ESP32-C6 zigbee2mqtt
Hello all! I tried to look up something, but most of the post are old that’s why i decided to create a new one.
Recently i bought ESP32-C6-WROOM1-N8 boards and from what i understand they have zigbee support.
Did someone managed to connect the new esp32-c6 board with zigbee2mqtt and report sensor data?
What firmware are you running on the esp32-c6
Not exactly out of the box, but i manage to send data to z2m (at least for BME280)
Kudos to GitHub - luar123/esphome_zb_sensor: Example of a zigbee sensor in esphome
Here is my example ESPHome Yaml
esphome:
  platformio_options:
    platform: https://github.com/luar123/platform-espressif32H2/archive/refs/tags/v6.5.1.zip
  includes:
    - esphome_zb.h
    - esp_zb_light.c
    - esp_zb_light.h
esp32:
  board: esp32-c6-devkitc-1
  variant: esp32c6
  flash_size: 8MB
  partitions: partitions_zb.csv
  framework:
    type: esp-idf
    version: 5.1.2
    platform_version: 6.5.0
    source: https://github.com/tasmota/esp-idf/releases/download/v5.1.3.240313/esp-idf-v5.1.3.zip
    sdkconfig_options:
      CONFIG_ESPTOOLPY_FLASHSIZE_8MB: y
      CONFIG_ZB_ENABLED: y
      CONFIG_ZB_ZED: y
      CONFIG_ZB_RADIO_NATIVE: y
      ZB_ED_ROLE: y
external_components:
  - source: github://pr#6323
    components: [ logger ]
logger:
i2c:
   - id: bus_a
     sda: 21
     scl: 22
     scan: true
  - platform: bme280_i2c
    i2c_id: bus_a
    temperature:
      oversampling: 16x
      on_value:
        then:
          - lambda: |-
                int16_t value = (int16_t)(x*100);
                reportAttribute(ESP_ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT, ESP_ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID, &value);
    humidity:
      on_value:
        then:
          - lambda: |-
                reportAttribute(ESP_ZB_ZCL_CLUSTER_ID_REL_HUMIDITY_MEASUREMENT, ESP_ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_ID, &value);
    address: 0x76
    update_interval: 60s
custom_component:
- lambda: |-
    auto my_zb = new esphomeZB();
    return {my_zb};
  components:
  - id: zb
for me it throws an error
INFO Reading configuration config/c6-test.yaml...
WARNING The selected ESP-IDF framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
Failed config
esp32: [source config/c6-test.yaml:11]
  variant: esp32c6
  flash_size: 8MB
  Could not find file 'config/partitions_zb.csv'. Please make sure it exists (full path: /home/username/config/partitions_zb.csv).
  framework:
    type: esp-idf
    version: 5.1.2
    source: |-
    sdkconfig_options:
      CONFIG_ZB_ZED: y
      ZB_ED_ROLE: y
Create the missing file config/partitions_zb.csv
it should contain:
otadata,  data, ota,     ,        0x2000,
phy_init, data, phy,     ,        0x1000,
app0,     app,  ota_0,   ,        0x1B0000,
app1,     app,  ota_1,   ,        0x1B0000,
nvs,      data, nvs,     ,        0x6D000,
zb_storage, data, fat,   , 16K,
zb_fct,     data, fat,   , 1K,
Hi folks,
I just ordered my C6. Few days before it arrives…
In the meantime, can someone please dumb it down for me? I want to flash it with whatever is needed in order to convert it into a Zigbee gateway so I can connect some push-buttons to control stuff in Home Assistant.
So what am I actually suppose to flash it with?
It is not a zigbee gateway (whatever that is), it creates a zigbee end point.
The firmware is given in post 3. You flash it with esphome.io
Hi. I’m getting a long way through the process, but then failing here:
Compiling .pioenvs\zb-sensor\src\esphome\components\sensor\filter.o
src/esp_zb_light.c:43:10: fatal error: ha/esp_zigbee_ha_standard.h: No such file or directory
   43 | #include "ha/esp_zigbee_ha_standard.h"
compilation terminated.
*** [.pioenvs\zb-sensor\src\esp_zb_light.o] Error 1
I’m not sure where that header file is meant to come from and where I can get it.
Grateful for any assistance.
P.S. I have deactivated the logger - running like this: esphome run --no-logs zb_sensor.yaml
I was successful with this using ESPHome Device Builder 2024.12.1 in HA for a Seeed XIAO esp32-c6:
esp32:
  variant: esp32c6
  flash_size: 4MB
  framework:
    type: esp-idf
    version: 5.2.2
    source: https://github.com/tasmota/esp-idf/releases/download/v5.1.4.240712/esp-idf-v5.1.4.zip
    sdkconfig_options:
      CONFIG_ESPTOOLPY_FLASHSIZE_4MB: y
      CONFIG_ZB_ZED: y
      ZB_ED_ROLE: y
This seems to work for me. now i have to test which features / platforms work.
With esp-idf the BME680 sensor refuses to compile.
Hello everyone. I’m new here. Can someone give me the exact code for esp32c6 with ds18b20 thermometer? I’m not a programmer. I would like to add my esp32c6 as a terminal device to esphome and z2m
Hello, are you using Zigbee?
If you haven’t done any development, this is probably going to be a sharp learning curve. I did it with ZHA here. Zigbee Freezer Monitor
No, and I’m afraid that ESPHome still doesn’t feature ZigBee even though many people asked for this.
I hope you can tell me I’m wrong! :slight_smile:
luar123/zigbee_esphome: External zigbee component
Thank you @xtronets! I remember I have been using @luar123 's work before but was not aware of this project in particular. I 'll be following him her from now on :slight_smile:
So for my Seeed C6 microcontroller board, when I find the time to try to implement a ZigBee endpoint for it using ESPHome, I think I will start off by using the board config I posted before combined with the z2m example by @ ppeevPeyo and/or GitHub - luar123/esphome_zb_sensor: Example of a zigbee sensor in esphome
