Esp32 cam login attempt or request with invalid authentication from
Thank you! It works perfectly but without the i2c part! I’m guessing you might have the bme sensor on yours :slight_smile:
Thanks again!
I’m using the TTGO T-Camera plus camera.
I’m gettting the following error:
[20:37:15][E][esp32_camera:091]: Setup Failed: ERROR
my config:
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: "zxc"
  password: "zxc"
  fast_connect: true
# Enable logging
logger:
  level: VERBOSE
# Enable Home Assistant API
api:
  password: "zxc"
ota:
  password: "zxc"
web_server:
  port: 80
# ttgo_camearv16 configuration
esp32_camera:
  external_clock:
    pin: GPIO04
    frequency: 20MHz
  i2c_pins:
    sda: GPIO18
    scl: GPIO23
  data_pins: [GPIO34, GPIO13, GPIO26, GPIO35, GPIO39, GPIO38, GPIO37, GPIO36]
  vsync_pin: GPIO05
  href_pin: GPIO27
  pixel_clock_pin: GPIO25
 # resolution: 800x600
 # jpeg_quality: 16
  vertical_flip: true
  horizontal_mirror: true
Hi!
Are you uploading via USB or OTA?
try adding this code on the buttom of your config and set the resolution to 640x480:
i2c:
  sda: 18
  scl: 23
  scan: False
spi:
  clk_pin: GPIO21
  mosi_pin: GPIO19
  miso_pin: GPIO22
output:
  - platform: gpio
    pin: GPIO0
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO2
I’m updating via OTA.
Tried with this code as well, no joy.
My log output looks like this:
[21:55:40][C][wifi:372]: WiFi:
[21:55:40][C][wifi:254]:   SSID: zxc
[21:55:40][C][wifi:255]:   IP Address: 192.168.2.214
[21:55:40][C][wifi:257]:   BSSID: zxc
[21:55:40][C][wifi:258]:   Hostname: 'ttgocam'
[21:55:40][C][wifi:262]:   Signal strength: -69 dB β–‚β–„β–†β–ˆ
[21:55:40][C][wifi:263]:   Channel: 1
[21:55:40][C][wifi:264]:   Subnet: 255.255.255.0
[21:55:40][C][wifi:265]:   Gateway: 192.168.2.1
[21:55:40][C][wifi:266]:   DNS1: 192.168.2.1
[21:55:40][C][wifi:267]:   DNS2: 0.0.0.0
[21:55:40][C][i2c:028]: I2C Bus:
[21:55:40][C][i2c:029]:   SDA Pin: GPIO18
[21:55:40][C][i2c:030]:   SCL Pin: GPIO23
[21:55:40][C][i2c:031]:   Frequency: 50000 Hz
[21:55:40][C][spi:096]: SPI bus:
[21:55:40][C][spi:097]:   CLK Pin: GPIO21 (Mode: OUTPUT)
[21:55:41][C][spi:098]:   MISO Pin: GPIO22 (Mode: INPUT)
[21:55:41][C][spi:099]:   MOSI Pin: GPIO19 (Mode: OUTPUT)
[21:55:41][C][gpio.output:010]: GPIO Binary Output:
[21:55:41][C][gpio.output:011]:   Pin: GPIO0 (Mode: OUTPUT)
[21:55:41][C][gpio.output:011]:   Pin: GPIO12 (Mode: OUTPUT)
[21:55:41][C][gpio.output:011]:   Pin: GPIO2 (Mode: OUTPUT)
[21:55:41][C][logger:137]: Logger:
[21:55:41][C][logger:138]:   Level: VERBOSE
[21:55:41][C][logger:139]:   Log Baud Rate: 115200
[21:55:41][C][logger:140]:   Hardware UART: UART0
[21:55:41][C][esp32_camera:043]: ESP32 Camera:
[21:55:41][C][esp32_camera:044]:   Name: My Camera
[21:55:41][C][esp32_camera:045]:   Board Has PSRAM: YES
[21:55:41][C][esp32_camera:047]:   Data Pins: D0:34 D1:13 D2:26 D3:35 D4:39 D5:38 D6:37 D7:36
[21:55:41][C][esp32_camera:048]:   VSYNC Pin: 5
[21:55:41][C][esp32_camera:049]:   HREF Pin: 27
[21:55:41][C][esp32_camera:050]:   Pixel Clock Pin: 25
[21:55:41][C][esp32_camera:051]:   External Clock: Pin:4 Frequency:20000000
[21:55:41][C][esp32_camera:052]:   I2C Pins: SDA:18 SCL:23
[21:55:41][C][esp32_camera:053]:   Reset Pin: -1
[21:55:41][C][esp32_camera:074]:   Resolution: 640x480 (VGA)
[21:55:41][E][esp32_camera:091]:   Setup Failed: ERROR
[21:55:41][C][web_server:125]: Web Server:
[21:55:41][C][web_server:126]:   Address: ttgocam.local:80
[21:55:41][C][ota:029]: Over-The-Air Updates:
[21:55:41][C][ota:030]:   Address: ttgocam.local:3232
[21:55:41][C][ota:032]:   Using Password.
