ESP32 Cam Fails When LED or PWM enabled
I have an AI Thinker ESP32 Cam that I’m trying to set up with ESPHome. When I include code that enables the onboard flash LED the camera stops working with these errors looping:
[W][esp32_camera:153]: Got invalid frame from camera!
[E][camera.c:495] i2s_run(): Timeout waiting for VSYNC
This yml the camera works and produces a valid picture stream:
esphome:
  platform: ESP32
  board: esp32cam
wifi:
  ssid: "ABC"
  password: "123"
output:
- platform: ledc
  pin: GPIO4
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  vertical_flip: false
  name: "Coop Cam v2"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
Likewise, just including the LED flash code works:
esphome:
  platform: ESP32
  board: esp32cam
  on_boot:
    then:
      - output.set_level:
          level: 2%
      - delay: 500ms
      - output.turn_off: flash32
wifi:
  ssid: "ABC"
  password: "123"
captive_portal:
# Enable logging
logger:
api:
ota:
But when I include the LED flash code with the camera code, I get the errors:
esphome:
  platform: ESP32
  board: esp32cam
  on_boot:
    then:
      - output.set_level:
          level: 2%
      - delay: 500ms
wifi:
  ssid: "ABC"
  password: "123"
output:
- platform: ledc
  pin: GPIO4
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  vsync_pin: GPIO25
  href_pin: GPIO23
  name: "Coop Cam v2"
captive_portal:
# Enable logging
logger:
api:
ota:
Does anyone know if there’s an issue using the onboard LED and camera at the same time?
Possibly a power issue? True a higher current supply - if you are powering via the USB port on the HA machine or your PC that can cause similar issues.
I’m using a 2.4A power supply, which I think should be more than enough? I added a 1A power supply in parallel and get the same errors.
I also can’t get other PWM components working while the camera component is present. See below for another yml, this time where I have a pwm switch component. As soon as the device boots it starts giving the same error:
yml:
esphome:
  platform: ESP32
  board: esp32cam
wifi:
  ssid: "ABC"
  password: "123"
  ap:
    ssid: "Coop Esp32 Door Fallback Hotspot"
output:
- platform: ledc
  pin: GPIO13
  frequency: "25000Hz"
- platform: ledc
  pin: GPIO2
light:
  - platform: monochromatic
    output: IN1
    restore_mode: ALWAYS_OFF
    name: "Andrew Mono Down"
    output: IN2
    name: "Andrew Mono Up"
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  vsync_pin: GPIO25
  href_pin: GPIO23
  name: "Coop Cam v2"
captive_portal:
# Enable logging
logger:
api:
ota:
Are you powering it from the 5v pins? Powering from 3.3 will be a problem.
You could also add small capacitor in the esp pins.
And in general, when the wifi is in used then ADC2 mapped pins shouldn’t be used. Might cause some stability errors.
Yes, powering from 5v.
I googled ADC2 pins and it looks like that refers to analogue to digital pins? This page seems to indicate that they’re GPIO 32-39? https://esphome.io/components/sensor/adc.html
Those are just used by the camera. There aren’t any issues using the camera while WiFi is enabled (as long as the PWM switches aren’t enabled)
GPIO 13 and 2 are part of the ADC2. Note is that might cause instability. Guess it depends on multiple items.
  • ADC2_CH0 (GPIO 4)
  • ADC2_CH1 (GPIO 0)
  • ADC2_CH2 (GPIO 2)
  • ADC2_CH3 (GPIO 15)
  • ADC2_CH4 (GPIO 13)
  • ADC2_CH5 (GPIO 12)
  • ADC2_CH6 (GPIO 14)
  • ADC2_CH7 (GPIO 27)
  • ADC2_CH8 (GPIO 25)
  • ADC2_CH9 (GPIO 26)
Ok, I’ll try other GPIO pins.
It looks like the only pins on the ESP 32 Cam available that aren’t in that list are GPIO 1, 3, and 16. I’ll need 4 total (2 for motor, 2 for endstops), but will try with just the motor first.
No luck. I switched to using GPIO 1 and GPIO 3 (instead of 2 and 13), but still same error. Even without a motor plugged in, the below yml results in [16:12:23][W][esp32_camera:153]: Got invalid frame from camera! errors every second.
I guess PWM GPIO output just doesn’t work with the camera enabled? Has anyone got this working?
esphome:
  platform: ESP32
  board: esp32cam
wifi:
  ssid: "ABC"
  password: "123"
  ap:
output:
- platform: ledc
  pin: GPIO3
- platform: ledc
  pin: GPIO1
light:
    output: IN1
    default_transition_length: 5s
    output: IN2
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  vsync_pin: GPIO25
  href_pin: GPIO23
  name: "Coop Cam v2"
captive_portal:
# Enable logging
logger:
api:
ota:
Is there anywhere I could submit this as an issue?
This is a big problem if PWM cannot be used with the ESP32 Cam in ESPHome while the camera is enabled.
@fr0zt this note explains it:
Note
Camera uses PWM timer #1. If you need PWM (via the ledc platform) you need to manually specify a channel there (with the channel: 2 parameter) on this page. I had the same issue, set the ledc channel to ‘2’ and it works.
Sample code with working PWM on the ESP32-cam Led pin, for anyone that googled this:
# Flashlight, use channel 2 for PWM, channel 1 is used by camera.
output:
  - platform: ledc
    pin: GPIO4
    channel: 2
## GPIO_4 is the flash light pin
light:
    output: gpio_4
also I made my ESP32 cam configuration public at my github:
