Esp32 cam stream over internet in HA
Hi guys, i want to know if it’s possible to view my home network esp32-cam streaming simple webserver that’s integrated into HA onto outside network (HA Cloud or Duck DNS)? I tried but i could see just blank unloaded tile on outside network but in local network it’s streaming. I tried camera integration, picture card etc., nothing works on outer network.
Ideas please…
if you can add your stream into HA using generic camera or another type of integration, watching stream will pass through home assistant when you are in external network (also internally).
So, data will flow from esp to home assistant and then to browser.
this works for me (foscam camera)
stream:
ffmpeg:
camera:
  - platform: mjpeg
    mjpeg_url: !secret doorcam_video_url
and also MotionEye works good (as addon)
Please consider moving this question to the Configuration section of the forum. This section is for sharing working projects (which was what I came here for).
Will try and get back to you😀
Someone did that for me, tnx for coordination🤣
Not working, still same blank banner on external website
Esphome works. What fuatakgun said was right, it needs to integrate into home assistant to work
