I don’t think anyone has done the ESP32-cam/ESPHome setup with just a FTDI TTL + rasp pi & Hassio? So I thought it was unique in that I was confirming a hardware combination was working. Or am I mistaken?
Edit: Reading more thoroughly (and soberly) I can see others have already done it. So yeah, it’s a bit of a spammy post I guess.
In case you’re still looking for a solution… I just use a long camera cable gently bending around the back of the board with a 90° twist back to the front.
I have a strange issue with one of my cams. When power is off for an extended period and then restored the device comes online but I get no image. There is an error in the logs when trying to initialize the cam. Rebooting the device does not fix the issue. If I toggle power it starts to work again. The camera is not easily accessible so I was hoping the reset button could restore the camera state.
How about feeding power through a normally closed relay. When you want to power cycle turn the relay on, cutting the power. The relay then switches off and the esp power is restored.
I have a setup with latest hassio and a esp32 cam on my network.
The stream works fine in a browser, but when i try to have the stream in hassio i don’t get any picture at all.
I think i know the issue but i don’t have a solution for it, my access to home assistant is via duckdns and ssl but i don’t have a clue how to fix my stream.
Did anyone get the TTGO-T Camera Plus to work properly with homeassistant/esphome? Been fighting it for several months and no matter what I do it get’s a api block. If you got the answer please do share ^^
This looks like the ttgo camera with motion sensor:) I have 2 of them and they work like a charm. It’s the ttgo plus that is the problem but I can try the code with some pin change to see if it works
