Hello all
I am trying to accomplish what seems to be basic task - to detect open circuit.
Schematic of my current setup is:
(despite setting a pin as pull up - I still add physical pull up as I though that maybe internal one is not enough. I also try a setup without a resistor connected.
I power it using USB with good quality “phone charger”.
Code for EspHome:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
web_server:
port: 80
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: "my-wifi-2.0"
password: "... secret ..."
ap:
ssid: "my-sensor-02 Fallback Hotspot"
binary_sensor:
- platform: gpio
pin:
number: GPIO21
mode: INPUT_PULLUP
device_class: opening
filters:
- delayed_on: 100ms
- delayed_off: 100ms
I also tried syntax (cannot find definitive reference documentation which one is correct):
- platform: gpio
pin:
number: 21
mode:
input: true
pullup: true
When I close the circuit - it correctly reads ON - and the state is stable - will stay like this for multiple minutes.
When I open the circuit - the state changing multiple times a minute. This is log:
[15:03:08][C][logger:305]: Hardware UART: UART0
[15:03:08][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'my_sensor_8_state'
[15:03:08][C][gpio.binary_sensor:015]: Device Class: 'opening'
[15:03:08][C][gpio.binary_sensor:016]: Pin: GPIO21
[15:03:08][C][web_server:161]: Web Server:
[15:03:08][C][web_server:162]: Address: my-sensor-02.local:80
[15:03:08][C][mdns:112]: mDNS:
[15:03:08][C][mdns:113]: Hostname: my-sensor-02
[15:03:08][C][ota:093]: Over-The-Air Updates:
[15:03:08][C][ota:094]: Address: my-sensor-02.local:3232
[15:03:08][C][api:138]: API Server:
[15:03:08][C][api:139]: Address: my-sensor-02.local:6053
[15:03:08][C][api:143]: Using noise encryption: NO
[15:03:13][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:13][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:14][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:14][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:15][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:15][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:18][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:18][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:19][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:19][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:20][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:20][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:23][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:23][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:24][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:24][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:25][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:25][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:26][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:26][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:27][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:27][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:29][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:29][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:30][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:30][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:34][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:34][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
[15:03:37][D][binary_sensor:036]: 'my_sensor_8_state': Sending state OFF
[15:03:37][D][binary_sensor:036]: 'my_sensor_8_state': Sending state ON
I also used another ESP32 board i had at home with same result.
Please help with figuring out how to get stable state with open circuit.