[21:55:41][C][api:103]: API Server:
[21:55:41][C][api:104]:   Address: ttgocam.local:6053
[21:55:55][V][api:542]: Hello from client: 'Home Assistant 0.96.5 (192.168.2.10)'
[21:55:55][D][api:573]: Client 'Home Assistant 0.96.5 (192.168.2.10)' connected successfully!
[21:56:04][V][api:1191]: on_camera_image_request_ stream=YES single=NO
[21:56:04][V][api:1191]: on_camera_image_request_ stream=NO single=YES
Do it via USB instead until you get a stable stream. The it’s probably fine
Just tried it via USB. The same.
I noticed the following:
[23:01:36][E][camera.c:1085] esp_camera_init(): Camera probe failed with error 0x20001
[23:01:36][E][esp32_camera:017]: esp_camera_init failed: ERROR
[23:01:36][E][component:153]: Component was marked as failed.
The full log.
========================= [SUCCESS] Took 59.11 seconds =========================
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[23:01:36][D][esp32-hal-psram.c:47] psramInit(): PSRAM enabled
[23:01:36][I][logger:116]: Log initialized
[23:01:36][C][ota:364]: There have been 1 suspected unsuccessful boot attempts.
[23:01:36][I][app:028]: Running through setup()...
[23:01:36][V][app:029]: Sorting components by setup priority...
[23:01:36][V][esp32-hal-i2c.c:1483] i2cInit(): num=0 sda=18 scl=23 freq=0
[23:01:36][V][esp32-hal-i2c.c:1677] i2cSetFrequency(): freq=100000Hz
[23:01:36][V][esp32-hal-i2c.c:1692] i2cSetFrequency(): cpu Freq=240Mhz, i2c Freq=100000Hz
[23:01:36][V][esp32-hal-i2c.c:1698] i2cSetFrequency(): Fifo delta=1
[23:01:36][V][esp32-hal-i2c.c:1677] i2cSetFrequency(): freq=50000Hz
[23:01:36][V][esp32-hal-i2c.c:1692] i2cSetFrequency(): cpu Freq=240Mhz, i2c Freq=50000Hz
[23:01:36]
[23:01:36]SCCB_Write [ff]=01 failed
[23:01:36]SCCB_Write [12]=80 failed
[23:01:36][C][wifi:029]: Setting up WiFi...
[23:01:36][V][wifi_esp32:033]: Enabling STA.
[23:01:36]I (1637) wifi: wifi driver task: 3ffb55f4, prio:23, stack:3584, core=0
[23:01:36]I (3489) wifi: wifi firmware version: 6b44342
[23:01:36]I (3493) wifi: config NVS flash: enabled
[23:01:36]I (3496) wifi: config nano formating: disabled
[23:01:36]I (3518) wifi: Init dynamic tx buffer num: 32
[23:01:36]I (3519) wifi: Init data frame dynamic rx buffer num: 10
[23:01:36]I (3519) wifi: Init management frame dynamic rx buffer num: 10
[23:01:36]I (3523) wifi: Init static rx buffer size: 1600
[23:01:36]I (3527) wifi: Init static rx buffer num: 4
[23:01:36]I (3530) wifi: Init dynamic rx buffer num: 10
[23:01:36]I (3602) wifi: mode : softAP (cc:50:e3:b5:fc:e1)
[23:01:36]I (3603) wifi: Init max length of beacon: 752/752
[23:01:36]I (3604) wifi: Init max length of beacon: 752/752
[23:01:36][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 0 - WIFI_READY
[23:01:36][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 13 - AP_START
[23:01:36][V][wifi_esp32:339]: Event: WiFi AP start
[23:01:36][V][wifi_esp32:288]: Event: WiFi ready
[23:01:36]I (3626) wifi: mode : sta (cc:50:e3:b5:fc:e0)
[23:01:36][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 2 - STA_START
[23:01:36][V][wifi_esp32:297]: Event: WiFi STA start
[23:01:36]I (3645) wifi: Set ps type: 0
[23:01:36]
[23:01:36][D][wifi:272]: Starting scan...
