ESP Timer reporting to HA
Hi I am hoping someone can help.
I have setup a irrigation controller and am using a script with delays to open and close the valves with relays.
I want the controller to be independent of HA, so I have a service that is exposed in HA which in turn will run the script for the watering schedule.
I am looking for a way to display.report the delay timer as it counts down for each zone in HA. is this possible.
substitutions:
  node_name: irrigation_1
  friendly_node_name: Irrigation Controller 1
  log_level: DEBUG
packages:
  device_base: !include common/device_base.yaml
api:
  services:
    - service: all_zones_water
      then:
        - script.execute: all_zones
    - service: all_zones_stop
      then:
        - script.stop: all_zones
        - logger.log: "Watering Stopped"
        - switch.turn_off: ${node_name}_zone_1
        - switch.turn_off: ${node_name}_zone_2
        - switch.turn_off: ${node_name}_zone_3
        - switch.turn_off: ${node_name}_zone_4
script:
  - id: all_zones
    mode: single
    then:
      - switch.turn_on:
      - delay: !lambda 'return id(zone_1_duration).state * 60000;'
      - switch.turn_on:
      - delay: !lambda 'return id(zone_2_duration).state * 60000;'
      - switch.turn_on:
      - delay: !lambda 'return id(zone_3_duration).state * 60000;'
      - switch.turn_on:
      - delay: !lambda 'return id(zone_4_duration).state * 60000;'
      - switch.turn_off:
 - platform: homeassistant
   name: Zone 1 Duration
   entity_id: input_number.irrigation_1_zone_1
   name: Zone 2 Duration
   entity_id: input_number.irrigation_1_zone_2
   name: Zone 3 Duration
   entity_id: input_number.irrigation_1_zone_3
   name: Zone 4 Duration
   entity_id: input_number.irrigation_1_zone_4
   entity_id: input_number.irrigation_1_max_time
switch:
  # Zone 1
  - platform: gpio
    pin:
      number: 12
      inverted: no
    name: ${friendly_node_name} - Zone 1
    interlock: ['${node_name}_zone_2', '${node_name}_zone_3', '${node_name}_zone_4']
    restore_mode: ALWAYS_OFF
    icon: mdi:water
    # Zone 2
  - platform: gpio
    pin:
      number: 5
      inverted: yes
    name: ${friendly_node_name} - Zone 2
    interlock: ['${node_name}_zone_1', '${node_name}_zone_3', '${node_name}_zone_4']
    icon: mdi:water
    # Zone 3
  - platform: gpio
    pin:
      number: 4
      inverted: yes
    name: ${friendly_node_name} - Zone 3
    interlock: ['${node_name}_zone_1', '${node_name}_zone_2', '${node_name}_zone_4']
    icon: mdi:water
    # Zone 4
  - platform: gpio
    pin:
      number: 15
      inverted: yes
    name: ${friendly_node_name} - Zone 4
    interlock: ['${node_name}_zone_1', '${node_name}_zone_2', '${node_name}_zone_3']
    icon: mdi:water
