misa1515
(Misa1515)
April 12, 2024, 6:57pm
1
HW Raspberry Pi4
HomeAssistant Core 2024.4.3
Supervisor 2024.04.0
OS 12.2
Frontend 20240404.2
Esphome 2024.3.2
Esphome hw ESP32-WROOM-32 (AZ-Delivery)
Python 3.12.3
(issue know too for older versions of HA and Esphome)
Description of issue
When are power off RPi4 and Esphome - then after power on HA is started without any issue and ESP32 is on (RED LED ON, power 5VDC), but not found online in HA. Then power adapter of ESP32 is unpluged and again powered and then is again online in HA (issue can be reproduced and is happened repeately).
When only RPi4 is switch to power off state. Then is powered on again (ESP32 is still under voltage) - but not found ESP32 online in HA Esphome. Then power adapter of ESP32 is unpluged and again powered and then is again online in HA Esphome (issue can be reproduced and is happened repeately).
How to solve this repeated issue, please?
misa1515
(Misa1515)
April 12, 2024, 7:02pm
2
And source code
(some settings in source code exhanged by question mark)
esphome:
friendly_name: Plynomer
esp32:
board: esp32dev
framework:
type: arduino
logger:
level: NONE
# baud_rate: 9600
baud_rate: 0
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-??????"
password: "????????????"
captive_portal:
substitutions:
platform: ESP32
board: esp32dev
device_name_short: "plynomer" # used by esp-home config
friendly_name: "BK-G4MT" # Elster DE-07-MI002-PTB002, No 06832435-041-11-I, 1 imp = 0,01 m3
device_description: "Plynomer"
update_interval: 60s # 60s 5.7.2023 17:40
impulsfactor: "0.0100"
appversion: "1.1.7"
# Global variables
globals:
- id: z61count
type: int
restore_value: yes
initial_value: "0"
- id: z61counter
type: float
restore_value: yes
initial_value: "0.0"
- id: m3kw
type: float
restore_value: yes
initial_value: "10.94"
- id: gas_meter_displayinital
type: float
restore_value: yes
initial_value: "29060.654"
- id: gas_meter_displayvalue
type: float
restore_value: yes
initial_value: "29246.433"
- id: gas_meter_totalm3
type: float
restore_value: yes
# Global variables
- id: boot_counter
type: int
restore_value: yes
initial_value: "0"
- id: daily_value
type: float
restore_value: yes
- id: hour_value
type: float
restore_value: yes
## binary sensors
## switches
switch:
- platform: restart
name: ${friendly_name} reset boot počítadla
turn_on_action:
then:
- lambda: |-
id(boot_counter) = 0;
id(bootcounter).update();
- logger.log: ${device_name_short} reset boot counter o.k!
name: ${friendly_name} reset všetko
turn_on_action:
then:
- lambda: |-
id(z61counter) = 0.0;
id(z61count) = 0;
id(gas_meter_totalm3)= 0.0;
id(gas_meter_displayvalue)= 0.0;
id(daily_value)= 0.0;
id(hour_value)= 0.0;
id(gas_meter_display).update();
id(gas_meter_total_m3).update();
id(gas_meter_total_kw).update();
id(gas_meter_total_kw_day).update();
- logger.log: ${device_name_short} all values reset!
## all default sensors
## all text sensors
text_sensor:
- platform: version
name: ${friendly_name} online od
icon: mdi:clock-start
- platform: wifi_info
ip_address:
icon: mdi:ip-network
ssid:
icon: mdi:wifi
bssid:
icon: mdi:wifi
mac_address:
name: ${friendly_name} MAC Wifi Adresa
icon: mdi:wifi
# Base packages wifi, timeserver...
#packages:
# base: !include common/base.yaml
# base_webserver: !include common/base_webserver.yaml
# base_global: !include common/base_global.yaml
# Switch to restart, reset all, reset bootcounter
# GASCOUNTER ZI-61 REED CONTACT
# GPIO19 <-- o-RC-o <--- GND
# o-10k ----> +5V
# Gasmeter: Krom Schröder BK-G4
# Q_max: 4 m³/h
# Q_min: 0.025 m³/h
# V: 1.2 dm³
# p_max: 0.5 bar
# 1 imp = 0.01 m³
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO19
inverted: false
mode: # INPUT_PULLUP # set ESP32 pin to input pull-up mode
input: true
pullup: true
name: ${friendly_name} Plynomer Z-61 Impulzy
device_class: window
filters:
- delayed_off: 10ms
## This automation will be triggered when a button press ends,
## or in other words on the falling edge of the signal.
on_release:
then:
- lambda: |-
ESP_LOGI("main", " ------- Z-61 SET NEW VALUES !!!!!");
id(z61count) += 1;
id(z61counter) += ${impulsfactor};
id(gas_meter_displayvalue) += ${impulsfactor};
id(gas_meter_totalm3) += ${impulsfactor};
id(daily_value) += ${impulsfactor};
id(hour_value) += ${impulsfactor};
id(gas_meter_m3_today).publish_state(${impulsfactor});
# ALL SENSORS
- platform: pulse_meter
pin: GPIO21 # priamo na +5VDC
name: "X_Instant water consumption"
unit_of_measurement: "L/min"
# timeout: 1s
internal_filter_mode: PULSE
internal_filter: 50ms
accuracy_decimals: 3
filters:
- lambda: return (x / 0.1);
total:
unit_of_measurement: "m³"
device_class: gas
state_class: total_increasing
filters:
- lambda: return (x / 100.0);
# - platform: adc
# pin: GPIO32
# name: "Napätie batérie"
# unit_of_measurement: "V"
# update_interval: 60s
# attenuation: 11dB
# Attenuation (db)
# | | attenuation | suggested range |
# | SoC | (dB) | (mV) |
# | | 0 | 100 ~ 950 |
# | | 2.5 | 100 ~ 1250 |
# | ESP32 +-------------+-----------------+
# | | 6 | 150 ~ 1750 |
# | | 11 | 150 ~ 2450 |
# | | 0 | 0 ~ 750 |
# | | 2.5 | 0 ~ 1050 |
# | ESP32-S2 +-------------+-----------------+
# | | 6 | 0 ~ 1300 |
# | | 11 | 0 ~ 2500 |
unit_of_measurement: 'kW'
#device_class: 'power'
#state_class: 'measurement'
pin: GPIO18 # D
filters:
- multiply: 1 # (60s / 75 pulses per kWh) * 1000 W
- filter_out: nan
total:
unit_of_measurement: 'imp'
device_class: gas # nove od 6.8.2023
state_class: total_increasing # nove od 6.8.2023
accuracy_decimals: 0
filters:
- multiply: 1
# - debounce: 300ms
on_value:
then:
- lambda: |-
id(z61count) += 1;
name: ${friendly_name} počítadlo štartov
lambda: |-
return (id(boot_counter));
- platform: uptime
name: ${friendly_name} Uptime Sensor
update_interval: ${update_interval}
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? String(days) + "d " : "") +
(hours ? String(hours) + "h " : "") +
(minutes ? String(minutes) + "m " : "") +
(String(seconds) + "s")
).c_str();
- platform: wifi_signal
name: ${friendly_name} WiFi signál
update_interval: 60s # 6.8.2023 17:30 60s
name: "${friendly_name} WiFi signál percentuálne"
icon: "mdi:wifi"
unit_of_measurement: "%"
lambda: |-
if (id(wifisignal).state) {
if (id(wifisignal).state <= -100 ) {
return 0;
} else if (id(wifisignal).state >= -50) {
return 100;
} else {
return 2 * (id(wifisignal).state + 100);
} else {
return NAN;
name: ${friendly_name} Plynomer zobrazené
accuracy_decimals: 2
icon: "mdi:counter"
device_class: gas
lambda: |-
return id(gas_meter_displayvalue);
name: ${friendly_name} Plynomer aktuálne
state_class: measurement
device_class: gas
unit_of_measurement: "imp"
lambda: |-
return (id(z61count));
name: ${friendly_name} m³ celkovo
device_class: gas
lambda: |-
return id(gas_meter_totalm3);
name: ${friendly_name} m³ za deň
icon: mdi:gauge
lambda: |-
return (id(daily_value));
name: ${friendly_name} m³ za hodinu
icon: mdi:gauge
lambda: |-
return (id(hour_value));
name: ${friendly_name} kWh celkovo
device_class: energy
unit_of_measurement: "kWh"
lambda: |-
return (id(gas_meter_totalm3) * id(m3kw));
name: ${friendly_name} kWh za deň
lambda: |-
return (id(daily_value) * id(m3kw));
name: ${friendly_name} kWh za hodinu
lambda: |-
return (id(hour_value) * id(m3kw));
