Esp32 cam door bell send photo?
hello, i have a esp32 cam for door bell , i would like when push button send a photo on ftp or email or … i have a linux server local
thank you
esphome:
  friendly_name: doorbell
esp32:
  board: esp32dev
  framework:
    type: arduino
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
  level: VERBOSE
ota:
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: 'xxxxxxxxxxxxx'
  password: 'xxxxxxxxxxxx'
  manual_ip:
    static_ip: 192.168.1.230
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Doorbell Fallback Hotspot"
    password: "Tourneur17"
captive_portal:
web_server:
  port: 80
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  resolution: 1024x768
  brightness: 2
esp32_camera_web_server:
  - port: 8080
    mode: stream
  - port: 8081
    mode: snapshot
switch:
  - platform: gpio
    pin: GPIO13
  - platform: gpio
    pin: GPIO15
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO14
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 10ms
      - delayed_off: 30s
    on_press:
      - switch.turn_on: ding
      - delay: 500ms
      - switch.turn_off: ding
      - switch.turn_on: relay
      - delay: 0.5s
      - switch.turn_off: relay
      - delay: 1s
      - delay: 0.5s
      - delay: 30s
Idk if this is the most streamlined way but, you could just fire an automation that snaps a pic, then saves that pic in HA and then use one of the many file synchronizing add ons like Samba or Syncthing to then send that file to your linux box. Im not sure of how you would attatch it to an email directly from HA. That may be possible, I dont recall seeing that and have never looked into it either.
You know that you can get HA notifications that include camera snapshots sent directly to your phone, right?
Apparently you can send emails… so, just make an automation that takes a snapshot when button is pressed, then attatch a copy of that photo to an outgoing email…
I forgot to mention that I don’t have home assistant , my server is already at maximum and I don’t want to add another
I found a code but I don’t know if it can be included and, if so, how.
ESP32-CAM remote image access via FTP. Take pictures with ESP32 and upload it via FTP making it accessible for the outisde network.
Leonardo Bispo
July - 2019
https://github.com/ldab/ESP32_FTPClient
Distributed as-is; no warranty is given.
#include "Arduino.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <ESP32_FTPClient.h>
#include "octocat.h"
#define WIFI_SSID ""
#define WIFI_PASS ""
char ftp_server[] = "";
char ftp_user[]   = "";
char ftp_pass[]   = "";
// you can pass a FTP timeout and debbug mode on the last 2 arguments
ESP32_FTPClient ftp (ftp_server,ftp_user,ftp_pass, 5000, 2);
void setup()
  Serial.begin( 115200 );
  WiFi.begin( WIFI_SSID, WIFI_PASS );
  Serial.println("Connecting Wifi...");
  while (WiFi.status() != WL_CONNECTED) {
      delay(500);
      Serial.print(".");
  Serial.println("");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());
  ftp.OpenConnection();
  // Get directory content
  ftp.InitFile("Type A");
  String list[128];
  ftp.ChangeWorkDir("/public_html/zyro/gallery_gen/");
  ftp.ContentList("", list);
  Serial.println("\nDirectory info: ");
  for(int i = 0; i < sizeof(list); i++)
    if(list[i].length() > 0)
      Serial.println(list[i]);
    else
      break;
  // Make a new directory
  ftp.MakeDir("my_new_dir");
  // Create the new file and send the image
  ftp.ChangeWorkDir("my_new_dir");
  ftp.InitFile("Type I");
  ftp.NewFile("octocat.jpg");
  ftp.WriteData( octocat_pic, sizeof(octocat_pic) );
  ftp.CloseFile();
  // Create the file new and write a string into it
  ftp.NewFile("hello_world.txt");
  ftp.Write("Hello World");
  ftp.CloseFile();
  ftp.CloseConnection();
void loop()
Would probably have to be prototyped first on the on_image event as a lambda, as image data is available in that event. Problem is that you cannot pause for so long in the lambdas.
