They have problems conneting to Wifi. Most of the time they won’t connect at all, but every now and then they do. And even then, they react very slow (I put a switch in the sketch to toggle the onboard LED).
I’ve tried 2 different devices and they both have the same problem. I’ve also tried many different settings inside the sketch. manual_ip, power_save_mode: none, fast_connect: true/false, various board types. So far, nothing helps.
In the past I’ve used Arduino sketches on these boards, and these worked fine with Wifi.
I just got 2 fire bettle 2’s. I had it connected for short periods without any noticeable problems. There is an entry for firebeetle in the esp board type. Idk if that will make a difference.
I’ve tried the firebeetle32 board. It seems to connect a little better, but it’s hard to say. It still doesn’t work very well. The LED toggle switch is responding very slowly, it at all.
They mention someting about GPIO02. That’s the LED.
Just to be sure I’ve removed that stuff from the sketch, but it didn’t help.
I get a strong feeling that this board is just poorly supported by esphome. Am I the only one having trouble with it?
Like I said: the boards have run fine with regular Arduino sketches.
Although its is not a solution but it is a simple way to verify if the MCU wifi is having an issue
Assuming the MCU is close to your router , if possible then try to flash directly from ESPhome-flasher ( the window based ) with a ready made firmware to test the wifi ? Try to test outside HA ESPhome If the MCU is for testing only then try something like WLED . it flashes quickly and then you would have access to WIFI right away to test it
I faced same issue with one MCU and it turn out SSID had a typo error with capital letter in the SSID name
Also if you connect the MCU to ESPhome-flasher and press view log , do you see anything related to wifi ?
I know this is an old post, but for anyboby using the search function …
If you have wi-fi issues when using a module with onboard PCB antennas … do you have it on a breadboard or perfboard ?
Breadboards have metal traces internally connecting the tie points (holes); and other perfboards/protoboards also contain metal for the components to solder to. Radio signals are reflected by metal, making it harder for the board to receive and broadcast clean signals.
The easiest trick is to locate the ESP at the end of the breadboard, so that the antenna is sticking out from the end, like
