I have just updated my ESP 32 boards (HASS) and two of my DHT22’s have now dropped to minus numbers (Only 2 out of four)
Have anybody experienced this or know the fix?
Fixed:
Re-installed the existing config and this seems to have resolved the issue.
Also make sure you have specified it is a DHT22 using model:
or it may happen again - this is a known issue.
Is this in the sensor yaml file?
Currently I have;
- platform: dht
pin: GPIO27
temperature:
name: "Garage Temperature"
humidity:
name: "Garage Humidity"
update_interval: 60s```
As per: DHT Temperature+Humidity Sensor — ESPHome
- model (Optional, int): Manually specify the DHT model, can be one of
AUTO_DETECT
,DHT11
,DHT22
,DHT22_TYPE2
,AM2302
,RHT03
,SI7021
and helps with some connection issues. Defaults toAUTO_DETECT
. Auto detection doesn’t work for the SI7021 chip.
Ah brilliant thank you.
I had used the template above but not really looked at the optional one as much so thanks for pointing that out!
