Hey everyone.
i have a liitle problem
so:
i bought this:
and i follow this tuto:
https://haade.fr/en/blog/homeassistant-assist-esphome-esp32-korvo-wroover-e-microphone-array$
but when i say the wake word nothing appen ;
maybe an error in the esphome code ?
substitutions:
##### WIFI SETUP #####
###### CHANGE ME START ######
device_name: "esp32korvo_mic"
wifi_ssid: !secret wifi_ssid
wifi_password: !secret wifi_password
apikey: !secret enc_key_esp32korvo_mic
##### CHANGE ME END #####
esphome:
min_version: 2023.11.0
platformio_options:
board_build.flash_mode: dio
on_boot:
- priority: -100
then:
- wait_until: api.connected
- delay: 1s
- if:
condition:
switch.is_on: use_wake_word
then:
- voice_assistant.start_continuous:
esp32:
board: esp-wrover-kit
framework:
type: arduino
version: recommended
external_components:
- source: github://rpatel3001/esphome@es8311
components: [ es8311 ]
- source: github://rpatel3001/esphome@es7210
components: [ es7210 ]
- source: github://pr#5230
components:
- esp_adf
# Enable logging
logger:
level: VERBOSE
##### API KEY #####
api:
encryption:
key: ${apikey}
##### OTA PASSWORD #####
ota:
password: ${wifi_password}
safe_mode: true
reboot_timeout: 3min
num_attempts: 3
text_sensor:
- platform: wifi_info
ip_address:
name: "${device_name} IP Address"
time:
platform: homeassistant
#### WIFI PASSWORD ###
wifi:
networks:
- id: wifi_default
ssid: ${wifi_ssid}
use_address: 192.168.42.159
ap:
ssid: ${device_name}
i2c:
sda: GPIO19
scl: GPIO32
scan: true
frequency: 400kHz
es8311:
address: 0x18
es7210:
address: 0x40
output:
- platform: gpio
pin: GPIO12
i2s_audio:
- id: codec
i2s_lrclk_pin: GPIO22
i2s_bclk_pin: GPIO25
i2s_mclk_pin: GPIO0
- id: mic_adc
i2s_lrclk_pin: GPIO26
i2s_bclk_pin: GPIO27
# i2s_mclk_pin: GPIO0
speaker:
- platform: i2s_audio
dac_type: external
i2s_audio_id: codec
i2s_dout_pin: GPIO13
mode: mono
microphone:
adc_type: external
i2s_audio_id: mic_adc
i2s_din_pin: GPIO36
pdm: false
voice_assistant:
microphone: external_mic
speaker: external_speaker
noise_suppression_level: 2
auto_gain: 15dBFS
volume_multiplier: 0.5
use_wake_word: false
on_listening:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
brightness: 100%
effect: wakeword
on_tts_start:
- light.turn_on:
blue: 0%
red: 0%
green: 100%
brightness: 50%
effect: pulse
on_end:
- delay: 100ms
- wait_until:
not:
speaker.is_playing:
- script.execute: reset_led
on_error:
- light.turn_on:
blue: 0%
red: 100%
green: 0%
brightness: 100%
effect: none
- delay: 1s
- script.wait: reset_led
- lambda: |-
if (code == "wake-provider-missing" || code == "wake-engine-missing") {
id(use_wake_word).turn_off();
script:
- id: reset_led
then:
- if:
condition:
then:
- light.turn_on:
blue: 30%
red: 0%
green: 0%
brightness: 25%
effect: none
else:
- light.turn_off: led_ring
switch:
name: Use wake word
optimistic: true
restore_mode: RESTORE_DEFAULT_ON
entity_category: config
on_turn_on:
- lambda: id(voice_asst).set_use_wake_word(true);
- if:
condition:
not:
- voice_assistant.is_running
then:
on_turn_off:
- voice_assistant.stop
# Restart option
- platform: restart
light:
- platform: esp32_rmt_led_strip
pin: GPIO33
num_leds: 12
rmt_channel: 0
rgb_order: GRB
chipset: ws2812
default_transition_length: 0s
effects:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
- addressable_twinkle:
twinkle_probability: 5%
progress_interval: 4ms
- addressable_color_wipe:
colors:
- red: 28%
green: 100%
blue: 90%
num_leds: 12
add_led_interval: 40ms
reverse: false
binary_sensor:
name: "${device_name} Volume Up"
name: "${device_name} Volume Down"
on_press:
- output.turn_on: pa_ctrl
- voice_assistant.start:
- light.turn_on:
brightness: 100%
effect: "Wakeword"
on_release:
- voice_assistant.stop:
- output.turn_off: pa_ctrl
- light.turn_off:
# Status de connection
- platform: status
- id: button_adc
platform: adc
internal: true
pin: 39
attenuation: 11db
update_interval: 15ms
filters:
- median:
window_size: 5
send_every: 5
send_first_at: 1
- delta: 0.1
on_value_range:
- below: 0.55
then:
- binary_sensor.template.publish:
state: ON
- above: 0.65
below: 0.92
then:
state: ON
- above: 1.02
below: 1.33
then:
state: ON
- above: 1.43
below: 1.77
then:
state: ON
- above: 1.87
below: 2.15
then:
state: ON
- above: 2.25
below: 2.56
then:
state: ON
- above: 2.8
then:
state: OFF
state: OFF
state: OFF
state: OFF
state: OFF
state: OFF
# Wifi signal
- platform: wifi_signal
name: "${device_name} WiFi Signal"
update_interval: 60s
Thanks for your reply
