Esp32_Camera is marked FAILED
Hi All
Please can someone assist me with the below Error on my ESP32 Camera Set Up in Home Assistance. I get the below error and are not sure if its Hardware or Code related:
[10:47:01][E][esp32_camera:123]: Setup Failed: ESP_ERR_NOT_FOUND
[10:47:01][E][component:082]: Component esp32_camera is marked FAILED
Code below:
esphome:
  platform: ESP32
  board: esp32cam
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "243a8uqRxCI2GA1F4+ShZyAr1KTAnK9FvjuxTrRUZe8="
ota:
  platform: esphome
web_server:
  port: 80
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Cam Fallback Hotspot"
    password: "C3FOhAPFtouw"
captive_portal:
# Example configuration entry
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  resolution: 800x600
# Flashlight
output:
  - platform: ledc
    pin: GPIO4
    channel: 2 # channel 1 is used for esp32_camera
## GPIO_4 is the flash light pin
light:
  - platform: monochromatic
    output: led
Thanking you in advance
My camera was working fine but for no apparent reasons and without ant changes on the .yaml, I started having this error.
Full starting log :
INFO ESPHome 2024.7.2
INFO Reading configuration /config/poulcam.yaml...
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
INFO Detected timezone 'Etc/UTC'
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
INFO Starting log output from 192.168.1.69 using esphome API
INFO Successfully connected to poulcam @ 192.168.1.69 in 0.152s
INFO Successful handshake with poulcam @ 192.168.1.69 in 0.202s
[15:23:03][I][app:100]: ESPHome version 2024.7.2 compiled on Jul 30 2024, 23:35:41
[15:23:03][C][wifi:599]: WiFi:
[15:23:03][C][wifi:427]:   Local MAC: E4:65:B8:70:B0:7C
[15:23:03][C][wifi:432]:   SSID: [redacted]
[15:23:03][C][wifi:435]:   IP Address: 192.168.1.69
[15:23:03][C][wifi:439]:   BSSID: [redacted]
[15:23:03][C][wifi:440]:   Hostname: 'poulcam'
[15:23:03][C][wifi:442]:   Signal strength: -73 dB ▂▄▆█
[15:23:03][C][wifi:446]:   Channel: 11
[15:23:03][C][wifi:447]:   Subnet: 255.255.255.0
[15:23:03][C][wifi:448]:   Gateway: 192.168.1.1
[15:23:03][C][wifi:449]:   DNS1: 0.0.0.0
[15:23:03][C][wifi:450]:   DNS2: 0.0.0.0
[15:23:03][C][logger:185]: Logger:
[15:23:03][C][logger:186]:   Level: DEBUG
[15:23:03][C][logger:188]:   Log Baud Rate: 115200
[15:23:03][C][logger:189]:   Hardware UART: UART0
[15:23:03][C][uptime.sensor:033]: Uptime Sensor 'Poulcam Uptime'
[15:23:03][C][uptime.sensor:033]:   Device Class: 'duration'
[15:23:03][C][uptime.sensor:033]:   State Class: 'total_increasing'
[15:23:03][C][uptime.sensor:033]:   Unit of Measurement: 's'
[15:23:03][C][uptime.sensor:033]:   Accuracy Decimals: 0
[15:23:03][C][uptime.sensor:033]:   Icon: 'mdi:timer-outline'
[15:23:03][C][uptime.sensor:034]:   Type: Seconds
[15:23:03][C][switch.gpio:068]: GPIO Switch 'IR Light Switch'
[15:23:03][C][switch.gpio:091]:   Restore Mode: always OFF
[15:23:03][C][switch.gpio:031]:   Pin: GPIO2
[15:23:03][C][template.binary_sensor:028]: Template Binary Sensor 'Camera is streaming'
[15:23:03][C][esp32_camera:048]: ESP32 Camera:
[15:23:03][C][esp32_camera:049]:   Name: Poulcam
[15:23:03][C][esp32_camera:050]:   Internal: NO
[15:23:03][C][esp32_camera:052]:   Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[15:23:03][C][esp32_camera:053]:   VSYNC Pin: 25
[15:23:03][C][esp32_camera:054]:   HREF Pin: 23
[15:23:03][C][esp32_camera:055]:   Pixel Clock Pin: 22
[15:23:03][C][esp32_camera:056]:   External Clock: Pin:0 Frequency:20000000
[15:23:03][C][esp32_camera:060]:   I2C Pins: SDA:26 SCL:27
[15:23:03][C][esp32_camera:062]:   Reset Pin: -1
[15:23:03][C][esp32_camera:089]:   Resolution: 1280x1024 (SXGA)
[15:23:03][E][esp32_camera:123]:   Setup Failed: ERROR
[15:23:03][E][component:082]:   Component esp32_camera is marked FAILED
[15:23:03][C][homeassistant.time:010]: Home Assistant Time:
[15:23:03][C][homeassistant.time:011]:   Timezone: 'UTC0'
[15:23:03][C][copy.sensor:015]: Copy Sensor 'WiFi Signal Percent'
[15:23:03][C][copy.sensor:015]:   State Class: 'measurement'
[15:23:03][C][copy.sensor:015]:   Unit of Measurement: '%'
[15:23:03][C][copy.sensor:015]:   Accuracy Decimals: 0
[15:23:03][C][dht:017]: DHT:
[15:23:03][C][dht:018]:   Pin: GPIO15
[15:23:03][C][dht:024]:   Model: DHT22 (or equivalent)
[15:23:03][C][dht:027]:   Update Interval: 60.0s
[15:23:03][C][dht:029]:   Temperature 'Poulcam Température'
[15:23:03][C][dht:029]:     Device Class: 'temperature'
[15:23:03][C][dht:029]:     State Class: 'measurement'
[15:23:03][C][dht:029]:     Unit of Measurement: '°C'
[15:23:03][C][dht:029]:     Accuracy Decimals: 1
[15:23:03][C][dht:030]:   Humidity 'Poulcam Humidité'
[15:23:03][C][dht:030]:     Device Class: 'humidity'
[15:23:03][C][dht:030]:     State Class: 'measurement'
[15:23:03][C][dht:030]:     Unit of Measurement: '%'
[15:23:03][C][dht:030]:     Accuracy Decimals: 0
[15:23:03][C][internal_temperature:076]: Internal Temperature Sensor 'Température Processeur'
[15:23:03][C][internal_temperature:076]:   Device Class: 'temperature'
[15:23:03][C][internal_temperature:076]:   State Class: 'measurement'
[15:23:03][C][internal_temperature:076]:   Unit of Measurement: '°C'
[15:23:03][C][internal_temperature:076]:   Accuracy Decimals: 1
[15:23:03][C][version.text_sensor:021]: Version Text Sensor 'Poulcam ESPHome Version'
[15:23:03][C][version.text_sensor:021]:   Icon: 'mdi:new-box'
[15:23:03][C][restart:068]: Restart Switch 'Poulcam restart'
[15:23:03][C][restart:070]:   Icon: 'mdi:restart'
[15:23:03][C][restart:091]:   Restore Mode: always OFF
[15:23:03][C][psram:020]: PSRAM:
[15:23:03][C][psram:021]:   Available: YES
[15:23:03][C][psram:024]:   Size: 2047 KB
[15:23:03][C][captive_portal:088]: Captive Portal:
[15:23:03][C][mdns:116]: mDNS:
[15:23:03][C][mdns:117]:   Hostname: poulcam
[15:23:03][C][esphome.ota:073]: Over-The-Air updates:
[15:23:03][C][esphome.ota:074]:   Address: 192.168.1.69:3232
[15:23:03][C][esphome.ota:075]:   Version: 2
[15:23:03][C][esphome.ota:078]:   Password configured
[15:23:03][C][safe_mode:018]: Safe Mode:
[15:23:03][C][safe_mode:020]:   Boot considered successful after 60 seconds
[15:23:03][C][safe_mode:021]:   Invoke after 10 boot attempts
[15:23:03][C][safe_mode:023]:   Remain in safe mode for 300 seconds
[15:23:03][C][api:139]: API Server:
[15:23:03][C][api:140]:   Address: 192.168.1.69:6053
[15:23:03][C][api:142]:   Using noise encryption: YES
[15:23:03][C][wifi_signal.sensor:009]: WiFi Signal 'Poulcam Wifi signal'
[15:23:03][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[15:23:03][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[15:23:03][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[15:23:03][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[15:23:03][C][wifi_info:011]: WifiInfo SSID 'Poulcam WiFi'
[15:23:03][C][esp32_camera_web_server:088]: ESP32 Camera Web Server:
[15:23:03][C][esp32_camera_web_server:089]:   Port: 8080
[15:23:03][C][esp32_camera_web_server:091]:   Mode: stream
[15:23:03][E][esp32_camera_web_server:097]:   Setup Failed
[15:23:03][E][component:082]:   Component esp32_camera_web_server is marked FAILED
[15:23:03][C][esp32_camera_web_server:089]:   Port: 8081
[15:23:03][C][esp32_camera_web_server:093]:   Mode: snapshot
Did you managed to get it resolved ?
Any ideas on how to get the stream back ?
Thank’s in advance
Same error. Solved changing usb cable.
