Hi
I used esp32 cam. The connection always disconnected. you can see that from the log
How I fix it?
The esphome code
substitutions:
# Modify variables based on your settings
hostname: 'livingroomcam'
ssid: '***'
password: '***'
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid: $ssid
password: $password
fast_connect: True
api:
# reboot_timeout: 0s
ota:
logger:
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
The log
[01:03:50][C][esp32_camera:051]: External Clock: Pin:0 Frequency:20000000
[01:03:50][C][esp32_camera:052]: I2C Pins: SDA:26 SCL:27
[01:03:50][C][esp32_camera:053]: Reset Pin: -1
[01:03:50][C][esp32_camera:074]: Resolution: 640x480 (VGA)
[01:03:50][C][esp32_camera:097]: JPEG Quality: 10
[01:03:50][C][esp32_camera:099]: Contrast: 0
[01:03:50][C][esp32_camera:100]: Brightness: 0
[01:03:50][C][esp32_camera:101]: Saturation: 0
[01:03:50][C][esp32_camera:102]: Vertical Flip: ON
[01:03:50][C][esp32_camera:103]: Horizontal Mirror: ON
[01:03:50][C][esp32_camera:120]: Test Pattern: NO
[01:03:50][C][api:095]: API Server:
[01:03:50][C][api:096]: Address: livingroomcam.local:6053
[01:03:51][D][esp32_camera:157]: Got Image: len=21349
[01:04:01][D][esp32_camera:157]: Got Image: len=21268
[01:04:11][D][esp32_camera:157]: Got Image: len=21760
[01:04:23][D][esp32_camera:157]: Got Image: len=21076
[01:04:31][D][esp32_camera:157]: Got Image: len=21354
[01:04:41][D][esp32_camera:157]: Got Image: len=21309
[01:04:55][D][esp32_camera:157]: Got Image: len=21411
[01:05:01][D][esp32_camera:157]: Got Image: len=21548
[01:05:11][D][esp32_camera:157]: Got Image: len=21224
[01:05:22][D][esp32_camera:157]: Got Image: len=21219
[01:05:31][D][esp32_camera:157]: Got Image: len=21517
[01:05:44][D][esp32_camera:157]: Got Image: len=21125
[01:05:51][D][esp32_camera:157]: Got Image: len=21079
[01:06:01][D][esp32_camera:157]: Got Image: len=21045
[01:06:12][D][esp32_camera:157]: Got Image: len=20989
[01:06:21][D][esp32_camera:157]: Got Image: len=21034
[01:06:31][D][esp32_camera:157]: Got Image: len=20876
[01:06:41][D][esp32_camera:157]: Got Image: len=20750
[01:06:51][D][esp32_camera:157]: Got Image: len=20920
[01:07:04][D][esp32_camera:157]: Got Image: len=20950
[01:07:11][D][esp32_camera:157]: Got Image: len=21005
[01:07:25][D][esp32_camera:157]: Got Image: len=20868
[01:07:25][D][api:067]: Disconnecting Home Assistant 0.102.2 (192.168.1.60)
[01:07:31][D][esp32_camera:157]: Got Image: len=21101
[01:07:37][D][api.connection:583]: Client 'Home Assistant 0.102.2 (192.168.1.60)' connected successfully!
[01:07:41][D][esp32_camera:157]: Got Image: len=21003
WARNING Disconnected from API: Timeout while waiting for message response!
INFO Connecting to livingroomcam.local:6053 (192.168.1.67)
INFO Successfully connected to livingroomcam.local
[01:08:09][D][api:067]: Disconnecting Home Assistant 0.102.2 (192.168.1.60)
[01:08:12][D][esp32_camera:157]: Got Image: len=21166
[01:08:19][D][api.connection:583]: Client 'Home Assistant 0.102.2 (192.168.1.60)' connected successfully!
[01:08:23][D][esp32_camera:157]: Got Image: len=21062
[01:08:29][D][api:067]: Disconnecting Home Assistant 0.102.2 (192.168.1.60)
[01:08:31][D][esp32_camera:157]: Got Image: len=21108
[01:08:38][D][api.connection:583]: Client 'Home Assistant 0.102.2 (192.168.1.60)' connected successfully!
[01:08:42][D][esp32_camera:157]: Got Image: len=21059
[01:08:54][D][esp32_camera:157]: Got Image: len=21018
[01:08:57][D][api:067]: Disconnecting Home Assistant 0.102.2 (192.168.1.60)
[01:09:01][D][esp32_camera:157]: Got Image: len=21067
[01:09:02][D][api.connection:583]: Client 'Home Assistant 0.102.2 (192.168.1.60)' connected successfully!
