I have an ESP32 that been fine.
However, it now no longer re-connects to wifi after using OTA update.
If I upload via USB using ESPHome flasher, suing the same config file, it then reconnects to WiFi and API OK.
If I subsequently do an OTA update, the update completes but then it won’t reconnect to Wifi and I have to update using USB again.
Any idea what’s going on or where to look for the cause?
========================= [SUCCESS] Took 15.49 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of stepper-test.local
INFO -> 10.0.1.101
INFO Uploading /data/stepper-test/.pioenvs/stepper-test/firmware.bin (1057200 bytes)
Uploading: [============================================================] 100% Done...
INFO Waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from stepper-test.local using esphome API
WARNING Can't connect to ESPHome API for stepper-test.local: Timeout while connecting to ('10.0.1.101', 6053)
INFO Trying to reconnect to stepper-test.local in the background
