Looks out of focus.
Yes it is! This was the first ESPHome device I’ve used and I spent a long time flashing and re-flashing thinking there was a problem when it wouldn’t connect.
Have you found one and tried it? I had a quick search on aliexpress but probably had the wrong search search words as I found nothing
Basically you are looking for a U-FL connector and something that works for 2.4GHz.
I have not really used it much I got it as it was cheap to play with.
The only thing I changed from default was 8 FPS.
This is a screen grab from it.
What’s max reliable frame rate ?
I have not tried it above 8 FPS as that would be ample for what I need such as a door bell. I run quite a few cameras for watching wildlife in the garden they are not connected to HA but are all running at 8 FPS and I get quite good results.
Hi, I installed the cam correctly and wanted to know if can turn it on and off and what is the procedure from Home Assitant. Thank you
my cam, when it arrived it had the protective plastic on the lens, did you look?
that was it
thanks!
now works fine, running it 800x600.
My camera also came with a small heatsink which i put on esp32 chip.
Currently running @ 10fps streaming, 0.1fps loading and had no issue: I must admit I never used “streaming” for more than 30-40s though
The current requirements are large and difficult to meet with a battery.
My esp32-cam runs hot to the touch. Perhaps with solar charging?
My esp32 cam arrived, unfortunately its not the ai thinker mode. I managed to flash it with FTL232 and my laptop, and ESPHOMEFLASHER, everything went well,
With 3,3 V does not connect to WiFi, with 5V yes, but I have this error
[E][esp32_camera:092]: Setup Failed: ERROR
The flash and the LED works fine but the camera shows nothing
Any clue?
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid: "xxxx"
password: "xxxx"
manual_ip:
static_ip: 192.168.1.21
gateway: 192.168.1.253
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
esp32_camera:
external_clock:
pin: GPIO27
frequency: 20MHz
i2c_pins:
sda: GPIO25
scl: GPIO23
data_pins: [GPIO17, GPIO35, GPIO34, GPIO5, GPIO39, GPIO18, GPIO36, GPIO19]
vsync_pin: GPIO22
href_pin: GPIO26
pixel_clock_pin: GPIO21
reset_pin: GPIO15
resolution: 640x480
jpeg_quality: 10
output:
#flashlight
- platform: gpio
pin: GPIO4
#statuslight
- platform: gpio
pin:
number: GPIO33
inverted: True
light:
#flashlight
- platform: binary
output: gpio_4
#statuslight
- platform: binary
output: gpio_33
I changed to these values but same error
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
Is there any documentation on which pins are connected to what?
Finally I managed with the below code to not have any errors … everything works … but no cmera stream
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO35, GPIO34, GPIO39, GPIO36, GPIO19, GPIO21, GPIO5, GPIO18]
vsync_pin: GPIO25
href_pin: GPIO23
This in lovelace
- id: camera_esp
type: picture-entity
title: Cam
show_header_toggle: false
aspect_ratio: 16x9
entity: camera.my_camera
camera_view: live
Log seems ok to me. Does ESPHome store the JPG somewhere, where I can check if they are produced or not?
[09:26:59][I][application:097]: esphome-core version 1.12.2 compiled on May 29 2019, 21:35:27
[09:26:59][C][wifi:371]: WiFi:
[09:26:59][C][wifi:253]: SSID: [redacted]
[09:26:59][C][wifi:254]: IP Address: 192.168.1.211
[09:26:59][C][wifi:256]: BSSID: [redacted]
[09:26:59][C][wifi:257]: Hostname: 'cam'
[09:26:59][C][wifi:261]: Signal strength: -72 dB ▂▄▆█
[09:26:59][C][wifi:262]: Channel: 6
[09:26:59][C][wifi:263]: Subnet: 255.255.255.0
[09:26:59][C][wifi:264]: Gateway: 192.168.1.253
[09:26:59][C][wifi:265]: DNS1: 1.1.1.1
[09:26:59][C][wifi:266]: DNS2: 1.0.0.1
[09:26:59][C][output.gpio:025]: GPIO Binary Output:
[09:26:59][C][output.gpio:026]: Pin: GPIO4 (Mode: OUTPUT)
[09:26:59][C][output.gpio:026]: Pin: GPIO33 (Mode: OUTPUT, INVERTED)
[09:26:59][C][logger:142]: Logger:
[09:26:59][C][logger:143]: Level: DEBUG
[09:26:59][C][logger:144]: Log Baud Rate: 115200
[09:26:59][C][logger:145]: Hardware UART: UART0
[09:26:59][C][light.state:225]: Light 'Cam flash'
[09:27:00][C][light.state:225]: Light 'Cam status'
[09:27:00][C][esp32_camera:044]: ESP32 Camera:
[09:27:00][C][esp32_camera:045]: Name: My Camera
[09:27:00][C][esp32_camera:046]: Board Has PSRAM: YES
[09:27:00][C][esp32_camera:048]: Data Pins: D0:35 D1:34 D2:39 D3:36 D4:19 D5:21 D6:5 D7:18
[09:27:00][C][esp32_camera:049]: VSYNC Pin: 25
[09:27:00][C][esp32_camera:050]: HREF Pin: 23
[09:27:00][C][esp32_camera:051]: Pixel Clock Pin: 22
[09:27:00][C][esp32_camera:052]: External Clock: Pin:0 Frequency:20000000
[09:27:00][C][esp32_camera:053]: I2C Pins: SDA:26 SCL:27
[09:27:00][C][esp32_camera:054]: Reset Pin: -1
[09:27:00][C][esp32_camera:075]: Resolution: 640x480 (VGA)
[09:27:00][C][esp32_camera:098]: JPEG Quality: 10
[09:27:00][C][esp32_camera:100]: Contrast: 0
[09:27:00][C][esp32_camera:101]: Brightness: 0
[09:27:00][C][esp32_camera:102]: Saturation: 0
[09:27:00][C][esp32_camera:103]: Vertical Flip: ON
[09:27:00][C][esp32_camera:104]: Horizontal Mirror: ON
[09:27:00][C][esp32_camera:121]: Test Pattern: NO
[09:27:00][C][text_sensor.version:027]: Version Text Sensor 'Cam ESPHome Version'
[09:27:00][C][text_sensor.version:027]: Icon: 'mdi:new-box'
[09:27:00][C][sensor.wifi_signal:027]: WiFi Signal 'Cam WiFi Signal'
[09:27:00][C][sensor.wifi_signal:027]: Unit of Measurement: 'dB'
[09:27:00][C][sensor.wifi_signal:027]: Accuracy Decimals: 0
[09:27:00][C][sensor.wifi_signal:027]: Icon: 'mdi:wifi'
[09:27:00][C][web_server:126]: Web Server:
[09:27:00][C][web_server:127]: Address: 192.168.1.211:80
[09:27:00][C][api:101]: API Server:
[09:27:00][C][api:102]: Address: 192.168.1.211:6053
[09:27:00][C][ota:127]: Over-The-Air Updates:
[09:27:00][C][ota:128]: Address: 192.168.1.211:3232
[09:27:19][I][ota:152]: Boot seems successful, resetting boot loop counter.
You don’t mention adding it via the configurations page in HA?
Mmhh yes I added it, everything is there: the LED turns ON and also the flash turns ON, the CAM symbol, its there, when I click on it … shows no feed
The log will show you if images are being created.
I have already asked, but “Is there any documentation on which pins are connected to what?”
Exactly what device did you buy (link to the web page please).
- Ok
- No, searched but could not find, only the below
OV2640 ESP32-CAM Wireless WiFi Bluetooth Module Camera Development Board ESP32 DC 5V Dual-core 32-bit CPU 2MP TF card OV7670
Ok, on some website they say to use the AI thinker mode: BTW when they say RESET mode GPIO -1, what is -1, GPIO1?
EDIT: well its the pinout that I am using right now … I rechecked my code with the below code, and seems to me to be the same (RESETcode its not in the ESPhome code)
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
