ESP32-A1S Audio Kit Media Player
I recently picked up a couple of ESP32-A1S Audio Kits from Amazon and have been playing with them for a bit. I figure it might be helpful if someone condensed some of the information about this board.
Amazon Link, AliExpress Link
If you have a 3D Printer, here’s a pretty good case for you to print/modify: EdwardKrayer’s github
I am using these speakers: 8 ohm 1W speakers with JST connectors
I also picked up this battery: 3.7V 3700mAh Battery – I’m still waiting on this to arrive.
My hope is that this can be supported in ESPHome like the RaspiMuse Proto or the M5Stack Speaker Kit or at least this might be helpful for someone who wants to play with this board a bit. Hopefully this isn’t too redundant.
The A1S Audio Kit boards I have are marked V2.2 with A210 on one board and 3895 on the other. On both the A1S module has B238 printed on the back. From what I can tell, there are older boards that use a different codec and older revisions have different GPIO assignments, but this appears to be the current version and matches up with AI Thinker’s (current) spec sheets and documentation.
The ESP32-A1S Audio kit can function as a media player in ESPhome, but only using the internal speakers. Headphone jacks don’t seem to output audio. If you’ve got some little speakers to attach to the JST connectors, this config will work (Thanks to @egwent @ra.jeevan and @hareeshmu for the help with this):
esphome:
esp32:
  board: esp-wrover-kit
  framework:
    type: arduino
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "ssid"
    password: "pass"
captive_portal:
i2c:
  sda: GPIO33
  scl: GPIO32
external_components:
  - source: github://pr#3552
    components: [es8388]
    refresh: 0s
es8388:
media_player:
  - platform: i2s_audio
    name: "ESP32 Audio Kit"
    i2s_lrclk_pin: GPIO25
    i2s_dout_pin: GPIO26
    i2s_bclk_pin: GPIO27
    dac_type: external
    mode: stereo
switch:
  - platform: gpio
    pin: GPIO21
    restore_mode: ALWAYS_ON
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
  - platform: gpio
    pin:
      number: GPIO036
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO013
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO019
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO023
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO018
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO005
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
light:
  - platform: binary
    name: "Test LED 1"
    output: light_output_1
  - platform: binary
    name: "Test LED 2"
    output: light_output_2
output:
  - id: light_output_1
    platform: gpio
    pin: GPIO22
    inverted: true
  - id: light_output_2
    platform: gpio
    pin: GPIO19
    inverted: true
The other way to get this to work in HomeAssistant is via Squeezelite-ESP32. To do that, go here:
  1. sle118’s Squeezelite-ESP32 Installer
  2. Then set up the wifi on the Squeezelite box and reboot
  3. Go to “Hardware” and under “Known Board Name” select “ESP32A1S V2.2+ Variant 1 (ES8388)”, Save, Apply, Reboot.
  4. Go to “Credits” then “Show NVS Editor” and go to the “NVS Editor” under actlrs_config: type buttons
  5. Scroll to the bottom. in the “new key” box type buttons and under “new value” type:
[{"gpio": 18,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS5"},"longpress":{"pressed":"BCTRLS_UP"}},{"gpio": 5,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS6"},"longpress":{"pressed":"BCTRLS_DOWN"}},{"gpio": 36,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS1"},"longpress":{"pressed":"BCTRLS_LEFT"}},{"gpio": 13,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS2"},"longpress":{"pressed":"BCTRLS_RIGHT"}},{"gpio": 19,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS3"},"longpress":{"pressed":"KNOB_LEFT"}},{"gpio": 23,"type": "BUTTON_LOW","pull": true,"long_press": 600,"debounce": 0,"normal": {"pressed": "BCTRLS_PS4"},"longpress":{"pressed":"KNOB_RIGHT"}}]
You can put different assignments to these as you’d like. I did it like this so every short press and every long press sends a different event to Home Assistant.
  1. At the bottom of the screen press “Commit” then press “Exit Recovery” and reboot your board.
  2. Then go to Home Assistant and add the “SlimProto Player” addon. Give it some time and then it will automagically detect and treat the board like a media_player.
