ESP32 a1s Audio kit for voice assistant
Hi folks
I really want to get started with voice but the atom echos are out of stock
but a do have a couple of esp32 A1-s audio kits I played with as players
They have two built in mics is there a how-to implement these in esphome?
Also there is sample code here
I’ve got it working as a media server but can’t get the internal mic anyone know what i2s gpio pin the internal mic is on ?
Found a post saying gpio 35 but voice to text not hearing anything
This it my config any ideas on getting mic working
esphome:
friendly_name: esp32 media
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
password: “xxxxxxxxxxxxxxxxxxxxxxxxx”
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Esp32-Media Fallback Hotspot"
password: "eAoRUxEpjcxZ"
captive_portal:
i2c:
sda: GPIO33
scl: GPIO32
external_components:
  • source: github://pr#3552
    components: [es8388]
    refresh: 0s
es8388:
media_player:
  • platform: i2s_audio
    name: “ESP32 Audio Kit”
    i2s_dout_pin: GPIO26
    dac_type: external
    mode: stereo
i2s_audio:
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO27
microphone:
    i2s_din_pin: GPIO35
switch:
  • platform: gpio
    pin: GPIO21
    restore_mode: ALWAYS_ON
voice_assistant:
microphone: mic1
binary_sensor:
  • platform: gpio
    pin:
    number: GPIO39
    inverted: true
    mode:
    input: true
  • platform: gpio
    pin:
    number: GPIO036
    inverted: true
    filters:
    • delayed_off: 10ms
  • platform: gpio
    pin:
    number: GPIO013
    inverted: true
    filters:
    • delayed_off: 10ms
  • platform: gpio
    pin:
    number: GPIO019
    inverted: true
    filters:
    • delayed_off: 10ms
  • platform: gpio
    pin:
    number: GPIO023
    inverted: true
    mode:
    input: true
    pullup: true
    filters:
    • delayed_off: 10ms
  • platform: gpio
    pin:
    number: GPIO018
    inverted: true
    mode:
    input: true
    pullup: true
    filters:
    • delayed_off: 10ms
  • platform: gpio
    pin:
    number: GPIO005
    inverted: true
    mode:
    input: true
    pullup: true
    filters:
    • delayed_off: 10ms
    on_press:
    • voice_assistant.start:
    on_release:
    • voice_assistant.stop:
light:
  • platform: binary
    name: “Test LED 1”
    output: light_output_1
  • platform: binary
    name: “Test LED 2”
    output: light_output_2
output:
  • id: light_output_1
    platform: gpio
    pin: GPIO22
    inverted: true
  • id: light_output_2
    platform: gpio
    pin: GPIO19
    inverted: true
Please post your yaml as yaml, not as markup.
Use three backticks ``` before and after your code, on separate lines. That way you will maintain proper formatting.
esphome:
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxx"
wifi:
  ap:
    password: "xxxxxxxx"
captive_portal:
i2c:
  sda: GPIO33
  scl: GPIO32
  - source: github://pr#3552
    refresh: 0s
es8388:
media_player:
  - platform: i2s_audio
    dac_type: external
    mode: stereo
i2s_audio:
microphone:
    i2s_din_pin: GPIO35
switch:
  - platform: gpio
    pin: GPIO21
voice_assistant:
  microphone: mic1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin:
      number: GPIO036
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO013
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO019
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO023
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO018
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO005
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
     - delayed_off: 10ms
    on_press:
      - voice_assistant.start:
    on_release:
      - voice_assistant.stop:
    on_click:
      - media_player.toggle: AudioKit
light:
  - platform: binary
    name: "Test LED 1"
  - platform: binary
    name: "Test LED 2"
output:
  - id: light_output_1
    platform: gpio
    pin: GPIO22
    inverted: true
  - id: light_output_2
    platform: gpio
    pin: GPIO19
    inverted: true
Thanks hopefully its readable now, the board works as a media player when I press to talk can see the voice assistant start but it nothing appears to be heard and if I try more then once get white noise on the speakers
this is the type of board im using but did not buy from this seller
https://www.aliexpress.com/item/1005005368093317.html?spm=a2g0o.productlist.main.3.614f67b5XVARuf&algo_pvid=bb3f6c66-435f-4069-b423-d3bc96a909f9&aem_p4p_detail=202305090644149109631710612800000688722&algo_exp_id=bb3f6c66-435f-4069-b423-d3bc96a909f9-1&pdp_npi=3%40dis!GBP!15.72!13.36!!!!!%402100bbf516836398544076152d0745!12000032764208224!sea!UK!0&curPageLogUid=3AwvG6HwKRNT&ad_pvid=202305090644149109631710612800000688722_2&ad_pvid=202305090644149109631710612800000688722_2
Figure 7 of the ESP32-A1S datasheet shows the ES_I2S_DSDIN signal connected to GPIO26 This is the same pin as the media_player pin, might be bidirectional or just rx/tx convention? Maybe try with both set to 26 or just the microphone to see if you can get it working separately.
