Hi, i’m tring to use a esp01 with deep sleep and wake it up when the pin changes (door sensor). I modified my esp01 like this https://www.instructables.com/Enable-DeepSleep-on-an-ESP8266-01/ so it should wake up right? i was using it before for another door sensor that i made with arduino ide and it was wakeing up (if i rembember correct…)
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: ""
password: ""
ap:
ssid: ""
password: ""
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
deep_sleep:
run_duration: 2min
sleep_duration: 2min
wakeup_pin: 0
- platform: adc
pin: VCC
internal: true
unit_of_measurement: '%'
update_interval: 40s
lambda: |-
return ((id(VCC).state /3.30) * 100.00);
binary_sensor:
- platform: gpio
pin:
number: 0
mode: INPUT
device_class: door
the problem i have is that esphome shows me a error on line " wakeup_pin: 0" because its only for esp32…but it should work if i modified the chip, or i m wrong?
the code without " wakeup_pin: 0" is working but its only sending pin state if its awake, if its sleeping it does nothing.
thanks in advance!
