ESP32-C6 thread-based ESPHome?
ESP32-C6 has just come out in its final mass-produced version with calibrated ADC, so is there any chance that ESPHome will sometime in the near future start to support Thread on these chips?
https://www.aliexpress.com/store/group/ESP32-C6/1100220184_40000003090971.html
There’s a good thread on the topic on the ESPHome Discord.
Search for “ESP32-C6” under the off-topic channel if that link is no good.
I had a skim and from what I could summise, there is little chance of official ESPHome support in the near future, but some individuals are making some good progress.
And there’s this feature request.
Thanks for the links.
Looks like the GitHub link is mainly for getting the ESP32-C6 to run with WiFi as the other ESP-chips.
I was hoping a bit on a Thread solution, but I will just see what I can mix up myself over the summer. :grinning:
Hey, did you found something that works?
Espressif provided it themself with the ZeroCode service.
It is a free service, that makes it easy to make Matter modules of some of the ESP boards.
Sort of a Matter version of ESPHome.
You should look at this:
ESPHome ESP32 OpenThread POC
Have you compiled thread device for the esp32c6 board? It still just shows coming soon if you select it since it was announced
I tried some GitHib repositories, which made it possible to work as a Matter device, but the code part needed for the sensor cause problems and it is currently put on pause.
I will probably not get to look at it before July, so the Zerocode might be faster. :slight_smile:
There is some progress in motion!
The new ESPHome major release, 2025.6.0, has now support for OpenThread. This means that ESPHome devices based on ESP32-C6 and -H2 can now communicate using Thread.
See ESPHome 2025.6.0 Changelog
And Matteralpha news article that puts this into context
I flashed an esp32-h2 dev board yesterday and it immediately joined my Apple Thread mesh with no issues. This was way easier than the Matter-over-Thread ZeroCode image I also tried, which refused to join the Matter controller (DCL issue, I believe). ESPHome for the win.
I suspect, but can’t be sure, that this is a routing (repeater) node, since it is line powered? (unfortunately I don’t have another device to test this with). If so, this is a $5 mesh extender. [see edit below]
Traceroute from my Mac Mini shows it’s going through one of the HomePods mini, as expected:
peter@macos % traceroute6 esphome-thread-repeater.local
traceroute6 to esphome-thread-repeater.local (fd83:e66f:f1f9:0:6bab:9e56:1541:e6d0) from fdc4:4aab:e77f:e44c:1c53:e1b9:c62a:83dd, 64 hops max, 28 byte packets
 1  fdc4:4aab:e77f:e44c:4cf:2809:9c06:5768  57.597 ms  6.986 ms  4.857 ms
 2  fd83:e66f:f1f9:0:6bab:9e56:1541:e6d0  92.205 ms  28.495 ms  27.904 ms
Edited to add: This post confirms esphome can be a router/repeater node.
