Esp32 c3 super mini + ld2410c Unable to read value
I tried for about 4 days until I succeeded on one on the third day.
But after running for about 26 hours, I couldn’t read the data.
Other same hardware and software couldn’t read it either.
I got a bit crashed. I need help.
My English is not very good
esphome:
  friendly_name: esp32-11
esp32:
  board: esp32-c3-devkitm-1
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "p55hLere6La5DK+d7+16NTOgWLueXYwyQqnTZL/9G6U="
ota:
  password: "12c41be6cc3446e5fa94b2f858acf1e5"
wifi:
  ssid: llong
  password: "52070304"
  ap:
    ssid: "Esp32-11 Fallback Hotspot"
    password: "3LQqldhDp4Cf"
captive_portal:
#i2c:
  #sda: 21
  #scl: 20
  #scan: true
  #id: bus_a
uart:
  tx_pin: GPIO21
  rx_pin: GPIO20
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
ld2410:
  uart_id: ld2410_uart
  throttle: 2000ms
select:
  - platform: ld2410
    distance_resolution:
      name: distance resolution
    baud_rate:
    light_function:
    out_pin_level:
      name: out pin level
button:
  - platform: ld2410
    factory_reset:
    restart:
    query_params:
number:
  - platform: ld2410
    timeout:
    max_move_distance_gate:
      name: max move distance gate
    max_still_distance_gate:
      name: max still distance gate
    g0:
      move_threshold:
        name: g0 move threshold
      still_threshold:
        name: g0 still threshold
    g1:
      move_threshold:
        name: g1 move threshold
      still_threshold:
        name: g1 still threshold
    g2:
      move_threshold:
        name: g2 move threshold
      still_threshold:
        name: g2 still threshold
    g3:
      move_threshold:
        name: g3 move threshold
      still_threshold:
        name: g3 still threshold
    g4:
      move_threshold:
        name: g4 move threshold
      still_threshold:
        name: g4 still threshold
    g5:
      move_threshold:
        name: g5 move threshold
      still_threshold:
        name: g5 still threshold
    g6:
      move_threshold:
        name: g6 move threshold
      still_threshold:
        name: g6 still threshold
    g7:
      move_threshold:
        name: g7 move threshold
      still_threshold:
        name: g7 still threshold
    g8:
      move_threshold:
        name: g8 move threshold
      still_threshold:
        name: g8 still threshold
    light_threshold:
      name: light threshold
text_sensor:
  - platform: ld2410
    version:
      name: "presenece sensor version"
    mac_address:
      name: "presenece sensor mac address"
switch:
  - platform: ld2410
    engineering_mode:
    bluetooth:
      name: control Bluetooth
  - platform: ld2410
    moving_distance:
      name: "Moving distance (cm)"
    still_distance:
      name: "Still Distance (cm)"
    moving_energy:
      name: "Move Energy (%)"
    still_energy:
      name: "Still Energy (%)"
    detection_distance:
      name: "Distance Detection (cm)"
    g0:
      move_energy:
        name: g0 move energy
      still_energy:
        name: g0 still energy
    g1:
      move_energy:
        name: g1 move energy
      still_energy:
        name: g1 still energy
    g2:
      move_energy:
        name: g2 move energy
      still_energy:
        name: g2 still energy
    g3:
      move_energy:
        name: g3 move energy
      still_energy:
        name: g3 still energy
    g4:
      move_energy:
        name: g4 move energy
      still_energy:
        name: g4 still energy
    g5:
      move_energy:
        name: g5 move energy
      still_energy:
        name: g5 still energy
    g6:
      move_energy:
        name: g6 move energy
      still_energy:
        name: g6 still energy
    g7:
      move_energy:
        name: g7 move energy
      still_energy:
        name: g7 still energy
    g8:
      move_energy:
        name: g8 move energy
      still_energy:
        name: g8 still energy
binary_sensor:
  - platform: ld2410
    has_target:
    has_moving_target:
    has_still_target:
I tried TX=RX RX=TX or TX=TX RX=RX but it doesn’t work
I also encountered a problem during this process. I was wondering if it is possible to replace the RX and TX interfaces through software without having to swap hardware? I don’t know if it is possible.
Hi
May be because of ESP board definition.
see this post:
Old thread but I thought I’d chime in. I am having success with the following UART settings.
uart:
  tx_pin: GPIO0
  rx_pin: GPIO1
  baud_rate: 256000
  parity: NONE
  stop_bits: 1
