Hello All
I have and ESP32 board where I have integrated Temperature / Humidity sensor DHT11. All works actually above expectations, there is just this one little problem which I cant get solved.
From time to time I have to disconnect the ESP32 from power , or I even loose electricity at all for short amount of time. During this time, the sensor values stored in Hassio are always “0” zeros. At the end is not such a big deal, but the graphs then looks strange. Its not so easy to read the graphs if it displays the range from 0 to 80, comparing to for example 65 to 80 , which would normally displayed as min and max values. See example below.
Anyone got an idea how to get rid of the zeros?
I know that in general configuration.yaml one could use availibilty:
attribute for sensor, but how to use it in ESPHome i dont know.
Below you can find the configuration of my sensor within ESPhome
- platform: dht
pin: 23
temperature:
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
humidity:
filters:
window_size: 15
send_every: 15
model: AM2302
update_interval: 10s
Thank you all for help
