I try to create a device where I switch a general relay from esp32 mini. I connected it to IO16 and also other. But no matter what I do, the lights on the relay are both on on boot. Relay is connected to a small pump and pump is connected to COM and NO. But also when I connect the pump to COM and NC it does not turn on, other pump is same.
So I am not sure what is wrong, does relay not work, are pumps defect or is the code wrong
Here is the esphome code
substitutions:
friendly_name: Plant Sensor 1
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp32:
board: wemos_d1_mini32
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${device_name}-plant-sensor-1"
password: "Ho6iNSovLIS5"
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
port: 80
switch:
- platform: gpio
pin: GPIO016
Not sure if the board is a problem, I also tried with esp32dev.
Any ideas?
