Hi guys,
I’m trying to make the Grow R503 work with my ESP32 WROOM-32, but it crashes. I’m using ESPHome version 2024.2.2
My configuration:
esphome:
esp32:
board: az-delivery-devkit-v4
framework:
type: arduino
# Enable logging
logger:
ota:
password: "xxx"
wifi:
ssid: "mynet"
password: "xxx"
ap:
ssid: "Bearcave-Entry"
password: "xxx"
mdns:
disabled: false
uart:
rx_pin: GPIO21
tx_pin: GPIO22
baud_rate: 57600
fingerprint_grow:
sensing_pin: GPIO23
on_finger_scan_invalid:
- homeassistant.event:
event: esphome.test_node_finger_scan_invalid
on_finger_scan_matched:
event: esphome.test_node_finger_scan_matched
finger_id: !lambda 'return finger_id;'
confidence: !lambda 'return confidence;'
on_finger_scan_unmatched:
event: esphome.test_node_finger_scan_unmatched
on_finger_scan_misplaced:
event: esphome.frontdoor_finger_scan_misplaced
on_enrollment_scan:
event: esphome.test_node_enrollment_scan
scan_num: !lambda 'return scan_num;'
on_enrollment_done:
event: esphome.test_node_enrollment_done
on_enrollment_failed:
event: esphome.test_node_enrollment_failed
api:
encryption:
key: "xxx"
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
- fingerprint_grow.enroll:
num_scans: !lambda 'return num_scans;'
- service: cancel_enroll
then:
- fingerprint_grow.cancel_enroll:
- service: delete
variables:
finger_id: int
then:
- fingerprint_grow.delete:
- service: delete_all
then:
- fingerprint_grow.delete_all:
Both the power supply and touch induction power supply of the R503 are connected to 3.3V
Log:
[18:03:53][I][logger:359]: Log initialized
[18:03:53][C][ota:483]: There have been 1 suspected unsuccessful boot attempts.
[18:03:53][D][esp32.preferences:114]: Saving 1 preferences to flash...
[18:03:53][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[18:03:53][I][app:029]: Running through setup()...
[18:03:53][C][uart.arduino_esp32:077]: Setting up UART...
[18:03:53][C][fingerprint_grow:055]: Setting up Grow Fingerprint Reader...
[18:03:53][D][fingerprint_grow:205]: Checking password
[18:03:53][D][fingerprint_grow:210]: Password verified
[18:03:53][D][fingerprint_grow:233]: Getting parameters
[18:03:53][D][fingerprint_grow:236]: Got parameters
[18:03:53][D][fingerprint_grow:258]: Getting fingerprint count
[18:03:53][D][fingerprint_grow:261]: Got fingerprint count
[18:03:53][C][wifi:038]: Setting up WiFi...
[18:03:53][C][wifi:051]: Starting WiFi...
[18:03:53][C][wifi:052]: Local MAC: B0:A7:32:D7:52:00
[18:03:54][D][wifi:459]: Starting scan...
[18:03:54][D][fingerprint_grow:098]: Scan and match
[18:03:54][D][fingerprint_grow:129]: Getting image 1
[18:03:54][D][fingerprint_grow:141]: Finger Misplaced
[18:03:54][W][component:214]: Component fingerprint_grow took a long time for an operation (0.09 s).
[18:03:54][W][component:215]: Components should block for at most 20-30ms.
[18:03:56][D][fingerprint_grow:098]: Scan and match
[18:03:56][D][fingerprint_grow:129]: Getting image 1
[18:03:56][D][fingerprint_grow:141]: Finger Misplaced
[18:03:56][W][component:214]: Component fingerprint_grow took a long time for an operation (0.09 s).
[18:03:56][W][component:215]: Components should block for at most 20-30ms.
[18:03:57][D][fingerprint_grow:098]: Scan and match
[18:03:57][D][fingerprint_grow:129]: Getting image 1
[18:03:57][D][fingerprint_grow:141]: Finger Misplaced
[18:03:59][D][fingerprint_grow:098]: Scan and match
[18:03:59][D][fingerprint_grow:129]: Getting image 1
[18:03:59][D][fingerprint_grow:141]: Finger Misplaced
[18:04:00][W][component:214]: Component fingerprint_grow took a long time for an operation (0.17 s).
