I’ve been having some difficulty for a number of weeks trying to debug an issue connecting an ESP32 (using IDF) to my MQTT server using TLS. I’m getting an error:
error:1402542E:SSL routines:ACCEPT_SR_CLNT_HELLO:tlsv1 alert protocol version
I initially started out using Let’s Encrypt certs but in an effort to get even a successful test connection, I’m currently using self signed certificates. I am getting the same I’ve been following plenty of guidance / troubleshooting but haven’t found much in terms of the similar issues (certainly not within the esphome ecosystem).
My ESP32 yaml is below and I’m using 2023.7.1 (recently upgraded as a troubleshooting step):
esphome:
friendly_name: test
esp32:
board: esp32dev
framework:
type: esp-idf
version: recommended
# Custom sdkconfig options
sdkconfig_options:
CONFIG_COMPILER_OPTIMIZATION_SIZE: y
# Advanced tweaking options
advanced:
ignore_efuse_mac_crc: false
mqtt:
broker: FQDN
username: username
password: password
client_id: .friendly_name.
port: 8883
discovery_prefix: friendly_name/alive
log_topic: friendly_name/logs
skip_cert_cn_check: true
idf_send_async: false
certificate_authority: |
-----BEGIN CERTIFICATE-----
ca.cert contents
-----END CERTIFICATE-----
Below are 1) my mosquitto config related to TLS 2) Mosquitto log extract 3) esphome device logs:
# Secure mqtt
listener 8883
certfile /mosquitto/certs/server.crt
cafile /mosquitto/certs/ca.crt
keyfile /mosquitto/certs/server.key
tls_version tlsv1.2
INFO ESPHome 2023.7.1
INFO Reading configuration /config/test.yaml...
INFO Starting log output from test/logs
INFO Successfully reconnected to the MQTT server
Any guidance / support technical or moral would be greatly appreciated.