  3. Key presses are passed to Home Assistant as a slimproto_event. You can use this to set up automations for key presses like so:
alias: Button 1 Short Press
description: ""
  - platform: event
    event_type: slimproto_event
    event_data:
      args:
        - button
        - preset_1.single
      entity_id: media_player.squeezelite_00000
condition: []
  - service: media_player.volume_down
    data: {}
      device_id: 00000000000000
mode: single
The Squeezelite player is pretty freaking cool and I’ve had no issues. I wish that I didn’t have to rely on service calls, but that’s a very minor gripe. Sound outputs to the speakers and to the headphone jack just fine.
If you’re having issues with keypresses, try setting your dip switches to: ON - OFF - OFF - OFF - ON.
Anyway, I hope this was helpful to someone. At the very least I hope it can encourage someone to give these cheap little boards a try.
Cool. Have you tried it as a Squeezebox client?
I currently have mine set up as a squeezebox client using my second set of instructions.
The slimproto player integration is essentially emulating a Logitech Media Server. I use my media sources in Home Assistant to play to the boxes as though it was connected to LMS.
I did try the LMS integration in HACS, so it definitely can work as a pure squeezebox, but after playing for awhile I realized Music Assistant has the same capabilities so I’m sticking with that.
Thanks for posting the configuration. It was pretty timely for me as I was working on getting a ESP32-S3-Korvo-1 setup. It has a es8311 chipset so I’ll keep that external component PR in mind.
Do the head phones work with the esphome configuration if the GPIO21 switch is turned off. The Korvo had some hardware logic to keep audio only headphone or only speaker.
On ESPHome the GPIO21 switch doesn’t seem to do anything but mute/unmute the internal speakers. Output to the headphone jacks is extremely quiet (inaudible) no matter what I do with that switch.
The only thing I can see that’s different between the squeezelite and ESPHome config is that squeezelite assigns data in and the I2C bus. (di=35, i2c=16)
4ohm 3 watt speakers are what the board was designed for.
8ohm 1 watt will work, just not as loud.
However, if you crank up the volume on a 4ohm 3watt you do get a bit of distortion.
Not so much on a 8 ohm 1 watt speaker.
Good guide/reference.
Many thanks for the manual! Did you also use the line-in and expose it to HA?
Hi All,
I know this thread is quite old already, but, I have to ask, I read everything and managed to have the ESP32-A1S working completely with mics, jack and and wake word… but, it’s worthless when trying to ask the assistant to play music because the TTS takes over while answering keeping the assistant from successfully playing the music, and… no automation can be made because there is no way to distinguish between the TTS and actual music since all the attributes remains the same (even music details). Any thoughts?
P.S I meant when using the jack (connected to speakers)
i got error when i reuse this example code :
Component media_player.i2s_audio requires component i2s_audio.
Look here
To contribute back for the initial code I received from this post. Here is a cleaned up, refined (and Aux port features) added to the ESPHome configuration. It provides automatic recognition that the Aux cable has been plugged in and then switches the audio output from the speaker to the Aux for you. In addition the choice to go from speaker to Aux is exposed and will update itself in home assistant as well. And…if you switch it in home assistant (for example if you have both speakers and Aux) it will switch it on the board (so basically you have full control of the audio output port).
Caveats are that there is a (very) tiny bit of sound that still comes out of the speakers when you switch to the aux port. Not sure why when both the DAC is switched off to those channels and the volume is set to minimum. Seems to function correctly with the aux port (when you switch back to the speakers you don’t hear anything from the attached aux out speakers). Anyway, that’s the only caveat.
Here is the code:
# ESP32-A1S V2.2 Audio Kit
substitutions:
  friendly_name: Audio Living Room
  ap_ssid: "Audio Living Room"
  encryption_key: !secret Encryption_Key_Audio_Living_Room    # Find in your secrets file
  ota_password: !secret OTA_Password_Audio_Living_Room        # Not used by everyone, but if used...move it to your secrets file
