Hi everyone,
I have an ESP32 setup that includes:
- an LD2420 mmWave radar motion sensor,
- a BH1750 light sensor,
- and a push button connected to a GPIO pin.
Everything works perfectly for a few months, but then, all of a sudden, the button starts to behave erratically, it detects false presses continuously even when it’s not being touched.
The rest of the system (radar and light sensor) continues to function normally.
The button is currently connected to GPIO 11 with the internal pull-up resistor enabled, and it’s wired to close to ground when pressed.
I’ve also added a 100 ms software debounce filter, but even increasing that value doesn’t make any difference.
Originally, the button was connected to GPIO 10, but after some time it started to switch on and off and then completely stopped working, so I moved it to GPIO 11 and now it has started detecting false triggers there as well.
Below is my code. Maybe I’m missing something obvious?
esphome:
friendly_name: radar
esp32:
board: esp32-c6-devkitc-1
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
reboot_timeout: 120s
manual_ip:
static_ip: 192.168.10.105
gateway: 192.168.10.1
subnet: 255.255.255.0
# output_power: 20.4 dB
# power_save_mode: none
ap:
ssid: hotspot_radar
password: !secret hotspot_wifi_password
i2c:
sda: GPIO6
scl: GPIO7
scan: true
uart:
tx_pin: GPIO0
rx_pin: GPIO1
baud_rate: 115200
parity: NONE
stop_bits: 1
captive_portal:
ld2420:
binary_sensor:
- platform: gpio
pin:
number: GPIO11
mode:
input: true
pullup: true
inverted: true
filters:
- delayed_on: 500ms
# - delayed_off: 200ms
name: "Pulsante Luce Bagno"
- platform: ld2420
has_target:
text_sensor:
- platform: ld2420
fw_version:
- platform: ld2420
moving_distance:
name : Distanza di movimento
- platform: bh1750
i2c_id: bus_a
name: "Sensore Luminosità Bagno"
address: 0x23
update_interval: 30s
- platform: uptime
#Availabe on esp32 and not on 8266
- platform: internal_temperature
name: "Internal Temperature"
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
device_class: ""
switch:
- platform: restart
name: Riavvio nodo ESPHome
select:
- platform: ld2420
operating_mode:
name: Modalità operativa
number:
- platform: ld2420
presence_timeout:
name: Timeout di rilevazione presenza
min_gate_distance:
name: Distanza minima gate
max_gate_distance:
name: Distanza massima gate
gate_select:
still_threshold:
name: Impostazione soglia immobilità
move_threshold:
name: Impostazione soglia movimento
button:
- platform: ld2420
apply_config:
name: Applica configurazione
factory_reset:
name: Reset a impostazioni di fabbrica
restart_module:
revert_config:
name: Undo modifiche
Has anyone encountered a similar issue?
Could it be a hardware problem, GPIO wear-out, or maybe something related to the internal pull-up stability over time?
Any insights or troubleshooting tips would be greatly appreciated.
Thanks in advance!