[23:01:39][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 1 - SCAN_DONE
[23:01:39][V][wifi_esp32:293]: Event: WiFi Scan Done status=0 number=6 scan_id=128
[23:01:39][D][wifi:287]: Found networks:
[23:01:39][I][wifi:322]: - [redacted] [redacted]β–‚β–„β–†β–ˆ
[23:01:39][D][wifi:323]:     Channel: 1
[23:01:39][D][wifi:324]:     RSSI: -72 dB
[23:01:39][D][wifi:326]: - [redacted] [redacted]β–‚β–„β–†β–ˆ
[23:01:39][I][wifi:164]: WiFi Connecting to [redacted]...
[23:01:39][V][wifi:166]: Connection Params:
[23:01:39][V][wifi:167]:   SSID: [redacted]
[23:01:39][V][wifi:170]:   BSSID: 16:91:82:37:6E:D2
[23:01:39][V][wifi:174]:   Password: [redacted]
[23:01:39][V][wifi:176]:   Channel: 1
[23:01:39][V][wifi:186]:   Using DHCP IP
[23:01:39][V][wifi:188]:   Hidden: NO
[23:01:39]I (6453) wifi: new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:1
[23:01:40]I (7190) wifi: state: init -> auth (b0)
[23:01:40]I (7214) wifi: state: auth -> assoc (0)
[23:01:40]I (7237) wifi: state: assoc -> run (10)
[23:01:40]I (7251) wifi: connected with [redacted], channel 1, bssid = 16:91:82:37:6e:d2
[23:01:40]I (7252) wifi: pm start, type: 0
[23:01:40]
[23:01:40][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 4 - STA_CONNECTED
[23:01:40][V][wifi_esp32:310]: Event: Connected ssid='[redacted]' bssid=[redacted] channel=1, authmode=WPA2 PSK
[23:01:42][D][WiFiGeneric.cpp:342] _eventCallback(): Event: 7 - STA_GOT_IP
[23:01:42][D][WiFiGeneric.cpp:385] _eventCallback(): STA IP: 192.168.2.214, MASK: 255.255.255.0, GW: 192.168.2.1
[23:01:42][V][wifi_esp32:331]: Event: Got IP static_ip=192.168.2.214 gateway=192.168.2.1
[23:01:42][I][wifi:380]: WiFi connected!
[23:01:42][C][wifi:254]:   SSID: [redacted]
[23:01:42][C][wifi:255]:   IP Address: 192.168.2.214
[23:01:42][C][wifi:257]:   BSSID: [redacted]
[23:01:42][C][wifi:258]:   Hostname: 'ttgocam'
[23:01:42][C][wifi:262]:   Signal strength: -66 dB β–‚β–„β–†β–ˆ
[23:01:42][C][wifi:263]:   Channel: 1
[23:01:42][C][wifi:264]:   Subnet: 255.255.255.0
[23:01:42][C][wifi:265]:   Gateway: 192.168.2.1
[23:01:42][C][wifi:266]:   DNS1: 192.168.2.1
[23:01:42][C][wifi:267]:   DNS2: 0.0.0.0
[23:01:42][C][web_server:068]: Setting up web server...
[23:01:42][C][ota:029]: Over-The-Air Updates:
[23:01:42][C][ota:030]:   Address: ttgocam.local:3232
[23:01:42][C][ota:032]:   Using Password.
[23:01:42][C][api:030]: Setting up Home Assistant API server...
[23:01:42][I][app:060]: setup() finished successfully!
