Hi there,
I’m getting started with my HomeAssistant Setup after migrating from OpenHAB. Learning curve is okay but now I want to advance my setup and use ESPHome to get mmWave tracking on it’s way.
But I’m stuck at the basics.
I’ve installed the ESPHome Addon, flashed my ESP32 (AZDelivery Rev C v4) and want to adopt it in ESPHome.
I copy the key, hit install and I am greeted with this mess of logfile:
INFO ESPHome 2023.12.5
INFO Reading configuration /config/esphome/esphome-web-cde9d0.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-cde9d0 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
warning: Calling missing SConscript without error is deprecated.
Transition by adding must_exist=False to SConscript calls.
Missing SConscript '/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build-esp32.py'
File "/data/cache/platformio/packages/framework-arduinoespressif32/tools/platformio-build.py", line 161, in <module>
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
Compiling .pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_frame_helper.cpp.o
In file included from src/esphome/components/api/api_connection.h:3,
from src/esphome/components/api/api_connection.cpp:1:
src/esphome/components/api/api_frame_helper.h:2:10: fatal error: cstdint: No such file or directory
#include <cstdint>
compilation terminated.
Compiling .pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_pb2.cpp.o
In file included from src/esphome/components/api/api_frame_helper.cpp:1:
#include <cstdint>
Compiling .pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_pb2_service.cpp.o
*** [.pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_connection.cpp.o] Error 1
*** [.pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
In file included from src/esphome/components/api/proto.h:3,
from src/esphome/components/api/api_pb2.h:5,
from src/esphome/components/api/api_pb2.cpp:3:
src/esphome/core/component.h:3:10: fatal error: string: No such file or directory
#include <string>
from src/esphome/components/api/api_pb2_service.h:5,
from src/esphome/components/api/api_pb2_service.cpp:3:
#include <string>
*** [.pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_pb2.cpp.o] Error 1
*** [.pioenvs/esphome-web-cde9d0/src/esphome/components/api/api_pb2_service.cpp.o] Error 1
========================== [FAILED] Took 3.24 seconds ==========================
Yesterday evening I was messing about with it and got numerous other issues. Got some random code errors that said that helper:arduino_header.h is missing, the compiling would take ages and my HA would freeze / crash completely.
Currently running it on an RPI 4 with 4g ram. Nothing special - CPU load is <10%, RAM usage is around 1 - 1.5GB. So nothing to worry about.
Any tips would be appreciated.
I am stuck with installing code to the ESP32 - Not even trying to upload fancy stuff. Just basic controls for the DFRobot mmWave Sensors. But now even the base code is not working?
PS:
For completeness sake:
Here’s the logfile of the Addon Log:
023-12-29 23:07:43,156 INFO 200 GET /edit?configuration=esphome-web-cde9d0.yaml (0.0.0.0) 4.28ms
2023-12-29 23:07:43,181 INFO 101 GET /ace (0.0.0.0) 1.41ms
2023-12-29 23:07:43,183 INFO Running command 'esphome --dashboard -q vscode --ace /config/esphome'
2023-12-29 23:07:46,528 INFO 200 POST /edit?configuration=esphome-web-cde9d0.yaml (0.0.0.0) 1155.93ms
2023-12-29 23:07:46,569 INFO 200 GET /info?configuration=esphome-web-cde9d0.yaml (0.0.0.0) 2.89ms
2023-12-29 23:07:47,542 INFO 101 GET /compile (0.0.0.0) 1.32ms
2023-12-29 23:07:47,545 INFO Running command 'esphome --dashboard compile /config/esphome/esphome-web-cde9d0.yaml'
2023-12-29 23:07:52,474 INFO Process exited with return code 1
and here is the YAML that was auto-generated when adding the device:
esphome:
friendly_name: ESPHome TEST2
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: <key>
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Cde9D0"
password: <pass>
captive_portal:
Thanks and cheers,
