Good afternoon! I already had a Smartreader ESP32 ready-made PCB for the P1 meter.
Today I started with an ESP32 PCB and I want to connect 2 bed sensors to it, I have already made the config.
Now I saw in the ESP dashboard that the smart reader has a diagnosis tab and the new ESP32 does not. Can I configure this somewhere so that I can also see the connection information for the ESP32 PCB?
Each one of those entities is something you have to manually add to your YAML. Just Google each and you’ll see how to do it; I have a handful of those types of sensors/entities that I add to all my ESPHome projects.
Thank you, it worked. Sometimes just taking a closer look can make a lot clear. I was able to find everything I needed here.
While the link describes how to get the connection information, it does not describe how to get the “Diagnose” and other sensor-categories ![]()
If you want to put all those information into an diagnostic “Tab”, you should add the entity_category information to the config:
entity_category: "diagnostic"
the whole sensor should look like this then.
- platform: wifi_signal
name: "WiFi Signal dB"
update_interval: 60s
This might just be a relevant information for others that might find this thread ^^
Very true, sorry! Below is the code for anyone who wants to add this with a restart button.
text_sensor:
- platform: wifi_info
ip_address:
ssid:
- platform: version
hide_timestamp: true
disabled_by_default: false
icon: mdi:new-box
entity_category: diagnostic
switch:
- platform: restart
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "${name} Signaal dB"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "${name} Signaal &"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: " %"
device_class: ""
- platform: uptime
force_update: false
unit_of_measurement: s
icon: mdi:timer-outline
accuracy_decimals: 0
device_class: duration
state_class: total_increasing
I know this is an old post…
Thank you, I’ve been looking at how to place diagnostics info on my HA dashboard for a while and stumbled across this.
Thant you know of is there any way to have the log of an ESP32 display on dashboard?.. I don’t want to keep having to go to the ESPHome integration to find the log.