# PINS
# GPIO0     Pin in Header; RST; DTR/RTS
# GPIO02    SD_DATA0; RTS/DTR
# GPIO04    SD_DATA1
# GPIO05    Key 6
# GPIO12    Microphone Jack Detect; SD_DATA2; JT_MTDI
# GPIO13    Key 2; SD_DATA3; JT_MTCK (switchable via 1, 2 & 4)
# GPIO14    SD_CLK; JT_MTMS
# GPIO15    SD_CMD; JT_MTDO (switchable via 3 & 5)
# GPIO18    Key 5
# GPIO19    Key 3; LED5 (shared argh)
# GPIO21    Amp Shutdown (pull down default?)
# GPIO22    LED4
# GPIO23    Key 4
# GPIO25    I2S Left/Right Clock
# GPIO26    I2S Data Out
# GPIO27    I2S Background Clock
# GPIO32    SCL
# GPIO33    SDA
# GPIO35    Analog/I2S Microphone
# GPIO36    Key 1
# GPIO39    Headphones Jack Detect
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
esp32:
  framework:
    type: arduino
# Enable logging
logger:
#  level: debug
# Enable Home Assistant API
api:
  encryption:
    key: ${encryption_key}
# Allow Over-The-Air updates
ota:
- platform: esphome
  password: ${ota_password}
wifi:
  ap:
    ssid: ${ap_ssid}
captive_portal:
i2c:
  id: i2c_base            # Technically this isn't needed if you don't use in the es8388 and i2c_device components. Usually it's only defined if you have more than one I2C bus and need to differentiate.
  sda: GPIO33
  scl: GPIO32
  #scan: true             # My scan results in just the 0x10 device which is the es8388. If you somehow add I2C devices you can remark this back out to scan the bus.
i2s_audio:
  - id: i2s_audio_bus
#audio_dac:
#  - platform: ES8388     # ESPHome currently (01-09-2025) supports only ES8311 and AIC3204 (not sure how similar an ES8311 is to an ES8388), if they do ever support it directly...this is where it would go
# ES8388 low power low cost audio codec
    refresh: 0s
es8388:
  i2c_id: i2c_base
  #address: 0x10
# Let the es8388 module above do the heavy lifting (setup, etc). Then create a custom I2C device (to the es8388 chip) for local control.
i2c_device:
  i2c_id: i2c_base
  address: 0x10
# Most of the ESP32-A1S boards have the capacitor for the microphone placed in the wrong location (it is placed for the I2S microphone even though the analog microphones have been soldered in place)
# Before remarking out the below and using it (in voice assistant for example), you will need to switch those capacitors or figure out a way to activate the line-in port
#microphone:
#  - platform: i2s_audio
#    id: media_mic
#    i2s_din_pin: GPIO35
#    adc_type: external
#    pdm: false
media_player:
    name: None  #"ESP32 Audio Kit"
    dac_type: external
    mode: stereo
#    mute_pin:
#      number: GPIO21
#      inverted: true
# NOTE: This lambda would be MUCH easier if defined in a function in a .h file and then just called here with the I2C component.
# But for making this readily shareable so someone can just copy/paste this into their own project it is done here.
# If you know how to move this code into it's own .h file I would recommend that just for clean/clear code
switch:
    restore_mode: RESTORE_DEFAULT_OFF
    optimistic: True
    on_turn_on:       # Turn on Line 2 (Aux), turn off Line 1 (Speakers)
      - lambda: !lambda |-
          const uint8_t output_cmd = 0x0C;      // DAC turn on Line 2, turn off Line 1
          const uint8_t unmute_cmd = 0x00;
          const uint8_t mute_cmd = 0x04;
          const uint8_t volume_min_cmd = 0x00;
          const uint8_t volume_max_cmd = 0x1C;
          // Registers
          const uint8_t Power_Reg = 0x04;
          const uint8_t Control3_Reg = 0x19;
          // I2C Pointer to local I2C es8388 component
          i2c::I2CDevice* pI2C = id(local_es8388);
          // Mute (prevent popping?)