There is also a signal marked ES_I2S_ADSDOUT connected to the ES8388. This connects to physical pin #11, which looks to be GPIO35 which would agree with reference to prior post.
If you look at the PR3552 code and discussion, there are some i2c commands sent to the ES8388 chip for configuration during setup. This might just setup the DAC and not the MIC. Adding some i2c to get the mic configured to what esphome expects might be necessary.
Thanks for the input I tried GPIO 26 and this didn’t make any difference so put it back to 35, think you are correct that something additional is needed to bring the mics online I saw that the folks with ESPMuse lux were having a similar issue tried their solution but didn’t help latest code below
esphome:
esp32:
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key: "xxx"
ota:
  password: "xxxx"
wifi:
  ap:
    password: "xxxxx"
captive_portal:
i2c:
  sda: GPIO33
  scl: GPIO32
    refresh: 0s
  - source: github://pr#4775
    components: [adc, i2s_audio, microphone]
    refresh: 0s
es8388:
media_player:
    i2s_dout_pin: GPIO35
    dac_type: external
    mode: stereo
i2s_audio:
microphone:
    i2s_din_pin: GPIO26
    adc_type: external
    pdm: false
switch:
  - platform: gpio
    pin: GPIO21
voice_assistant:
  microphone: mic1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin:
      number: GPIO036
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO013
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO019
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO023
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO018
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO005
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
     - delayed_off: 10ms
    on_press:
    on_release:
    on_click:
light:
  - platform: binary
    name: "Test LED 1"
  - platform: binary
    name: "Test LED 2"
output:
    platform: gpio
    pin: GPIO22
    inverted: true
    platform: gpio
    pin: GPIO19
    inverted: true
Wish I had somthing constructive to add but I’m stuck at this point as well.
Everything working except microphones.
Board:
JESSINIE ESP32 Audio Kit ESP32 WiFi Bluetooth Module ESP32-A1S Module Audio Development Board BLE Low Power Dual-core 64Mb Serial Adapter Port to WiFi Board
ESP32 Audio Kit V2.2 A221
can you share the code you used?
its posted in this thread see post 10
esphome:
esp32:
  framework:
    type: arduino
logger:
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxxx"
wifi:
  ap:
    ssid: "esp32-audio-kit Fallback Hotspot"
    password: "xxxxxxxxxxxxxxxxxxxx"
captive_portal:
web_server:
  port: 80
i2c:
  sda: GPIO33
  scl: GPIO32
    refresh: 0s
    refresh: 0s
es8388:
media_player:
    dac_type: external
    mode: stereo
i2s_audio:
microphone:
    i2s_din_pin: GPIO35
    adc_type: external
    pdm: false
switch:
  - platform: gpio
    pin: GPIO21
voice_assistant:
  microphone: mic1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin:
      number: GPIO036
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO013
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO019
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO023
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO018
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO005
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
     - delayed_off: 10ms
    on_press:
    on_release:
    on_click:
light:
  - platform: binary
    name: "Test LED 1"
  - platform: binary
    name: "Test LED 2"
output:
    platform: gpio
    pin: GPIO22
    inverted: true
    platform: gpio
    pin: GPIO19
    inverted: true
Any luck getting the ESP audio kit working?
Everything but the microphone.
Hi, I got the ESP32-A1S audio kit microphone working, but it is not straightforward … this is still under development in the es8388 driver support:
https://github.com/esphome/esphome/pull/3552#issuecomment-1556031035
Please report your boards configurations to check how many of you have capacitors placed in the wrong positions !
I just received your exact same board (ESP32 Audio Kit V2.2 A247) and the capacitors are in the lowest position and the second from last positions are empty. So I will move them tomorrow night and test out the code. Thanks for the work.
Same here. I got one move okay but then tweezers flicked the other across the room. Looks like they were 140nF 0402 package.
my dog ate my electronics?
