Hi there,
Question, I have several ESP32 cam’s. But I had to change my SSID + password in the router. Of course the cam’s aren’t connecting to the new network credentials when I only change SSID + password in the yaml file.
I’ve searched a lot on the forum but can’t find it. What do I have to do to connect the cam’s the wright way?
Do I need this:
wifi:
networks:
- ssid: 'old-ssid'
password: 'old-password'
- ssid: 'new-ssid'
password: 'new-password'
manual_ip:
static_ip: 192.168.189.16
gateway: 192.168.189.1
subnet: 255.255.255.0
dns1: 8.8.8.8
dns2: 8.8.4.4
use_address: 192.168.189.16
Or should I approach it completely differently?
Love to hear from you, been messing around for a few days
vincen
(Vincèn)
April 8, 2022, 12:44pm
2
Have you changed only SSID/pass in your router ? nothing else regarding Wifi settings or IP settings ?
Thanks for your quick response. No I have changed only SSID and password
I have the same problem, I switched to a Tenda mesh network by disabling my router’s wifi.
did you have any solution yet?
nickrout
(Nick Rout)
April 9, 2022, 9:55pm
6
Use esptool to erase the flash then reflash esphome, over the wire obviously.
hi nickrout, is there no other way?
Then I have to reconnect all my devices again.
nickrout
(Nick Rout)
April 11, 2022, 7:03am
8
If you still have access to your old AP you can change it OTA.
I can change back to old settings. but with what settings am I going to tell the devices that they have new network settings
do you have any ideas?
I did this, it didn’t work either
