i’d like to send data from an ESP32 to a public mqtt broker. In my case to flexpi.
On the flexpi panel I can see that I’m connected with the ESP, but no values of the sensor appears in the flexpi panel. Have I set up anything else in my config that tells the sensor to talk to the mqtt broker? I read something about mqtt publish??? Sorry for my stupid questions…
Perhaps soemane can give me an example?
Thank you
My configuration:
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: "xxx"
password: "xxx"
ap:
ssid: "Brunnen Fallback Hotspot"
password: "xxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
#api:
mqtt:
broker: mqtt.flespi.io
username: mypersonaltoken
ota:
- platform: ultrasonic
trigger_pin: GPIO18
echo_pin: GPIO19
update_interval: 2000ms
