ESP32 Deep Sleep for Rain Guage
Is it possible to wake up my ESP32 with the same pin as a sensor?
I have a Rain Guage I’ve build, which uses Pin 27 with a hall effect sensor to detect a bucket tip for rain.
What I’d like to do is put the ESP32 to deep sleep until the bucket tip is detected, then stay wake for a minute, sending any successive tips, resetting that timer. Once it stops raining, the bucket stops tipping and a minute later, deep sleep resumes.
Here’s my current YAML:
substitutions:
  wake_time: '60s'
esphome:
  friendly_name: ESP32 Rain Gauge
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxx"
ota:
  password: "xxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32-Rain-Gauge"
    password: "xxxxxxxxx"
captive_portal:
# Reed switch between GPIO and GND
  - platform: pulse_counter
    pin:
      number: GPIO27
    unit_of_measurement: mm
    filters:
      - multiply: 0.02
deep_sleep:
  sleep_duration: 30s
  run_duration: 30s
  esp32_ext1_wakeup:
    mode: ALL_LOW
    pins:
      - 27
I am putting together a greenhouse system including rain gauge, and so wanting to do the exact same thing. Did you get it working ?
Finally given this some detailed attention. See my result at Use a binary sensor to wake up from deep sleep - #13 by donburch888