[23:01:42][I][app:096]: esphome version 1.13.6 compiled on Aug  5 2019, 21:54:03
[23:01:42][C][wifi:372]: WiFi:
[23:01:42][C][wifi:262]:   Signal strength: -67 dB β–‚β–„β–†β–ˆ
[23:01:42][C][i2c:028]: I2C Bus:
[23:01:42][C][i2c:029]:   SDA Pin: GPIO18
[23:01:42][C][i2c:030]:   SCL Pin: GPIO23
[23:01:42][C][i2c:031]:   Frequency: 50000 Hz
[23:01:42][C][spi:096]: SPI bus:
[23:01:42][C][spi:097]:   CLK Pin: GPIO21 (Mode: OUTPUT)
[23:01:42][C][spi:098]:   MISO Pin: GPIO22 (Mode: INPUT)
[23:01:42][C][spi:099]:   MOSI Pin: GPIO19 (Mode: OUTPUT)
[23:01:42][C][gpio.output:010]: GPIO Binary Output:
[23:01:42][C][gpio.output:011]:   Pin: GPIO0 (Mode: OUTPUT)
[23:01:42][C][gpio.output:011]:   Pin: GPIO12 (Mode: OUTPUT)
[23:01:42][C][gpio.output:011]:   Pin: GPIO2 (Mode: OUTPUT)
[23:01:42][C][logger:137]: Logger:
[23:01:42][C][logger:138]:   Level: VERBOSE
[23:01:42][C][logger:139]:   Log Baud Rate: 115200
[23:01:42][C][logger:140]:   Hardware UART: UART0
[23:01:42][C][esp32_camera:043]: ESP32 Camera:
[23:01:42][C][esp32_camera:044]:   Name: My Camera
[23:01:42][C][esp32_camera:045]:   Board Has PSRAM: YES
[23:01:42][C][esp32_camera:047]:   Data Pins: D0:34 D1:13 D2:26 D3:35 D4:39 D5:38 D6:37 D7:36
[23:01:42][C][esp32_camera:048]:   VSYNC Pin: 5
[23:01:42][C][esp32_camera:049]:   HREF Pin: 27
[23:01:42][C][esp32_camera:050]:   Pixel Clock Pin: 25
[23:01:42][C][esp32_camera:051]:   External Clock: Pin:4 Frequency:20000000
[23:01:42][C][esp32_camera:052]:   I2C Pins: SDA:18 SCL:23
[23:01:42][C][esp32_camera:053]:   Reset Pin: -1
[23:01:42][C][esp32_camera:074]:   Resolution: 640x480 (VGA)
[23:01:42][E][esp32_camera:091]:   Setup Failed: ERROR
[23:01:42][C][web_server:125]: Web Server:
[23:01:42][C][web_server:126]:   Address: ttgocam.local:80
[23:01:42][C][api:103]: API Server:
[23:01:42][C][api:104]:   Address: ttgocam.local:6053
[23:01:49][V][api:542]: Hello from client: 'Home Assistant 0.96.5 (192.168.2.10)'
[23:01:49][D][api:573]: Client 'Home Assistant 0.96.5 (192.168.2.10)' connected successfully!
[23:02:08][V][api:1191]: on_camera_image_request_ stream=YES single=NO
[23:02:31][V][api:1191]: on_camera_image_request_ stream=NO single=YES
This is my code. I got the same error when I was using i2c when I didn’t have the bme sensor on my camera.
esphome:
  platform: ESP32
wifi:
  ssid: "Secret ssid"
  password: "sercret password"
  manual_ip:
    static_ip: cool ip
    gateway: cooler gateway
    subnet: 255.255.255.0
  fast_connect: true
# Enable logging
logger:
api:
  password: ""
ota:
  password: ""
esp32_camera:
  external_clock:
    pin: GPIO4
    frequency: 20MHz
  i2c_pins:
    sda: GPIO18
    scl: GPIO23
  vsync_pin: GPIO5
  href_pin: GPIO27
  resolution: 640x480
  jpeg_quality: 12
  vertical_flip: false
  idle_framerate: 0.1fps
spi:
  clk_pin: GPIO21
  mosi_pin: GPIO19
  miso_pin: GPIO22
output:
  - platform: gpio
    pin: GPIO0
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO2
switch:
  - platform: restart
  - platform: wifi_signal
    update_interval: 300s
  - platform: uptime
Have you got yours working better? I get some pictures now and then but nothing more :slight_smile:
It just sits for now on the desk. But I took the camera module and installed it on an esp32cam board. In the meantime I bought a couple of ttgo beam or something, those that have a small display and antenna. These are working way better but still, from time to time I need to send the rest request.
I think that most of the issues are coming from the board manufacturing quality and from the quality of the cameras.
MFG.
