I have a few different ESP32 (wroom32) dev boards and once I enable bluetooth (see config) the board connects to the wifi then spams the message below then locks up completely. I have to reboot it and it does it again.
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
[I][logger:214]: Log initialized
[C][ota:458]: There have been 2 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving preferences to flash...
[I][app:029]: Running through setup()...
[D][esp32_ble_tracker:214]: Starting scan...
[C][wifi:037]: Setting up WiFi...
[D][wifi:370]: Starting scan...
[W][airthings_wave_plus:106]: Connection in progress
[D][esp32_ble_tracker:720]: Found device A4:C1:38:B2:2E:B9 RSSI=-78
[D][esp32_ble_tracker:741]: Address Type: PUBLIC
[D][esp32_ble_tracker:743]: Name: 'ihoment_H6148_2EB9'
[D][esp32_ble_tracker:720]: Found device 2A:1F:F0:0C:8A:A6 RSSI=-95
[D][esp32_ble_tracker:741]: Address Type: RANDOM
[D][esp32_ble_tracker:720]: Found device 58:54:30:0A:FE:5E RSSI=-92
[D][esp32_ble_tracker:745]: TX Power: 2
[D][ble_client:047]: Found device at MAC address [A4:DA:32:14:90:C8]
[I][ble_client:085]: Attempting BLE connection to a4:da:32:14:90:c8
[I][airthings_wave_plus:015]: Connected successfully!
[D][wifi:385]: Found networks:
[I][wifi:429]: - 'IoT' [redacted]▂▄▆█
[D][wifi:430]: Channel: 6
[D][wifi:431]: RSSI: -69 dB
[D][wifi:430]: Channel: 1
[D][wifi:431]: RSSI: -74 dB
[D][wifi:431]: RSSI: -79 dB
[D][wifi:430]: Channel: 11
[D][wifi:431]: RSSI: -87 dB
[D][wifi:434]: - [redacted] [redacted]▂▄▆█
[I][wifi:245]: WiFi Connecting to 'IoT'...
[I][ble_client:161]: Service UUID: 0x1800
[I][ble_client:162]: start_handle: 0x1 end_handle: 0x9
[I][ble_client:341]: characteristic 0x2A00, handle 0x3, properties 0x2
[I][ble_client:341]: characteristic 0x2A01, handle 0x5, properties 0x2
[I][ble_client:341]: characteristic 0x2A04, handle 0x7, properties 0x2
[I][ble_client:341]: characteristic 0x2AC9, handle 0x9, properties 0x2
[I][ble_client:161]: Service UUID: 0x1801
[I][ble_client:162]: start_handle: 0xa end_handle: 0xa
[I][ble_client:161]: Service UUID: B42E1C08-ADE7-11E4-89D3-123B93F75CBA
[I][ble_client:162]: start_handle: 0xb end_handle: 0x16
[I][ble_client:341]: characteristic B42E2A68-ADE7-11E4-89D3-123B93F75CBA, handle 0xd, properties 0x2
[I][ble_client:341]: characteristic B42E2D06-ADE7-11E4-89D3-123B93F75CBA, handle 0x10, properties 0x2c
[I][ble_client:341]: characteristic B42E2FC2-ADE7-11E4-89D3-123B93F75CBA, handle 0x14, properties 0x10
[I][ble_client:161]: Service UUID: F000FFC0-0451-4000-B000-000000000000
[I][ble_client:162]: start_handle: 0x17 end_handle: 0x23
[I][ble_client:341]: characteristic F000FFC1-0451-4000-B000-000000000000, handle 0x19, properties 0x1c
[I][ble_client:341]: characteristic F000FFC2-0451-4000-B000-000000000000, handle 0x1d, properties 0x1c
[I][ble_client:341]: characteristic F000FFC5-0451-4000-B000-000000000000, handle 0x21, properties 0x14
[I][ble_client:161]: Service UUID: 0x180A
[I][ble_client:162]: start_handle: 0x24 end_handle: 0xffff
[I][ble_client:341]: characteristic 0x2A23, handle 0x26, properties 0x2
[I][ble_client:341]: characteristic 0x2A24, handle 0x28, properties 0x2
[I][ble_client:341]: characteristic 0x2A25, handle 0x2a, properties 0x2
[I][ble_client:341]: characteristic 0x2A26, handle 0x2c, properties 0x2
[I][ble_client:341]: characteristic 0x2A27, handle 0x2e, properties 0x2
[I][ble_client:341]: characteristic 0x2A29, handle 0x30, properties 0x2
[D][esp32_ble_tracker:720]: Found device 79:CB:33:19:CF:EE RSSI=-82
[D][airthings_wave_plus:062]: version = 1
[D][airthings_wave_plus:065]: ambient light = 137
[D][sensor:125]: 'Airthings Wave Plus Humidity': Sending state 22.50000 % with 0 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus Radon': Sending state 30.00000 Bq/m³ with 0 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus Radon Long Term': Sending state 30.00000 Bq/m³ with 0 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus Temperature': Sending state 26.20000 °C with 2 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus Pressure': Sending state 997.58002 hPa with 1 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus CO2': Sending state 550.00000 ppm with 0 decimals of accuracy
[D][sensor:125]: 'Airthings Wave Plus VOC': Sending state 50.00000 ppb with 0 decimals of accuracy
**[I][ble_client:075]: [a4:da:32:14:90:c8] Disabling BLE client.**
[D][esp32_ble_tracker:720]: Found device 27:DA:3F:F2:98:C1 RSSI=-89
[W][airthings_wave_plus:021]: Disconnected!
[W][wifi_esp32:495]: Event: Disconnected ssid='IoT' bssid=[redacted] reason='4-Way Handshake Timeout'
[W][wifi:554]: WiFi Unknown connection status 0
[D][esp32_ble_tracker:720]: Found device 0B:41:98:85:00:F8 RSSI=-100
[D][esp32_ble_tracker:720]: Found device 2A:1F:F0:0C:8A:A6 RSSI=-96
[D][esp32_ble_tracker:720]: Found device 29:B8:D7:05:8A:AC RSSI=-95
Config:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: DEBUG # Required for the tracker to show the device
# Enable Home Assistant API
api:
ota:
password: "03e1c29aa1530c50534ccce27a1b6b17"
wifi:
ssid: !secret wifi_ssid
domain: ".iot"
manual_ip:
static_ip: 192.168.5.164
gateway: 192.168.5.1
subnet: 255.255.255.0
# Enablefallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: "Airways-Ble Fallback Hotspot"
password: "S5tqpd8Zs866"
captive_portal:
- platform: airthings_wave_plus
ble_client_id: airthings01
update_interval: 5min # default
temperature:
name: "Airthings Wave Plus Temperature"
radon:
name: "Airthings Wave Plus Radon"
radon_long_term:
name: "Airthings Wave Plus Radon Long Term"
pressure:
name: "Airthings Wave Plus Pressure"
humidity:
name: "Airthings Wave Plus Humidity"
co2:
name: "Airthings Wave Plus CO2"
tvoc:
name: "Airthings Wave Plus VOC"
esp32_ble_tracker:
ble_client:
- mac_address: A4:DA:32:14:90:c8
As you can see I get a few readings from the Airthings device! However it disconnects from the wifi and locks up. Any ideas?
