Sorry, but no luck
With version 2.0.0 of Arduino framework, I can compile barely minimum conf (web server, etc.):
esphome:
esp32:
board: esp32dev
framework:
type: arduino
version: 2.0.0
logger:
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Camera-Living-Room"
password: "<some password>"
captive_portal:
web_server:
port: 80
But if I append ESP32 Camera component to above configuration:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
resolution: 640x480
name: Camera Living Room
jpeg_quality: 10
I’m getting compile error:
INFO Reading configuration /config/camera-living-room.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
WARNING GPIO0 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Compiling app...
Processing camera-living-room (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/camera-living-room/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/esp32_camera/esp32_camera.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/camera-living-room/src/esphome/components/mdns/mdns_component.cpp.o
In file included from src/esphome/components/esp32_camera/esp32_camera.cpp:4:
src/esphome/components/esp32_camera/esp32_camera.cpp: In member function 'virtual void esphome::esp32_camera::ESP32Camera::dump_config()':
src/esphome/components/esp32_camera/esp32_camera.cpp:60:56: error: 'struct camera_config_t' has no member named 'pin_sccb_sda'; did you mean 'pin_sscb_sda'?
ESP_LOGCONFIG(TAG, " I2C Pins: SDA:%d SCL:%d", conf.pin_sccb_sda, conf.pin_sccb_scl);
src/esphome/core/log.h:94:90: note: in definition of macro 'esph_log_config'
esp_log_printf_(ESPHOME_LOG_LEVEL_CONFIG, tag, __LINE__, ESPHOME_LOG_FORMAT(format), ##__VA_ARGS__)
src/esphome/components/esp32_camera/esp32_camera.cpp:60:3: note: in expansion of macro 'ESP_LOGCONFIG'
src/esphome/components/esp32_camera/esp32_camera.cpp:60:75: error: 'struct camera_config_t' has no member named 'pin_sccb_scl'; did you mean 'pin_sscb_scl'?
src/esphome/components/esp32_camera/esp32_camera.cpp: In member function 'void esphome::esp32_camera::ESP32Camera::set_i2c_pins(uint8_t, uint8_t)':
src/esphome/components/esp32_camera/esp32_camera.cpp:220:17: error: 'struct camera_config_t' has no member named 'pin_sccb_sda'; did you mean 'pin_sscb_sda'?
this->config_.pin_sccb_sda = sda;
pin_sscb_sda
src/esphome/components/esp32_camera/esp32_camera.cpp:221:17: error: 'struct camera_config_t' has no member named 'pin_sccb_scl'; did you mean 'pin_sscb_scl'?
this->config_.pin_sccb_scl = scl;
pin_sscb_scl
Compiling .pioenvs/camera-living-room/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
*** [.pioenvs/camera-living-room/src/esphome/components/esp32_camera/esp32_camera.cpp.o] Error 1
========================== [FAILED] Took 7.02 seconds ==========================
Did you done something else except of adding version: 2.0.0?
Thx
