I am trying to compile a firmware for a WT32-ETH01 device. Flashed it using UART (no USB port) using web flash without problems. The initial yaml included
esp32:
board: esp32dev
framework:
type: esp-idf
Which did not compile. In another thread here there was a solution to it by changing esp-idf to “arduino”, which fixed the compilation error, but it introduced another:
Compiling .pioenvs/esphome-web-b38560/lib4c5/Network/NetworkClient.cpp.o
execv errno (13)
thread 'main' panicked at 'internal error: entered unreachable code', main.rs:223:5
Full log attached.
Has anyone got an idea on how to compile a firmware for this device?
BTW, I am still using wifi, as the old recommended setup for this device on many tutorials (How I installed ESPHome on the wt32-eth01) does not work:
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
as clk_mode
is deprecated.
Wifi works for now anyway after initializing the device - I just can’t compile a firmware with the current (2025.8.1) ESPHome build.
INFO ESPHome 2025.8.1
INFO Reading configuration /config/esphome/esphome-web-b38560.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-b38560 (board: esp32dev; framework: arduino; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
INFO Package configuration completed successfully
Library Manager: Installing ESP32Async/AsyncTCP @ 3.4.5
INFO Installing ESP32Async/AsyncTCP @ 3.4.5
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing ESP32Async/ESPAsyncWebServer @ 3.7.10
INFO Installing ESP32Async/ESPAsyncWebServer @ 3.7.10
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-arduinoespressif32 @ 3.2.1
- framework-arduinoespressif32-libs @ 5.4.0+sha.858a988d6e
- tool-esptoolpy @ 5.0.2
- tool-mklittlefs @ 3.2.0
- toolchain-xtensa-esp-elf @ 14.2.0+20241119
Dependency Graph
|-- Networking @ 3.2.1
|-- AsyncTCP @ 3.4.5
|-- WiFi @ 3.2.1
|-- FS @ 3.2.1
|-- Update @ 3.2.1
|-- ESPAsyncWebServer @ 3.7.10
|-- ESP32 Async UDP @ 3.2.1
|-- DNSServer @ 3.2.1
|-- ESPmDNS @ 3.2.1
execv errno (13)
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
Compiling .pioenvs/esphome-web-b38560/lib4c5/Network/NetworkEvents.cpp.o
*** [.pioenvs/esphome-web-b38560/lib4c5/Network/NetworkClient.cpp.o] Error 101
execv errno (13)
*** [.pioenvs/esphome-web-b38560/lib4c5/Network/NetworkEvents.cpp.o] Error 101
========================== [FAILED] Took 9.59 seconds ==========================
Any hints?
