Wondering if there is any development to take advantage of this functionality? Search returned nothing. In my case I’d like to be able switching pin modes in code to monitor different devices on the same pin : leak sensor and motion sensor.
Muxing is working fine on esphome, pin can be defined as I/O, uart, i2c, ledc…
Dynamic swapping can be more restricted.
You don’t specify what are you exactly after. Esphome has allow_other_uses parameter and you probably can change pinmodes on lambda.
hi, I’m running esp32 with this yaml: water leak, DS18B20 sensors, two reed switches. Also want to add HC-SR501 PIR motion sensor without opening the box just using one of the pins that is outside on terminal block (these are accessible : GPIO35- ADC leak detector, GPIO32, 33- switches, GPIO16 -one wire) . I’m thinking may be use GPIO16 for PIR? Reference to documentation or yaml example would be very helpful. Thank you
- platform: adc
pin: GPIO35 # Heater and HVAC leak sensor
attenuation: auto
icon: mdi:water-alert
name: "Heater & AC leak"
unit_of_measurement: "%"
accuracy_decimals: 0
filters:
- sliding_window_moving_average:
window_size: 5
send_every: 5
send_first_at: 1
- calibrate_linear:
- 3.0 -> 0
- 1.5 -> 100
- clamp:
min_value: 0
max_value: 100
ignore_out_of_range: False
#update_interval: 12s
#DS18B20 Actual sensor
- platform: dallas_temp
address: 0x6f791cd435646128
unit_of_measurement: "°C"
icon: "mdi:thermometer"
device_class: "temperature"
state_class: "measurement"
accuracy_decimals: 2
update_interval: 30s
address: 0x8f161dd435646128
update_interval: 60s
address: 0x9c000000bbf38728
name: "Temperature Water Heater"
binary_sensor:
lambda: |-
float analog = id(water_heater_ac_leak).state;
return analog > 60;
on_press:
then:
- switch.turn_on: buzzer_sw
on_release:
then:
- switch.turn_off: buzzer_sw
- platform: gpio
name: "Garage door Closed"
pin:
number: GPIO32
mode:
input: true
pullup: true
filters:
- delayed_off: 500ms
- platform: gpio
name: "Garage door Open"
pin:
number: GPIO33
mode:
input: true
pullup: true
filters:
switch:
- platform: gpio
pin:
number: GPIO2
inverted: false
optimistic: true
turn_on_action:
- while:
condition:
lambda: 'return true;'
then:
- delay: 10s
- delay: 20s
turn_off_action:
one_wire:
- platform: gpio
pin:
number: GPIO16
mode:
input: true
pullup: true
I don’t see this viable. Afaik HC-SR501 has push-pull output, it will not “collaborate” with other circuits connected.
Ok, Thank you.
