Hi all,
i’m going to build an energy monitor for my house.
I am going to use an Azdelivery esp32 devkit c4, it claims to have 16 ADC
Can i attach up to 16 ct clamp?
in emontx i see they do not attach more than 4 clamps, is it only due to the lack of multiple adc?
i’ve built a prototype on a breadboard with one clamp. I’ve got several problems offsetting to zero values when no current flows.
my esp32 always read 0.007 to 0.010 corresponding to 0.5A or 10 to 20W.
[11:25:19][D][ct_clamp:038]: 'PowerMeter Quadro PT Ch 1 Current' - Raw AC Value: 0.825A after 807 different samples (2690 SPS)
[11:25:19][D][sensor:125]: 'PowerMeter Quadro PT Ch 1 Current': Sending state 17.16085 A with 4 decimals of accuracy
[11:25:19][D][sensor:125]: 'ch1_energy': Sending state 4049.96021 W with 0 decimals of accuracy
[11:25:19][D][sensor:125]: 'ch1_total_energy': Sending state 13.89269 kWh with 2 decimals of accuracy
[11:25:21][D][sensor:125]: 'adc_sensor': Sending state 0.14200 V with 2 decimals of accuracy
[11:25:21][D][ct_clamp:038]: 'PowerMeter Quadro PT Ch 1 Current' - Raw AC Value: 0.813A after 826 different samples (2753 SPS)
[11:25:21][D][sensor:125]: 'PowerMeter Quadro PT Ch 1 Current': Sending state 16.91836 A with 4 decimals of accuracy
[11:25:21][D][sensor:125]: 'ch1_energy': Sending state 3992.73193 W with 0 decimals of accuracy
[11:25:21][D][sensor:125]: 'ch1_total_energy': Sending state 13.89491 kWh with 2 decimals of accuracy
[11:25:23][D][sensor:125]: 'adc_sensor': Sending state 0.14200 V with 2 decimals of accuracy
[11:25:23][D][ct_clamp:038]: 'PowerMeter Quadro PT Ch 1 Current' - Raw AC Value: 0.851A after 843 different samples (2810 SPS)
[11:25:23][D][sensor:125]: 'PowerMeter Quadro PT Ch 1 Current': Sending state 17.71147 A with 4 decimals of accuracy
[11:25:23][D][sensor:125]: 'ch1_energy': Sending state 4179.90674 W with 0 decimals of accuracy
[11:25:23][D][sensor:125]: 'ch1_total_energy': Sending state 13.89724 kWh with 2 decimals of accuracy
I’ve already changed the power source thinking it was faulty (from an usb charger to a tenstar robot transformer from 220vac to 3.3dc, the one i will use in production to power esp from main ac).
This is how i’ve attached my esp32
and this is my config. I’m using a lamba to filter out false values.
- platform: homeassistant
entity_id: input_number.sensor_epyc_850va_input_voltage
internal: true
- platform: ct_clamp
sensor: adc_sensor
name: "${nome_esteso} Ch 1 Current"
update_interval: $update_interval
accuracy_decimals: 4
device_class: current
filters:
- calibrate_linear:
- 0.003 -> 0.0
- 0.12400 -> 2.569 #measured data
- 0.22800 -> 4.775 #measured data
- 0.31700 -> 6.620 #measured data
- 0.42300 -> 8.800 #measured data
#dati in W
on_value:
then:
- sensor.template.publish:
state: !lambda |-
if (id(ch1_current).state > 0.005) {
return (id(ch1_current).state * id(voltage).state);
} else {
return 0.0;
lambda: return {};
unit_of_measurement: W
accuracy_decimals: 0
device_class: energy
state_class: measurement
- platform: adc
pin: 36
attenuation: auto
# Energy Sensors (kWh) for HA Dashboard
- platform: total_daily_energy
power_id: ch1_energy
filters:
- multiply: 0.001
unit_of_measurement: kWh
Last question. How can i manage when the ct clamp is detached?
thanks in advance