          pI2C->write_byte(Control3_Reg, mute_cmd);
          // Line 1 DAC volume min...probably not necessary, but since we are turning line 2 to max, might as well turn line 1 down
          pI2C->write_byte(0x2E, volume_min_cmd);
          pI2C->write_byte(0x2F, volume_min_cmd);
          pI2C->write_byte(Power_Reg, output_cmd);
          // Line 2 DAC volume max...this is not done in the base es8388 initialization so we need to do it here
          pI2C->write_byte(0x30, volume_max_cmd);
          pI2C->write_byte(0x31, volume_max_cmd);
          // Unmute
          pI2C->write_byte(Control3_Reg, unmute_cmd);
    on_turn_off:      # Turn on Line 1 (Speakers), turn off Line 2 (Aux)
          const uint8_t output_cmd = 0x30;      // DAC turn on Line 2, turn off Line 1
          // Registers
          // Line 2 DAC volume min...probably not necessary, but since we are turning line 1 to max, might as well turn line 2 down
          pI2C->write_byte(0x30, volume_min_cmd);
          pI2C->write_byte(0x31, volume_min_cmd);
          // Line 1 DAC volume max...since we turn it down in the on_turn_on event above we need to turn it back to max here
          pI2C->write_byte(0x2E, volume_max_cmd);
          pI2C->write_byte(0x2F, volume_max_cmd);
          // Unmute
# NOTE: Mute didn't work in the media player??
# This normally should be pulled into the media player via the [mute_pin] section in the [media_player] block
# If you want to control it as a separate switch, unremark the below 4 lines and remark out the [mute_pin] section in the [media_player] block
  - platform: gpio
    pin: GPIO21
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
      mode:
        input: true
#   Writing directly to the es8388 in on_state could be done, but then the Aux Output wouldn't get updated.
#   By calling the state of the Aux Output with the state of the headphone jack instead, we can do both where
#   we switch automatically but allow changing back and forth if the headphone's remain plugged in (and the aux_output remains in sync).
#   If you DON'T want automatic switching when aux is plugged in, remark out the below 3 lines
    on_state:
          id(aux_output).publish_state(id(headphone_jack_status).state);
# If you need to know when the microphone jack is plugged in...
#  - platform: gpio
#    pin:
#      number: GPIO12
#      inverted: true
#      mode:
#        input: true
#        pulldown: true
#    name: "Microphone Jack"
  - platform: gpio
    pin:
      number: GPIO36
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO13
      inverted: true
    name: "Key 2"           # DIP switch 1 & 2 MUST be in the ON position to get Key2 to function correctly. Otherwise it just seems to always report pressed.
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO19
      inverted: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO23
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO18
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO5
      inverted: true
      mode:
        input: true
        pullup: true
    filters:
      - delayed_off: 10ms
light:
# LED 4 is described as a 'status_led' which allows it to double as a status led and a light led when not in an error/warning state.
# Change platform to binary and add to the [output] block, like the LED 5 example, if you don't want it doubling as a status LED
  - platform: status_led
    pin:
      number: GPIO22
      inverted: true
# LED 5 is shared with Key 3. Unfortunately you cannot use both here since ESPHome will complain that GPIO19 has already been used!! So you need to choose between Key 3 OR LED 5.
# IF you want to use LED 5, unremark the below stuff...
#  - platform: binary
#    name: "LED 5"
#    output: led_5
#output:
#  - id: led_5
#    platform: gpio
#    pin: GPIO19
#    inverted: true
# Debugging/Status stuff... set 'disabled_by_default: true' if you don't want these showing up by default, remark/delete out to remove entirely
debug:
  update_interval: 5s
  - platform: wifi_signal           # WiFi signal strength in dB; NOTE: This is needed if you want the WiFi signal strength in % variable below to be available.
    update_interval: 60s
    #disabled_by_default: true
  - platform: copy                  # Reports the above WiFi signal strength in %
    source_id: wifi_signal_db
    name: "WiFi Signal Strength"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: " %"
    entity_category: "diagnostic"
    device_class: ""
  - platform: uptime                # Seconds since last boot
    disabled_by_default: false
    force_update: false
    unit_of_measurement: s
    icon: mdi:timer-outline
    accuracy_decimals: 0
    device_class: duration
    state_class: total_increasing
    entity_category: diagnostic
#  - platform: debug
#    free:
#      name: "Heap Free"
#      #disabled_by_default: true
#    fragmentation:                 # Only available on ESP8266
#      name: "Heap Fragmentation"
#    block:
#      name: "Heap Max Block"
#    loop_time:
#      name: "Loop Time"
#    psram:                         # Only available on ESP32
#      name: "Free PSRAM"
text_sensor:
  - platform: wifi_info
    ip_address:
      icon: "mdi:ip-outline"
    ssid:
      icon: "mdi:wifi-settings"
    bssid:
    mac_address:
      icon: "mdi:network-outline"
    scan_results:
      icon: "mdi:wifi-refresh"
      disabled_by_default: true   # This is just here...because it can be, so disable by default since you don't want this running all the time!
