ESP32 hangs on boot after every OTA
Good morning!
I have connected a touch sensor to an ESP32 according to these instructions and two additional servos.
Actually everything works fine, but after an OTA the device is stuck somewhere during boot: it can be reached via ping, but webfronted and API are not connected.
If I then disconnect and reconnect the power supply, it boots up normally again.
Here is the code:
substitutions:
  friendly_name: "Heizungsraum Gastherme"
esphome:
  friendly_name: "${friendly_name}"
  platform: ESP32
  board: nodemcu-32s
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: XXX.XXX.XXX.XXX
    gateway: XXX.XXX.XXX.XXX
    subnet: XXX.XXX.XXX.XXX
  reboot_timeout: 5min
  ap:
    ap_timeout: 24h
    ssid: “${friendly_name} AP"
    password: !secret ap_password
web_server:
  port: 80
api:
  encryption:
    key: XXXXXXXXXXXXXXXXXXXXX
ota:
mdns:
  disabled: false
logger:
esp32_touch:
# setup_mode: True
  iir_filter: 10ms
binary_sensor:
  - platform: esp32_touch
    name: "Heizungsraum Wasserleck"
    pin: GPIO27
    threshold: 100
output:
  - platform: ledc
    pin: GPIO16
    frequency: 50 Hz
  - platform: ledc
    pin: GPIO17
    frequency: 50 Hz
servo:
  - id: heizungswasser_regler
    output: heizungswasser_regler_pwm
    transition_length: 6s
    restore: true
  - id: brauchwasser_regler
    output: brauchwasser_regler_pwm
    restore: true
select:
    name: 'Heizungswasser vorwärmen:'
    icon: "mdi:heating-coil"
    optimistic: true
    options:
      - "Aus"
      - "Stufe 1"
      - "Stufe 2"
      - "Stufe 3"
      - "Stufe 4"
      - "Stufe 5"
      - "Sparbetrieb"
      - "Maximum"
    set_action:
      then:
          - delay: 1s
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Aus";
              then:
                - number.set:
                    value: -100
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Stufe 1";
              then:
                - number.set:
                    value: -70
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Stufe 2";
              then:
                - number.set:
                    value: -40
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Stufe 3";
              then:
                - number.set:
                    value: -10
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Stufe 4";
              then:
                - number.set:
                    value: 25
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Stufe 5";
              then:
                - number.set:
                    value: 50
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Sparbetrieb";
              then:
                - number.set:
                    value: 75
          - if:
              condition:
                - lambda: |-
                    return (id(heizungswasser_wahl).state) == "Maximum";
              then:
                - number.set:
                    value: 100
    name: 'Brauchwasser vorwärmen:'
    icon: "mdi:hand-water"
    optimistic: true
    options:
      - "Aus"
      - "Stufe 1"
      - "Stufe 2"
      - "Stufe 3"
      - "Stufe 4"
      - "Stufe 5"
      - "Sparbetrieb"
      - "Stufe 6"
      - "Maximum"
    set_action:
      then:
          - delay: 1s
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Aus";
              then:
                - number.set:
                    value: -100
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 1";
              then:
                - number.set:
                    value: -75
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 2";
              then:
                - number.set:
                    value: -50
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 3";
              then:
                - number.set:
                    value: -25
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 4";
              then:
                - delay: 1s
                - number.set:
                    value: 0
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 5";
              then:
                - number.set:
                    value: 25
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Sparbetrieb";
              then:
                - number.set:
                    value: 50
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Stufe 7";
              then:
                - number.set:
                    value: 75
          - if:
              condition:
                - lambda: |-
                    return (id(brauchwasser_wahl).state) == "Maximum";
              then:
                - number.set:
                    value: 100
number:
    internal: true
    min_value: -100
    initial_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    set_action:
      then:
        - servo.write:
            level: !lambda 'return x / 100.0;'
    internal: true
    min_value: -100
    initial_value: 0
    max_value: 100
    step: 1
    optimistic: true
    restore_value: true
    set_action:
      then:
        - servo.write:
Unfortunately I also get no log-output, so I can’t say exactly where it is stuck. However, if I do not connect the touch sensor, it runs without any problems.
As far as I can tell, however, I have done everything correctly in tom_i’s instructions, or can you find the error?
Any help would be highly appreciated!
I have exactly the same problem but on a D1 mini with a simple BME280 sensor on battery shield after an OTA.
No log output most of the time or boot log interrupted somewhere in the middle after OTA and upon each reset button press.
Works fine for the rest :thinking:
Thank you for your reply. Browsed the posts meanwhile and found several posts concerning this issue: but never a solution… :frowning: @tom_l : did you have similar problems or were your ESPs only equipped with the waterless-sensors?
I have never had this issue.
