Hi all
I tried to solution on my problem almost everywhere, but no success
I have ESP32 connected to the home assistant and is powered by powerbank. I have deep sleep mode programmed and is almost working correctly
Wake up by time is working perfectly, but I am not able wake up by configured touch sensor. Touch sensor is working correctly because if ESP is alive, then my sensor is working. Can me help somebody. I am totally frustrated, that I am lost maybe one week with finding some solution, but nothing works. I tried connect power supply with USB port and by VIN pins, both connection doesnβt help.
My code is:
sphome:
friendly_name: ESP pool
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "fhryr/eg="
ota:
- platform: esphome
password: "42de63436"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esp-Pool"
password: "789"
web_server:
port: 80
version: 2
deep_sleep:
run_duration:
default:
seconds: 30
touch_wakeup_reason:
seconds: 60
sleep_duration: 2min
touch_wakeup: true
captive_portal:
one_wire:
- platform: gpio
pin: GPIO17
i2c:
sda: GPIO21
scl: GPIO22
scan: false
frequency: 800kHz
esp32_touch:
setup_mode: false
binary_sensor:
- platform: esp32_touch
pin: GPIO4
threshold: 1000
wakeup_threshold: 1000
on_press:
then:
- binary_sensor.template.publish:
state: ON
- switch.turn_on: display_relay
state: OFF
on_release:
then:
- switch.turn_off: display_relay
filters:
- delayed_off: 10s
on_press:
then:
- lambda: |-
id(mydisplay).backlight();
on_release:
then:
- lambda: |-
id(mydisplay).no_backlight();
- platform: status
name: "ESP pool wifi"
on_state:
then:
- if:
condition:
wifi.connected:
then:
- output.turn_on: blue_led
else:
- output.turn_off: blue_led
- platform: dallas_temp
address: 0xbf41d6d446357528
unit_of_measurement: Β°C
icon: "mdi:thermometer-plus"
device_class: temperature
state_class: measurement
accuracy_decimals: 1
update_interval: 10s
accuracy_decimals: 0
lambda: return esp_sleep_get_wakeup_cause();
switch:
- platform: gpio
pin:
number: 19
mode: OUTPUT
output:
- platform: gpio
pin: GPIO2
