Esp32 cam - after update the web server is not working
After the previous 2 updates (not sure which one), the webserver on the esp32 cam stoped working. All was fine previously; I could connect to https://:8080 without problem, and the motioneye was working using it.
After the update in Overview of HA i can see the video of the camera with entity id: camera.esp32_cam. However the stream on port 8080 is not working and i can’t find solution for it.
Here is my code:
esphome:
esp32:
  board: esp32dev
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: <key>
ota:
  - platform: esphome
    password: <password>
esp32_camera_web_server:
  - port: 8080
    mode: stream
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.0.159
    subnet: 255.255.255.0
    gateway: 192.168.0.1
  ap:
    ssid: "Esp32-Cam-Lab Fallback Hotspot"
captive_portal:
# Example configuration entry
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 8MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  resolution: 800x600
  jpeg_quality: 20
  max_framerate: 3 fps    # default: 10 fps, max 60
  idle_framerate: 1 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
output:
  - platform: gpio
    pin: GPIO4
binary_sensor:
  - platform: status
  - platform: wifi_signal
    name: "ESP32Cam WiFi Signal"
    update_interval: 30s
light:
  - platform: binary
    output: gpio_4
switch:
  - platform: restart
    name: "Esp32 Cam Reboot"
Any help would be appreciated.
thank you.