  - platform: version
    hide_timestamp: true
    icon: mdi:new-box
#  - platform: debug
#    device:
#      name: "Device Info"
#    reset_reason:
#      name: "Reset Reason"
If you take the Aux out and plug it into a nice active 2.1 ‘computer’ speaker system (‘computer’ since they always have the Aux in port) you can have yourself a cheap (depending on the speakers) media player. I have 3 of these hooked up to 300W systems.
Although not really a caveat, I did notice these boards are sensitive to power supply noise. To many power supplies are switching and I’m pretty sure I can hear it when I turn it up high. If the volume is at mid range though I don’t hear it. Just thought I would note this if you get the board and hear the noise and think it’s a bad board…use the battery port and run it from a battery (to see for sure) or a known clean power supply before giving up.
I am using your code, jack connection works nice but I do not have sound through the speakers, no matter the AMP switch position. Any advice? Thanks in advance!
The ‘AMP Switch’ is technically a ‘Mute’ switch…but, because the player didn’t respond to the Player Mute directly and since the documents for the ES8388 module show it as the amplifier switch I chose to keep it that way (from the original code I got that is). Anyway, the Amp switch is only effective for the attached speaker and not for the audio output (via the 1/8" audio/headphone jack). The ‘Aux Output’ switch is what controls the audio out through either the attached speaker or through the headphone jack. When ‘Aux Output’ is off, sound goes through the attached speaker (which then requires the ‘Amp’ switch to be On otherwise the sound is muted). When ‘Aux Output’ is on, sound goes through the headphone jack. When you plug in your headphone jack, the code should recognize it and automatically switch to the ‘Aux Output’. When you unplug the headphone jack, the code should recognize it and automatically switch the ‘Aux Output’ off and the ‘AMP Switch’ to on.
You didn’t really specify which speakers you are not getting sound through. So my first question is that the onboard speaker connection or speakers you are connecting via the headphone jack? Second question would then be…does the other speaker work when you pull the headphone jack out (or plug it in)?
Make sure you are not using a 4-wire Aux cable too. You need to be using a 3-wire cable (Right, Left and Ground only).
Thanks for your answer. I am using 4ohm 3watt speakers connected to the amplifiers’ ouputs. The sound is really low, hardly audible. Do you know if there is a way to raise the max volumen?
Yes,
Do a search for
and change it to
const uint8_t volume_max_cmd = 0x21; // 0x21 is true MAX at 4.5dB; 0x1F is 1.5dB; Original was 0x1C which is -3dB
Sorry, didn’t realize I hadn’t updated the code I posted in regards to volume.
In addition, I should mention that although loud…it still wasn’t loud enough for me. What I found is that HA does provide a DSP for your audio channels. Through that I was able to add additional boost to the volume. But…don’t expect a lot from the little speaker. The real volume is when you use the “Aux Out” into a full stereo system. That’s also where the DSP boost really comes out.
Anyway…let me know if that helps
Thanks for your quick answers! I just found that boards labelled as “B4 40” have a hardware problem that causes this, so it was not due to the code. In any case, I will change the code with your suggestion for the new board I ordered :slight_smile:
Hmmm…I’ll have to see what boards I have. Speaking of hardware problems, the microphone circuit is a disaster on this board and hence why I didn’t implement any code in that area (I would’ve liked to have used that as an added input from a radio such that it would’ve been easier to switch input sources - currently I use a different method for controlling a radio from HA). Do you know if the new boards fixed this issue?
Looks like they’ve added support for the es8388 DAC in ESPHome now! 2025.6.0 by jesserockz · Pull Request #9126 · esphome/esphome · GitHub
Works great, thanks!
I put volume_max_cmd = 0x21 as you suggest and can be heard loud and clear
Here is my GitHub link for the ESP32-A1S Audio Kit Media Player code that I keep updated if/when I make a change (had the modification for the volume). Since I don’t always remember that I posted the code here, it’s probably best that I provide this link here just in case. For any future visitors, it’s best to grab the code from here instead since it should always be the most current.
