Hey everyone, all of the sudden I’ve been having some issues trying to connect esp32’s to HA. This specific one is a devkitc, and i flash esphome via web.esphome per usual. However when I try to adopt it into home assistant, I get this error. Tried on two brand new esp’s, same thing. Any help would be greatly appreciated
INFO Reading configuration /config/esphome/esphome-web-113150.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-113150 (board: esp32dev; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
Library Manager: Installing esphome/AsyncTCP-esphome @ 1.2.2
INFO Installing esphome/AsyncTCP-esphome @ 1.2.2
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- AsyncTCP-esphome @ 1.2.2
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 2.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/api_connection.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/api_server.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/list_entities.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/proto.cpp.o
Compiling /data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/subscribe_state.cpp.o
src/esphome/components/api/proto.cpp:91:1: internal compiler error: Segmentation fault
} // namespace esphome
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://gcc.gnu.org/bugs/> for instructions.
*** [/data/esphome-web-113150/.pioenvs/esphome-web-113150/src/esphome/components/api/proto.cpp.o] Error 1
========================= [FAILED] Took 24.18 seconds =========================
