Hi everyone,
Maybe a really simple question but i want to do the following: i have an ESP32 with ESPHome and a BME680 sensor running. Runs great. But i have also a couple of bluetooth LYWSD03MMC sensors what i also want to readout by bluetooth. So my idea was to integrate it in one ESP32. But i can’t get it working. I thought about just adding (run pvvx firmware) the pvvx sensor lines and done. But that it’s not working. My last try is below. How could i get this working?
esphome:
platform: ESP32
board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: secret
wifi:
ssid: "secret"
password: "secret"
ap:
ssid: "secret"
password: "secret"
captive_portal:
i2c:
sda: 19
scl: 23
scan: true
bme680_bsec:
# i2c address
# Common values are:
# - 0x76
# - 0x77
# Default: 0x76
address: 0x76
# Temperature offset
# Useful if device is in enclosure and reads too high
# Default: 0
#temperature_offset: 0
# IAQ calculation mode
# Available options:
# - static (for fixed position devices)
# - mobile (for on person or other moveable devices)
# Default: static
iaq_mode: static
# Interval at which to save BSEC state
# Default: 6h
state_save_interval: 3h
- platform: bme680_bsec
temperature:
# Temperature in °C
name: "BME680 Temperature"
sample_rate: lp
filters:
- median
pressure:
# Pressure in hPa
name: "BME680 Pressure"
sample_rate: lp
filters:
- median
humidity:
# Relative humidity %
name: "BME680 Humidity"
sample_rate: lp
filters:
- median
gas_resistance:
# Gas resistance in Ω
name: "BME680 Gas Resistance"
filters:
- median
iaq:
# Indoor air quality value
filters:
- median
iaq_accuracy:
# IAQ accuracy as a numeric value of 0, 1, 2, 3
name: "BME680 Numeric IAQ Accuracy"
co2_equivalent:
# CO2 equivalent estimate in ppm
name: "BME680 CO2 Equivalent"
filters:
- median
breath_voc_equivalent:
# Volatile organic compounds equivalent estimate in ppm
name: "BME680 Breath VOC Equivalent"
filters:
- median
battery_level:
name: "PVVX Battery-Level"
battery_voltage:
name: "PVVX Battery-Voltage"
humidity1:
name: "PVVX Humidity"
mac_address: "A4:C1:38:AA:BB:CC"
platform: pvvx_mithermometer
temperature1:
name: "PVVX Temperature"
text_sensor:
iaq_accuracy:
# IAQ accuracy as a text value of Stabilizing, Uncertain, Calibrating, Calibrated
name: "BME680 IAQ Accuracy"