[18:04:00][W][component:215]: Components should block for at most 20-30ms.
[18:04:00][D][wifi:474]: Found networks:
[18:04:00][I][wifi:518]: - 'mynet2' (8C:FD:DE:33:AC:4C) ▂▄▆█
[18:04:00][D][wifi:519]: Channel: 5
[18:04:00][D][wifi:520]: RSSI: -62 dB
[18:04:00][D][wifi:523]: - 'SXX' (90:17:3F:25:99:00) ▂▄▆█
[18:04:00][D][wifi:523]: - 'mynet' (D4:6E:0E:27:D4:2F) ▂▄▆█
[18:04:00][D][wifi:523]: - 'Telekom-Rf2yN5' (78:65:59:5C:98:5A) ▂▄▆█
[18:04:00][D][wifi:523]: - 'Zxk' (AA:01:12:08:5C:EA) ▂▄▆█
[18:04:00][D][wifi:523]: - 'dlink-x' (10:62:EB:09:F9:A6) ▂▄▆█
[18:04:00][I][wifi:304]: WiFi Connecting to 'mynet2'...
[18:04:00][I][wifi:591]: WiFi Connected!
[18:04:00][C][wifi:409]: Local MAC: B0:A7:32:D7:52:00
[18:04:00][C][wifi:414]: SSID: 'mynet2'
[18:04:00][C][wifi:415]: IP Address: 192.168.1.162
[18:04:00][C][wifi:417]: BSSID: 8C:FD:DE:33:AC:4C
[18:04:00][C][wifi:418]: Hostname: 'bearcave-entry'
[18:04:00][C][wifi:420]: Signal strength: -59 dB ▂▄▆█
[18:04:00][C][wifi:424]: Channel: 5
[18:04:00][C][wifi:425]: Subnet: 255.255.255.0
[18:04:00][C][wifi:426]: Gateway: 192.168.1.1
[18:04:00][C][wifi:427]: DNS1: 192.168.1.1
[18:04:00][C][wifi:428]: DNS2: 0.0.0.0
[18:04:00][D][wifi:600]: Disabling AP...
[18:04:00][C][ota:096]: Over-The-Air Updates:
[18:04:00][C][ota:097]: Address: bearcave-entry.local:3232
[18:04:00][C][ota:100]: Using Password.
[18:04:00][C][ota:103]: OTA version: 2.
[18:04:00][C][api:025]: Setting up Home Assistant API server...
[18:04:00][I][app:062]: setup() finished successfully!
[18:04:01][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 10 2024, 17:34:33
[18:04:01][C][wifi:577]: WiFi:
[18:04:01][C][wifi:409]: Local MAC: B0:A7:32:D7:52:00
[18:04:01][C][wifi:414]: SSID: 'mynet2'
[18:04:01][C][wifi:415]: IP Address: 192.168.1.162
[18:04:01][C][wifi:417]: BSSID: 8C:FD:DE:33:AC:4C
[18:04:01][C][wifi:418]: Hostname: 'bearcave-entry'
[18:04:01][C][wifi:420]: Signal strength: -61 dB ▂▄▆█
[18:04:01][C][wifi:424]: Channel: 5
[18:04:01][C][wifi:425]: Subnet: 255.255.255.0
[18:04:01][C][wifi:426]: Gateway: 192.168.1.1
[18:04:01][C][wifi:427]: DNS1: 192.168.1.1
[18:04:01][C][wifi:428]: DNS2: 0.0.0.0
[18:04:01][C][logger:447]: Logger:
[18:04:01][C][logger:448]: Level: DEBUG
[18:04:01][C][logger:449]: Log Baud Rate: 115200
[18:04:01][C][logger:451]: Hardware UART: UART0
[18:04:01][C][uart.arduino_esp32:137]: UART Bus 1:
[18:04:01][C][uart.arduino_esp32:138]: TX Pin: GPIO22
[18:04:01][C][uart.arduino_esp32:139]: RX Pin: GPIO21
[18:04:01][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[18:04:01][C][uart.arduino_esp32:143]: Baud Rate: 57600 baud
[18:04:01][C][uart.arduino_esp32:144]: Data Bits: 8
[18:04:01][C][uart.arduino_esp32:145]: Parity: NONE
[18:04:01][C][uart.arduino_esp32:146]: Stop bits: 1
[18:04:01][C][fingerprint_grow:443]: GROW_FINGERPRINT_READER:
[18:04:01][C][fingerprint_grow:444]: System Identifier Code: 0x0000
[18:04:01][C][fingerprint_grow:446]: Touch Sensing Pin: GPIO23
[18:04:01][C][fingerprint_grow:447]: Update Interval: 0.5s
[18:04:01]Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
[18:04:01]
[18:04:01]Core 1 register dump:
[18:04:01]PC : 0x4016651b PS : 0x00060530 A0 : 0x800d8832 A1 : 0x3ffb2740
WARNING Decoded 0x4016651b: esphome::sensor::Sensor::get_state() const at /home/laci/projects/esphome/.esphome/build/bearcave-entry/src/esphome/components/sensor/sensor.cpp:86
[18:04:01]A2 : 0x00000000 A3 : 0x3f40106e A4 : 0x000001bf A5 : 0x3f4010ea
[18:04:01]A6 : 0x00000000 A7 : 0x3fe00000 A8 : 0x800e03d1 A9 : 0x3ffb26d0
[18:04:01]A10 : 0x00000004 A11 : 0x3f40106e A12 : 0x000001bf A13 : 0x3f4010ea
[18:04:01]A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000001f EXCCAUSE: 0x0000001c
[18:04:01]EXCVADDR: 0x00000024 LBEG : 0x40089961 LEND : 0x40089971 LCOUNT : 0xfffffff0
[18:04:01]
[18:04:01]
[18:04:01]Backtrace:0x40166518:0x3ffb27400x400d882f:0x3ffb2760 0x40166739:0x3ffb27b0 0x400deb89:0x3ffb27d0 0x400e0eba:0x3ffb2800 0x400e9b19:0x3ffb2820
WARNING Found stack trace! Trying to decode it
WARNING Decoded 0x40166518: esphome::sensor::Sensor::get_state() const at /home/laci/projects/esphome/.esphome/build/bearcave-entry/src/esphome/components/sensor/sensor.cpp:86
WARNING Decoded 0x400d882f: esphome::fingerprint_grow::FingerprintGrowComponent::dump_config() at /home/laci/projects/esphome/.esphome/build/bearcave-entry/src/esphome/components/fingerprint_grow/fingerprint_grow.cpp:449 (discriminator 2)
WARNING Decoded 0x40166739: esphome::Component::call_dump_config() at /home/laci/projects/esphome/.esphome/build/bearcave-entry/src/esphome/core/component.cpp:78
WARNING Decoded 0x400deb89: esphome::Application::loop() at /home/laci/projects/esphome/.esphome/build/bearcave-entry/src/esphome/core/application.cpp:108
WARNING Decoded 0x400e0eba: loop() at /home/laci/projects/esphome/.esphome/build/bearcave-entry/bearcave-entry.yaml:105
WARNING Decoded 0x400e9b19: loopTask(void*) at /home/laci/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:50
[18:04:01]
[18:04:01]
[18:04:01]
[18:04:01]
[18:04:01]ELF file SHA256: 0000000000000000
[18:04:01]
[18:04:01]Rebooting...
[18:04:01]ets Jul 29 2019 12:21:46
[18:04:01]
[18:04:01]rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[18:04:01]configsip: 0, SPIWP:0xee
[18:04:01]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[18:04:01]mode:DIO, clock div:2
[18:04:01]load:0x3fff0030,len:1184
[18:04:01]load:0x40078000,len:13132
[18:04:01]load:0x40080400,len:3036
[18:04:01]entry 0x400805e4
[18:04:01][I][logger:359]: Log initialized
As you can see, fingerprint detection works, but the board crashes until it settles in safe mode.
Thanks in advance!
