I have setup an ESP32-cam anit works nicely. Still, since the board is rotated 90° in its case, the picture is also rotated. I only find the options to mirror the picture, which is nice, but I cannot find rotate.
It sounds like a case of I’m the problem, but perhaps somebody could put me in the right direction?
Thanks for the info. I can always install Motioneye OS in HA, but it bloats for just rotating a stream. I had a quick look at ffmpeg. Itight do the job but I’ll have to dig a bit into it.
Then on the image card I added the following code for rotating -90deg, obviously you could also make it 90deg or 180deg (when making 180deg, skip the margin-bottom):
thanks for this, card mod works. Unfortunately only rotates the card so when the camera is clicked on the pop-out window is still rotated wrong. Still happy the card is fixed though. Any work arounds for rotating the pop-out view of the entity?
