K Switch N-Fet
# GPIO35 Fan LedPanel Switch N-Fet
# GPIO36 Fan Controller Box Switch N-Fet
output:
- platform: ledc
pin: GPIO1
channel: 0 # ist ok
inverted: True # 0 = volllast 255= aus
frequency: 1000 Hz # default 490Hz
- platform: ledc
pin: GPIO2
channel: 1 # ist ok
frequency: 1000 Hz
- platform: ledc
pin: GPIO3
channel: 2 # ist ok
frequency: 1000 Hz
- platform: ledc
pin: GPIO4
channel: 3 # ist nicht ok. flackert wenn auf Channel 1 oder 2
frequency: 1000 Hz
- platform: ledc
pin: GPIO5
channel: 4 # ist nicht ok, flackert wenn on und lässt sogar noch die LED's an led_4000k_p1_gpio3 leicht mit flackern
frequency: 1000 Hz
- platform: ledc
pin: GPIO6
channel: 4 # ist ok
frequency: 1000 Hz
- platform: ledc
pin: GPIO7
channel: 6
frequency: 1000 Hz
id: led_660nm_p2_gpio7 # ist ok flackert nicht und stört keine anderen Kanäle
#- platform: ledc
# pin: GPIO11
# channel: 7
# frequency: "4096Hz"
# id: PANEL_12V_FAN_GPIO11
# hub_2 0x1b00000df723ec28
#[21:46:43][D][dallas.sensor:084]: hub_1 0x3f00000df6546028
#[21:46:43][D][dallas.sensor:084]: hub_1 0x3100000df746fa28
- platform: internal_temperature
name: "ESP32-S2-Saola_1R Temperatur"
- platform: dallas
address: 0x3100000df746fa28
dallas_id: hub_1
name: "Uc Box StepDown"
- platform: dallas
address: 0x3f00000df6546028
dallas_id: hub_1
- platform: dallas
address: 0x1b00000df723ec28
dallas_id: hub_2
name: "LED-Panel Temperatur"
- platform: sht4x
temperature:
name: "Temperatur am Kronendach"
humidity:
address: 0x44
update_interval: 30s
# Pimoroni BME60 Sensor
#- platform: bme680
# temperature:
# name: "Temperatur an Kronendach"
# oversampling: 16x
# filters:
# offset: -0.65
# update_interval: 12s
# pressure:
# name: " Luftdruck"
# humidity:
# name: " Luftfeuchtigkeit"
# filters:
# offset: -0.65
# gas_resistance:
# name: "Gas Luft-Gemische"
# i2c_id: bus_a
# ##iir_filter: 7x
# address: 0x77 #address: 0x77 #address: 0x76 # BME688 Piomoroni/BME680/Adafruit/BME680 Piomoroni
# BH1750 Lux/Lumen sensor
- platform: bh1750
name: "LED Lichtstärkein Lux Mitte der Pflanze:"
i2c_id: bus_a
address: 0x5C
- platform: bh1750
name: "LED Lichtstärke in LuX am Kronendach:"
i2c_id: bus_a
address: 0x23
- platform: adc
pin: GPIO10
- platform: cd74hc4067
name: "BigBox Panel-1 3000K Power"
number: 5
sensor: adc_sensor
update_interval: 300s
unit_of_measurement: "W"
accuracy_decimals: 2
device_class: "power"
filters:
- lambda: return (x * 10);
name: "BigBox Panel-2 3000K Power"
number: 4
sensor: adc_sensor
update_interval: 60s
filters:
name: "BigBox Panel-1 4000K Power"
number: 3
sensor: adc_sensor
filters:
name: "BigBox Panel-2 4000K Power"
number: 2
sensor: adc_sensor
filters:
# - lambda: "return x > 0.001 ? x * 56221 : 0;"
name: "BigBox Panel-1 660nm Power"
number: 1
sensor: adc_sensor
filters:
#- lambda: "return x > 0.001 ? x * 56221 : 0;"
name: "BigBox Panel-2 660nm Power"
number: 0
sensor: adc_sensor
filters:
# - platform: cd74hc4067
# id: Panel_1und2_730nm
# name: "BigBox Panel-1und2 730 Power"
# number: 6
# sensor: adc_sensor
# update_interval: 60s
# unit_of_measurement: "W"
# device_class: "power"
# filters:
# #- lambda: "return x > 0.001 ? x * 56221 : 0;"
# - lambda: return (x * 10);
# id: Panel_1und2_840nm
# name: "BigBox Panel-1und2840 Power"
# number: 6
# filters:
light:
- platform: monochromatic
name: "LED Panel 1 3000K 1000Hz"
output: led_panel1_GPIO1
gamma_correct: 1.0
name: "LED Panel 2 3000K 1000Hz"
output: led_panel2_GPIO2
gamma_correct: 1.0
name: "LED 4000K P1"
output: led_4000k_p1_gpio3
#gamma_correct: 1.0
name: "LED 4000K P2"
output: led_4000k_p2_gpio4
#gamma_correct: 1.0
name: "LED 660nm P1"
output: led_660nm_p1_gpio5
#gamma_correct: 1.0
name: "LED FarRed 730nm"
output: farred_730nm_gpio6
#gamma_correct: 1.0
name: "LED 660nm P2"
output: led_660nm_p2_gpio7
#gamma_correct: 1.0
#- platform: monochromatic
# name: "Panel 12V Fan 33600Hz"
# output: PANEL_12V_FAN_GPIO11
switch:
- platform: gpio
pin: GPIO33
inverted: true
name: "Led Panel 1 3000K GPIO33"
- platform: gpio
pin: GPIO34
inverted: true
name: "Led Panel 2 3000K GPIO34"
- platform: gpio
pin: GPIO35
name: "Fan LedPanel GPIO35"
- platform: gpio
pin: GPIO37 # 36 only 1.34V
name: "Fan Controller Box GPIO37"
edit:
what i see now.
i change only the power_safe_mode
i’m not sure if is that a problem
