ESP32-CAM fails to work
Asking help with setting up an ESP32-CAM using ESPHome and MB-board. I’m able to flash and install properly, however, once installed the device is online but the camera is not streaming or showing as a sensor. The ESPHome logbook shows:
esp32cam Firmware turned off
11:49:54 PM - 6 minutes ago
esp32cam Firmaware became unavailable
Here is my esp32cam.yaml file. I’ve also tried with board as “esp32dev” but the same result.
esphome:
  friendly_name: esp32cam
esp32:
  board: esp32cam
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxx"
ota:
  password: "yyyyy"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32Cam Fallback Hotspot"
    password: "2LnKhHbzZE7E"
captive_portal:
You don’t have anything in your YAML for the camera:
I’ve never actually used one though, so I can’t help you beyond “follow the docs”.
How silly of me. Thank you!
